Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Printer prints blurily! help!!
It seems like the words r printing on top of each other!
    Novelist:
  • 148 Answers
Your fuser roller is dirty it is offsetting the image
FIX
turn machine off and let it cool
there may be a felt cleaning pad ( rod) that you can remove and put some silicone oil on
if you do not see the pad open the machine and release the fuser rollers( area where you would remove a jam at exitit
once you see the fuser area see if you can locate fuser oil (most macines have a small bottle
it is silicone oil that cleans the rollers
call around to staples etc and copy dealers to get some and clean the rolers with a cotton clth and the oil
Good luck
Posted on Jan 02, 2009
  • Steve Archer Jan 02, 2009
    disregard previous solution i thought it was a laser printer te fuzzy image on ink print may be lack of pressure for paper thickness
    check thickness control and also make sure print cartridge is properly seated
I used to be able to select the draft option when printing, but this seems to have disappeared. I am using an Epson stylus TX100 printer and my document is in Word 7. How do I get draft back?
You can set the option to print in Draft mode while in Word. Follow the steps below and see if it works for you.
1. Go to the MS Office button in Word at the top left of the screen.
2. Then click on Word Options button located to the bottom right of the Office Menu.
3. Select the Advanced Options at the left of the screen.
4. Scroll down and look for the Print Advanced Options
5. Choose "Use Draft Quality"
You can also set your printer's properties to print in Draft mode. If you've tried that and it doesn't work I would suggest updating or reloading your printer's drivers. The print drivers may have become corrupted.
I hope that helps.
Apr 12, 2011 | Office Equipment & Supplies
I am trying to print onto pre-printed forms which have a dark blue band at the top. My printer isn't recognising that the band is there so is starting to print too far down the page. Help please!
This type of problem can usually be resolved simply by adjusting the margins from within your word processing program. Depending on which word processor you are using you can go into the page setup and make these changes. For Microsoft Word go to the "File" tab at the top then to page setup. The first tab that comes up will allow you to change the margins on the page. If the print is too far down try reducing the top margin from one inch to 0.5. If that is not enough reduce it some more. Print test pages on regular paper, then hold them up to the light against the paper with the pre-printed band to see how the print lines up. That way you don't waste the expensive paper!
May 20, 2010 | HP Photosmart C5280 Printer
When I try to print something, it doesn't print. It seems to be connected properly.
It seems that either the drivers are not installed for this printer or the printer has not been selected in the word processor. First insert the CD that came with the printer in the drive and install the driver for this printer. reboot. and connect the printer and allow Windows to detect it and load its drivers. Now second, open the document that you want printed in a word processor and give the print command. Here you will find an option on which printer to print on. Select this printer and get the prints.
Nov 19, 2009 | Epson Stylus C62 InkJet Printer
Because my Deskjet 932C wasn't printing at all, I downloaded a new driver for it from the HP site. Now it prints but prints only the top portion of a page -- sometimes about 1.5 inches, sometimes 3 inches,...
I would recommend uninstalling the installed driver from your system, disconnect the USB cable (if one is installed), reboot.
Once the system comes back up, turn off your anti-virus. Now install the printer driver again. Install the USB cable for the printer (if that's how you're connecting) and finish the install.
Re-enable your anti-virus.
Aug 29, 2009 | Office Equipment & Supplies
Page two of a word document prints so every other line is faint
do 1 thing, save document-2 as a pdf file and try to print one document @ a time. it will resolve the issue.
Jul 24, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Prints only top section of test page
when you start printing first you look print preview button in the word. then click print you get full printed .
if its not printing it will be the problem of your ink, it will bw finsh please check it or take printer settting and give printing formate A4 size then print it it will be ok.
Jul 11, 2009 | HP Deskjet D1341 InkJet Printer
Printer prints words on top of each other
Check to make sure that there is nothing preventing the page from being pulled into the printer. Overlapping words is often caused by the paper feed not moving quickly enough, subsequently causing words to overlap and not span the entire page.
If that doesn't work, let me know and we'll troubleshoot further.
May 15, 2009 | Lexmark Z42 InkJet Printer
Kodak 5100 AiO When printing emails the borders
Read through some of the solutions on here and eventually removed print heads and cleaned them and printing of borders and words is now fine. Still have probs with photos being discoloured .
Apr 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
How do i print edge to edge using the G85 Office Jet all in one?
The G85 does not support edge to edge printing, it requires a top margin of 0.08:, a bottom margin of 0.46" and side margins of 0.25".
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Printer seems to be skipping
As the printer is printing fine from word......try to print from notepad and wordpad also.
If it prints fine then it is a problem with internet explorer or it can be also a problem with a particular website.
If you are facing the same problem with all the websites then try reinstalling Internet Explorer.
May 24, 2008 | Dell 922 All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
44 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
