Question about Toshiba Satellite A135-S4527 Notebook
Reset bios password/jump cmos
I cant remember password and would like a picture and directions on how to jump cmos. Is it the same as jumping a different model # satellite? I already have the board apart so if someone could help asap it would be great. thanks
    Problem Solver:
  • 8 Answers
You can remove your BIOS battery for about 10 seconds and the BIOS password and adjustmens that you custom made in your BIOS will reset.
you dont need to jump cmos if you get out the BIOS battery for a couple of seconds because the BIOS will reset itsself
let me know how it worked out
greetings
Posted on Jan 02, 2009
My leptop ibm thinkpad A22P is lock with bios password not opned my leptop
Answer: If you encounter a password prompt at boot or the BIOS / CMOS setup is locked as shown below and you do not know the password you will need to clear the BIOS password using the suggestions listed below.
cmospass.jpg Generic BIOS / CMOS passwords
Try using generic CMOS passwords. A complete listing of these passwords can be found on document CH000451.
Use a BIOS password utility
There are utilities designed to help bypass CMOS passwords. An example of a great utility to decrypt / bypass BIOS passwords is the PC BIOS Security and Maintenance toolkit, which is available by clicking here.
Clear using jumper (recommended)
Precaution: When inside the computer please be sure you're aware of the potential damage that can be caused by ESD.
jumper.jpgOn the computer motherboard locate the BIOS clear / password jumper or dipswitch and change its position. This jumper is often labeled CLEAR, CLEAR CMOS, JCMOS1, CLR, CLRPWD, PASSWD, PASSWORD, PSWD or PWD as shown in the picture to the right. To change the jumper simply remove it from the two pins its currently on so that it covers the pin that is not covered. For example, in the picture to the right pins 1 and 2 are covered, you'd remove the jumper and put it on pins 2 and 3.
Once this jumper has been changed, turn on the computer and the password should be cleared. Once cleared, turn the computer off and return the jumper or dipswitch to its original position.
The location of the jumpers or dipswitches are dependent on the manufacturer of the computer and motherboard. However, below are some general ideas on where to find it. Remember that most motherboards could have dozens of different jumpers, make sure you're changing the CMOS jumper and not something else. If these general suggestions do not help refer to your motherboard / computer documentation or skip to the next step.
  1. On the edge of the motherboard - Most jumpers are located on the side of the motherboard for easy accessibility, verify by looking at all visible edges of the motherboard.
  2. By the CMOS battery - Some manufactures will place the jumper to clear the CMOS / BIOS password by the actual CMOS battery.
  3. By the processor - Some manufactures will place the jumpers by the processor of the computer.
  4. Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
  5. Other visible location - While it is possible that the jumpers / dipswitches may not be in a visible location, most manufactures try to make things easier by placing the jumpers / dipswitches in another visible location.
Remove CMOS battery
cmos.gifRemoving the CMOS battery like the one shown in the picture to the right will cause the system to loose all CMOS settings including the password. To do this locate and remove the CMOS battery on the motherboard for at least five-minutes. After this has been done put the battery back into the computer and turn it back on.
Jump the CMOS solder beads
Older computers and especially older laptops don't have jumpers or dipswitches and require the user to jump a pair of solder beads on a circuit board. The identification and location of these solder beads can vary and if not available in computer documentation is only obtainable through the computer manufacturer.
If you've identified the solder beads they can be jumped by placing a flat-head screwdriver over the two beads and leaving it on those beads while turning on the computer. Once the computer has booted turn off the computer and then remove the screwdriver.
PLEASE ACCEPTT
Nov 17, 2010 | IBM (08K3261) for ThinkPad A20P, A20M,...
How to bypass bios passwords on a Toshiba L505-S5966?
Many computers reset BIOS by removing the CMOS battery.Wait several minutes then reinsert it and restart your computer.
Some computer require a pin jump to reset the BIOS password. Check your owners manual.
Good luck
Feb 01, 2010 | Toshiba Computers & Internet
Can't change enter BIOS on Ubisurfer... help?
Before attempting to bypass the BIOS password on a computer, please take a minute to contact the hardware manufacturer support staff directly and ask for their recommended methods of bypassing the BIOS security. In the event the manufacturer cannot (or will not) help you, there are a number of methods that can be used to bypass or reset the BIOS password yourself.
Try this first :
manufacturer name : HP
password : HP
Method 1 : Removing the CMOS Battery
The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time.
Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all.For eg: IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set.
Method 2 : Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings
Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturers documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop.
Please remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position.
Method 3 :
Jumping the Solder Beads on the CMOS
It is also possible to reset the CMOS by connecting or "jumping" specific solder beads on the chipset. There are too many chipsets to do a breakdown of which points to jump on individual chipsets, and the location of these solder beads can vary by manufacturer, so please check your computer and motherboard documentation for details. This technique is not recommended for the inexperienced and should be only be used as a "last ditch" effort.
Method 4 :
Password cracking software
The following software can be used to either crack or reset the BIOS on many chipsets. If your PC is locked with a BIOS administrator password that will not allow access to the floppy drive, these utilities may not work. Also, since these utilities do not come from the manufacturer, use them cautiously and at your own risk.
Cmos password recovery tools 3.1
!BIOS
RemPass
KILLCMOS
Dec 28, 2009 | HEWLETT-PACKARD HEWLETT PACKARD PCDO...
Friend gave me an hp pavillion zv5000 that they couldnt get to work. it needs the power on password and they dont have it. i am a pc tech so i have no problem with doing any kind of laptop surgery. would...
Method 3 :
Method 4 :
!BIOS
RemPass
KILLCMOS
Note : Download this tool.
http://rs80l34.rapidshare.com/files/68277812/11204651/unlock6.zip
It's HP confidential tools to reset BIOS.
Dec 26, 2009 | HP Pavilion zv5000 Notebook
I turned on my toshiba l305s-5900d on day and it is asking for a bios password, but i never put on on it. does anyone have any help. i would apprediate any help. thanks john
Try this first :
manufacturer name : Toshiba
password : Toshiba
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
Method 3 :
Method 4 :
!BIOS
RemPass
KILLCMOS
Dec 10, 2009 | Toshiba Satellite Pro L300 Notebook
How do you reset a Toshiba Satellite L305D Power on Password?
To reset the password on this model, you need to:
  • Power off the computer, flip it over, and open the ram door
  • Find a small jumper to the left of memory module 0 (the one closest to the board).
  • Use a screwdriver to jump this pad while you turn the computer on
  • Continue jumping the pad until after the splash screen dissappears
  • If successfull the password prompt will go away. If not, try try again.
  • When successful, make haste to update your bios: http://cdgenp01.csd.toshiba.com/cont...s/slb8v140.exe Toshiba's have a nasty habit of setting bios passwords on their own. I'm assuming thats why you're here.
Sep 27, 2009 | Toshiba Satellite L305D-S5881 Notebook
I have a dell 4600 that I got from my daughter . which I had to re-install and It has a password in the bios for the set up and my daughter dont know
Hi katmbutts;
Before attempting to bypass the BIOS password on a computer, please take a minute to contact the hardware manufacturer support staff directly and ask for their recommended methods of bypassing the BIOS security. In the event the manufacturer cannot (or will not) help you, there are a number of methods that can be used to bypass or reset the BIOS password yourself. They include:
    • Using a manufacturers backdoor password to access the BIOS
    • Use password cracking software
    • Reset the CMOS using the jumpers or solder beads.
    • Removing the CMOS battery for at least 10 minutes
    • Overloading the keyboard buffer
    • Using a professional service
Please remember that most BIOS passwords do not protect the hard drive, so if you need to recover the data, simply remove the hard drive and install it in an identical system, or configure it as a slave drive in an existing system. The exception to this are laptops, especially IBM Thinkpads, which silently lock the hard drive if the supervisor password is enabled. If the supervisor password is reset without resetting the and hard drive as well, you will be unable to access the data on the drive.
Backdoor passwords
Many BIOS manufacturers have provided backdoor passwords that can be used to access the BIOS setup in the event you have lost your password. These passwords are case sensitive, so you may wish to try a variety of combinations. Keep in mind that the key associated to "_" in the US keyboard corresponds to "?" in some European keyboards. Laptops typically have better BIOS security than desktop systems, and we are not aware of any backdoor passwords that will work with name brand laptops. WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords Award BIOS backdoor passwords:
ALFAROME BIOSTAR KDD ZAAADA ALLy CONCAT Lkwpeter ZBAAACA aLLy CONDO LKWPETER ZJAAADC aLLY Condo PINT 01322222 ALLY d8on pint 589589 aPAf djonet SER 589721 _award HLT SKY_FOX 595595 AWARD_SW J64 SYXZ 598598 AWARD?SW J256 syxz AWARD SW J262 shift + syxz AWARD PW j332 TTPTHA AWKWARD j322 awkward AMI BIOS backdoor passwords:
AMI AAAMMMIII BIOS PASSWORD HEWITT RAND AMI?SW AMI_SW LKWPETER A.M.I. CONDO PHOENIX BIOS backdoor passwords: phoenix, PHOENIX, CMOS, BIOS MISC. COMMON PASSWORDS
ALFAROME LKWPETER BIOSTAR lkwpeter biostar setup biosstar SETUP CMOS Syxz cmos Wodj OTHER BIOS PASSWORDS BY MANUFACTURER Manufacturer Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX TMC BIGO Toshiba Toshiba TOSHIBA BIOS Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot IBM APTIVA BIOS Press both mouse buttons repeatedly during the boot Then There is Password cracking software The following software can be used to either crack or reset the BIOS on many chipsets. If your PC is locked with a BIOS administrator password that will not allow access to the floppy drive, these utilities may not work. Also, since these utilities do not come from the manufacturer, use them cautiously and at your own risk. Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturer's documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop. Remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position. Removing the CMOS Battery The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time. Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all. IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set. If you reset the BIOS password, but cannot reset the hard drive password, you may not be able to access the drive and it will remain locked, even if you place it in a new laptop. IBM Thinkpads have special jumper switches on the motherboard, and these should be used to reset the system.
Overloading the KeyBoard Buffer On some older computer systems, you can force the CMOS to enter its setup screen on boot by overloading the keyboard buffer. This can be done by booting with the keyboard or mouse unattached to the systems, or on some systems by hitting the ESC key over 100 times in rapid succession. Jumping the Solder Beads on the CMOS It is also possible to reset the CMOS by connecting or "jumping" specific solder beads on the chipset. There are too many chipsets to do a breakdown of which points to jump on individual chipsets, and the location of these solder beads can vary by manufacturer, so please check your computer and motherboard documentation for details. This technique is not recommended for the inexperienced and should be only be used as a "last ditch" effort. I hope this helps, Don't forget to leave a rating. Mark
Apr 23, 2009 | Dell Dimension 4600 PC Desktop
Bios password
The master password for Compaq is "compaq"
If that doesn't work you need to use a jumpe on the motherboard:
This Jumper is often named like: "RTC_CLEAR" , "CLEAR CMOS" , "CLRCMOS" , "CLRCMS". His position is often near by the motherboard battery. You will need to reconfigure any BIOS changes that you have done.
Mar 17, 2009 | HP Compaq Presario V3000T Notebook
Cant remeber bios password
try removing or disconnecting the CMOS battery of the laptop......then put it back after 5-10mins
Feb 23, 2009 | Acer Aspire 5520-5908 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
760 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
