Question about Motorola Mobility Blnc Bluetooth Car Kit Portfolio Ihf1000
MOTOROLA IHF 1000
WHEN I PRESS THE BLUE BUTTON IT KEEPS ANSWERING SET UP MENU.I CAN NOT ANSWER OR DIAL OUT TO MAKE A CALL.
    New Friend:
  • 12 Answers
You need to pair the carkit with your phone. Make sure the Bluetooth feature on your phone is set On, then follow the Pairing process outlined in the user manual.
Posted on Jan 09, 2009
I have a uniden dect 1735 not sure how to get it to ring longer before the answering machine comes on
press menu
press the down button to get answer set up press menu
press down button until you get ring time
press side button to increase the no of rings
press menu to set press end to exit
Nov 06, 2017 | Uniden Lands Phones
I have a uniden deft 1735 phone and the red light keeps blinking
it is the vmwi in the global set up
press the menu button
press the down arrow to get to answering set up
keep pressing the down button until you get global set up
press the down button until you get the vmwi word press the menu button
press the down button to change from no to yes
press the menu button then press end
the light will stop flashing
If you get it right , right it down as the nbn sets that light off on a regular basis
Oct 17, 2017 | Uniden Lands Phones
My answering machine (phone line) is picking up when I dial my fax number. How do I set my fax machine up so that it will pick up when I dial the fax number?
Either your fax machine is set to answer on more rings then your answering machine is or you dont have the automatic answer key pushed?
Determine how many rings your answering machine picks up on and then change the number of rings to a lower amount on your fax machine. To change the number of rings before picking up the line, press the "menu" key on the fax machine and use the up and down arrows to scroll until you find the "basic fax set up" or the "advanced set up" areas. I am not sure which one will have the number of rings setting. Try looking in both until you find it.
when you see it press "ok" or "enter" get in and change the amount of rings before answering. call your fax machine to make sure it picks up before your answering machine.
This should solve your problem.
Mar 21, 2011 | Office Equipment & Supplies
Have problem changing auto answer to longer than 3 rings
Press and hold the SET button to enter the change mode. The unit announces the current time and day. Press SET repeatedly until the unit announces the rings to answer. Press and release NEXT or PREVIOUS until the unit announces the correct number of rings for the answerer to pick up. Once the rings to answer is set, press SET to enter the incoming message length menu.
If you need a manual, you can download one here.
Oct 31, 2010 | GE 29868GE1 Digital Answering Machine
Answering maching keeps flashing CL
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day/check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on the base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause to confirm the setting.
Sep 26, 2009 | GE 25952 Cordless Phone
Answering machine keeps flashing CL
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day/check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause button to confirm the setting.
Sep 26, 2009 | Uniden Cordless Phone
Number of Rings, I want to reduce the number of rings
Press and hold STOP/SET button for two seconds to access the set-up menu. Press STOP/SET to continue. Press STOP/SET over and over until the Machine says "Rings to Answer". To set the rings to answer just press NEXT or PREVIOUS to select how many rings you would like. Toll Saver option answers after 5 rings unless you already have a message, in that case it will answer after 2 rings. After you hear the option you like, Press STOP/SET button to store it. Now just press STOP/SET over and over until you get to the end of options, it should beep when you get there. Once you get to the end the machine will announce all the settings for review.
Aug 13, 2009 | GE 29878GE1 Digital Answering Machine
How do you set the time and date? Thanks
Hi!
First of all you need to set the Language which allows you to set the answer in either English or in Spanish voice menu mode. Once the language is set, all voice menu, including the ones used in Remote access mode, will be switched to the selected language.
1. Press and hold the STOP/SET button for two seconds, then release to access the set-up menu.
2. The answering machine announces, "For English, press NEXT, press SET to continue (in English). Para espanol, oprima PREVIO, oprima PROGRAMAR para continuar (in Spanish)".
3. Press NEXT, answerer enters English voice menu mode. If PREVIOUS is pressed, answerer enters Spanish voice menu mode. If SET is pressed, answerer remains in the current language mode. In any case, the answerer enters to the TIME/DAY menu.
NOTE: Language can only be set when the user is in physical access of the unit. When you are running in Remote Access mode, the language cannot be changed and will remain in the language you’ve previously set.10
Setting the Time/Day : This setting allows you to set the current time and day for the Time/Day stamp attached to each message.
Hour : 1. When you have completed setting the Language, the unit will enter the TIME/DAY menu. The answering system announces, "Time (the current time and day setting) To set hour, press next...press set to continue."
2. To change the hour, press and release the NEXT or PREVIOUS button and the answering system announces an hour, such as "12am, 1am, 2am," or "12am, 11pm, 10pm."
3. After choosing the hour, press and release the STOP/SET button to store the hour. The answering system enters the Minute menu.
Minutes : 1. The answering system announces, "(the current minutes setting). To set minutes, press next...press set to continue."
2. To change the minutes, press and release the NEXT or PREVIOUS button, and the answering system announces a minute such as "1, 2, 3" or "59, 58, 57."
3. After choosing the minute, press and release the STOP/SET button to store the minute. The answering system enters the Day menu.
Range of Settings
Time
Hour 12 a.m. - 11 p.m.
Minute 0 - 59
Day Sunday - Monday
Rings 2,3,4,5 toll saverto Answer
Message time 1,2,3,4, minutes
Security 0 - 9, 0 - 9, 0 - 9Code
Default Settings
Time 12 a.m. Sunday
Rings to Answer 4
Message time 2
Security Code 12311
Day
1. The answering system announces, "(the current day setting) To set day, press next...press set to continue."
2. To change the day, press and release the NEXT or PREVIOUS button, and the answering system announces a day, such as "Sunday, Monday" or "Sunday, Saturday."
3. After choosing a day, press and release the STOP/SET button to store the day. The answering system enters the Rings to Answer menu.
Thanks for using FixYa and do rate the solution as Fixya, if found helpful.
Thanks
Rylee
Apr 06, 2009 | GE Telephone
I need to set the rings
Rings to Answer:
THIS SETTING ALLOWS YOU TO SELECT THE NUMBER OF RINGS BEFORE THE UNIT ANSWERS A CALL.
1. The unit announces, "Rings to Answer (the current rings to answer setting). To set rings to answer press NEXT. Press SET to continue.
2. To chantge the rings to answer, press and relase the NEXt OR GREETING/PREVIOUS button and the unit announces a number, such as "2,3,4," or "2, toll saver, 5."
3. After choosing a number, press and release the STOP/SET button to store the rings to answer. The unit confirms the setting and enters Message Length menu.
Taken directly from the instruction booklet that came with my GE 29888GE1 instructions.
Hope it works for you ! jp
Mar 02, 2009 | GE 29888GE1 Digital Answering Machine
No dial tone on my handset
when the phone rings just pick up the hand set and answer
if that doesn't work press the talk/answer button and answer
Oct 05, 2017 | GE 21008GE2 Dual-Handset Cordless...
Motorola Mobility Blnc Bluetooth Car Kit Portfolio Ihf1000 Logo
295 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
