Question about Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive
Vauxhall combo van 2003 ex post-office - curtesy lights
Curtesy lights not working and drivers side headlight not working.
Bulb ok.
    New Friend:
  • 76 Answers
The head light i dont know but the indicators i can help with, on the right hand side under the bonet, behind the metal panel, there is a black box unsrew it be carefull and have the key ready as the alarm will go off change the indicator relay the lid of the box will tell u which one it is thy should now work thanks jezza
Posted on Jul 24, 2009
How do I switch on the running board curtesy lights
You need to check the connector to the lights, it may have not been connected properly and has worked loose.
Feb 16, 2017 | Kia Sportage Cars & Trucks
Fuse for radio/interior light on 2006 Chevrolet Matiz
look under the dash by the drivers side should be on the sidewall
Sep 23, 2014 | Cars & Trucks
The curtesy fuse blew in my 1986 celebrity now even with a new fuse in the dash lights won't come on when the headlights are on and the radio don't come on the horn don't work and with the headlights...
that sounds like there maybe damaged wires or that there is a wiring fault. the new fuse you put in wasn't a bigger fuse then it is meant to have in it is it? cause if so instead of the fuse blowing the wires may melt together and damage parts or catch on fire etc.
Mar 19, 2011 | 1990 Chevrolet Celebrity
MY LOW BEAM HEAD LIGHTS AND INTERIOR CURTESY LIGHTS DO NOT WORK
on head light switch check for 12 volts on black/yellow wire. if missing check fuse and wire to fuse box. IF there check red/yellow for same. IF missing on red/yellow suspect defective light switch.
Feb 16, 2011 | 1965 Ford Mustang
Ex post office combo van need to change rear door lock to central
Hi Bernard, try this http://www.vauxhallownersnetwork.co.uk/showthread.php?141866-Ex-Royal-Mail-Combo-Van-%28rear-doors-opening%29&highlight=convert+ex+post+office+combo+rear+door+loack+to+central
Apr 05, 2009 | Enlight Combo (5601908) (Beige) (5601908)...
Vauxhall combo van, the spanner light comes on and stays on when ignition is switched on, and the mileage stays illuminated at all times even when the key is removed, just bought van any clues, drives well...
Can mean many things, automatic gearbox, emissions problems and if it flashes, it is an immobilizer fault. The car can be driven, if running ok but the engine management system should be checked ASAP. You will need EOBD diagnostic equipment to find cause. vauxhall can check this 4 u but it will cost u £47 unfortuanely but 4 that price u can get the diagnostic reader ur self the port is under the ash tray or the cover below the hand brakeRAC.htm">http://www.argos.co.uk/static/Product/partNumber/7402742/Trail/searchtext>RAC.htm
Mar 19, 2009 | 2005 GMC Sierra
Removing a speed limiter from a vauxhall combo cdti van
The speed-limiter is likely to be enabled via the ECU. Removing the limiter is a five-minute job if you have access to the GM Tech 2 electronic management/diagnostic tool.
If the van is yours then there's no legal requirement for the limiter. You could just book it in at a Vauxhall dealer for the limiter to be removed. They may charge you for an hour's labour though. Still worth doing in my opinion.
Jan 25, 2009 | 2005 GMC Sierra
1992 Buick Lesabre - heater won't cut off, even with ignition off
There has to be a positive wire making contact with the blower wiring. And if it still runs while the car is off, then it could only be a handfull that have power while the car is off. Like the cigarette lighter wiring, headlight switch wiring, curtesy lighting, hazards. Can also be under the hood, hood light ( if you have one) whether or not it works. I sincerely hope that this could be of some help to you. Good luck and best wishes.
Jan 15, 2009 | 1992 Buick LeSabre
Turn signal
Go to your local NAPA auto parts store and get replacement tail lights circuit boards. This should solve the problem. I did for my daughters van.
Dec 08, 2008 | 2003 Pontiac Montana
Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive Logo
698 people viewed this question
Top Enlight Computers & Internet Experts
gaucherre
Larry Maranto
Jerry Umali
Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
