Question about Candy 17 in. CS455 Built-in Dishwasher
Candy dishwasher not working
Hello, we have a Candy dishwasher which was working fine until this morning. Now the light flashes on 3 hour delayed start and whichever of the buttons is pressed all the machine does is emit a single bleep.
3 Suggested Answers
  • 4 Answers
SOURCE: Candy dishwasher CDl 1012/2-80, program stuck?
Hi Derek if its only been used about as you say ten times it will stil be under gaurantee,just call the supplier and have them solve the problem for you mate it sounds as if the program selector is faulty as it is all eletronic programming and could even be a faulty circuit board.
hope this helps
regards JL
Posted on Oct 04, 2009
  • 3247 Answers
SOURCE: I have a candy cdi
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Posted on Oct 11, 2010
Long cycles
Hello Shawn, thank you for your question!
If your dishwasher is taking too long to complete a cycle, first you need to make sure the water is 120F at the sink. If water is less than 120F it causes a delay in the performance and advancement of the timer until proper water temperature is reached. Run the sink to its hottest point, start a "pots and pans wash cycle". If that cycle runs over 4 hours, then I recommend reaching out to a service technician since more than likely the issue lies with the control board. If it runs under 4 hours it is possibly fine, it is only heat delays causing it to run so long.
Hope this helps!
Dec 25, 2013 | Frigidaire 24 in. FDB1050RE Built-in...
Does this dishwasher have a lock button?
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
Oct 13, 2012 | Electrolux EWDW6505GS Fully Integrated...
Candy CDI4545 turn off delay start
Press the key to set the delay start time.This dishwasher can be delayed to start for 1 to 24 hours,and the display window beside the delay key can indicate the remaining time. If you want to cancel the delay start, just press the delay key to make the remaining time become 0.
Dado
May 17, 2012 | Candy CDI4545 Builtin Dishwasher
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Four hour delay light flashing
I have a kenmore elite dishwasher and the 6hour delay light is flashing and no other buttons work when I push them.. whats wrong?
Apr 11, 2009 | Kenmore Dishwashers
Maytag dishwasher error code "1H" MWB6601AWB
The 1 H is not a fault code it is the delay time of one hour.
May 10, 2008 | Dishwashers
Won't start
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Jan 13, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Candy 17 in. CS455 Built-in Dishwasher Logo
Top Candy Dishwashers Experts
Charles T Nevin
Charles T Nevin
 Evgeniy_Getz
Evgeniy_Getz
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
