Question about Freezers
Hoshizaki km-1300skf 3 beep error code
The machine is giving me a 3 beep error code every 3 seconds and not making ice at all running around a 20 lbs suction pressure
  • Freezers Master
  • 1,230 Answers
The 3 beeps indicates that the freeze cycle is longer than 60 minutes. with the suction pressure at 20, it sounds like low on charge (freon). I believe this is an R 404-A unit. Other things to look for are: Stuck float switch (in the up position), Water valve leaking, hot gas valve leaking, txv not feeding properly, weak compressor. Look at high side pressure too. It should not go below 210 psi during the freeze cycle. Low pressure should be in the middle to upper 40's psi.
Let me know if you need more.
Posted on Feb 14, 2009
My hoshizaki ice machine KM-900mrf model beeps 3 times and stop making ice. After reset it starts, but stats beeping again after an hour.
Have a look at the side of the evaporator; there is a probe (thermistor) attached to it that tells the control board when to initiate the harvest cycle. make sure it's clean and attached properly and doesn't need replacing. If hitting the float switch initiates the harvest cycle it sounds like you have a blocked/ scaled water tube or switch housing. take off the bottom of the switch assembly (black rubber bit) and clean through to the water chamber. run a cycle of descaler before trying again.
Jul 04, 2015 | Hoshizaki Freezer Commercial Ice Machines...
3 Beep Warning
Staying in the freeze cycle too long. Usually about an hour. Several things can cause this. Look for water running even if machine is off. Possible stuck float switch. And more.
Nov 08, 2013 | Hoshizaki KM-61BAH 49 Pound Self-Contained...
3 beep code on hoshizaki km630mae
Freeze cycle too long. Usually about an hour. Many things can cause this. Look for water running even when machine is off. Stuck float switch causes this. may need a tech to check things out.
Feb 24, 2012 | Hoshizaki Freezer Commercial Ice Machines...
I have a Hoshizaki model Km-250baf it beeps three times.
3 beeps means it has been in the freeze cycle too long. A stuck float switch can cause this as well as a leaking water valve. Look for that first. Let me know if you need more info.
Feb 06, 2011 | Hoshizaki Freezer Commercial Ice Machines...
3 beeps every two seconds not making ice
Aug 12, 2010 | Hoshizaki Freezer Commercial Ice Machines...
I have got Hoshizaki Ice Machine which makes three beep sound every 2 second continuously. I turned off the machine. It looks it needs to be cleaned. Can anyone help me to resolve this problem so that it...
I am assuming that it has run two consecutive cycles. I would first clean the machine inside and out. it should drop ice once cleaned, if not then open up the control box and find out which lights are flashing. I am almost certain that once it is cleaned it will drop ice.
Jul 21, 2010 | Hoshizaki Commercial Freezer KM-500MAH
Small production of ice? What should be the normal production of ice?
The way I understand how Hoshizaki machines work, the model number is usually what the unit will produce, in pounds of ice. Their manual states: "Approximate production/ 24 hours @ 70 degrees air/ 50 degrees water (incoming)" So, yours should be producing 450 pounds a day, approimately. Since I can not pin point your exact model, I found one that is close. It states: "Ice Production per cycle: 6.6 pounds, 360 pcs." Again, it is not you exact machine. Their web site does not show this model either. So this is the best info I can get for you. Hope this helps.
Jun 03, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine model KM-250BAF SERVICE MANUAL
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
Jul 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Jul 09, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine with constant beeping every 3 seconds
Most likely(50% of the times) Your Ice machine need a real cleaning. not just run clean cycle with ice machine cleaner. every 6 month call HVAC-R guys - machine will last half time longer if u schedule proper maintenance with them. I have seen It all: people try to call "friend", or someone who "knows" how this machines work. Real clean would take up to 3 hours for people who know what they doing. Here is one of my videos, when 3 beeps - long freeze cycle is not common and all others would offer You to get a new Ice Machine. Bill to the owner was 950$, New Machine 3450$ plus labour to install 600$.
Jun 23, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Freezers Logo
394 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
