Question about Samsung ML 1450 Laser Printer
Samsung ML-1450 printer
Every time I print, there is a shadow further down the page of what I am printing and general black roller marks. I have tried cleaning the roller inside with some wipes but this makes no difference at all. The print quality apart from this is fine and the writing is all dark enough but all the prints look very messy because of this.
  • 691 Answers
Sounds like your PCU is starting to fail. There is a cleaner roller that removes any remained toner and this could be shot. Try replacing the PCU. If this makes no difference it could be the fuser though this si less likely.
Posted on May 23, 2007
  • Asim
    Asim Apr 13, 2014
    @Inky Fingers can u please explain PCU. I have the same problem as mentioned above.
  • Inky Fingers
    Inky Fingers Apr 13, 2014
    PCU - photo conductor unit. The cartridge you slide in and out that helps create the image
The printed page have shadows of the printed document
Dirty upper fuser roller,or drum cleaning blade is defective.
Oct 09, 2013 | Samsung ML 1710 Laser Printer
Samsung CLP-310 printer shadow printing on second half of page
I would check that the tension between your fusing rollers is ok as the toner will come off the paper and than return back to paper on its next revolution causing a faint image further down the page
May 19, 2012 | Samsung CLP 310 Laser Printer
Samsung ML-2010 Mono Laser Printer leaves unwanted marks on page.
if older printer or well used printer (All laser printers if they have print quality issues - it is mostly either the toner or the fuser). the only way to tell is get (borrow) a toner and see if problem is the same or remove the fuser (the hot thing in the printer) and see if the "ironing" unit or fuser rollers are dirty or worn out or scratched
Mar 01, 2009 | Office Equipment & Supplies
Ink trail
the trail is informing you, it is time for a new toner cartirdge and cleaning.
Feb 11, 2009 | Samsung ML 1450 Laser Printer
Samsung ML-1450 "Time out" error
I would try to reinstall the drivers for this printer and make sure it is your default or selected printer. It sounds like the drivers were changed or corrupt. Any new software install may of done this. Also try to let the printer be unpluged from power for 24 hours.
Jan 08, 2009 | Samsung ML-1450 (Open Box) Printer
Samsung ml-2010 printer prints vertical lines on the page
it may due to scearch on roller. check the roller for any scearch mark.
Dec 23, 2008 | Samsung ML 2010 Laser Printer
Samsung ml 1450 printing problem
either paper is stuck in it somwhere, your carts are **** or the fuser is worn out.
Dec 17, 2008 | Samsung ML 1450 Laser Printer
Pulls 2 sheets every time
Drive clutch of the paper pickup roller. It sticks.
Dec 05, 2017 | Samsung ML-1450 (Open Box) Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Samsung ML 1450 Laser Printer Logo
279 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
