Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Message on vista that disc is full (it isnt)
I get a pop up message on windows vista that no space on hard disc, despite fact that have 500gb of memeory and the computer is nearly new. Also message that back up has failed. Windows suggests a solution, but when tried it does not work. Any ideas. Could it be the hardware?
  • 69 Answers
This article may help. Vista apparently likes to not add an upper limit to its System Restore function... but only sometimes.
Posted on Jan 02, 2009
I have a Verbatim Clon 500GB external hard drive which only holds 4.65 GB; why??
Windows 7Might not be formatted correctly. Check Disc Management under Administrative tools. This will give the true size including space that has not assigned as a partition.
Aug 28, 2012 | Verbatim Computers & Internet
Recieve error message that computer is running low on memory
Hi liciasol,
I see that you system is running low on memory, This can be that you have files in the Hard Drive that almost reach your Hard Drive maximum capacity.
to check you concern we will need to find out what files you have first in your Machine.
  • Check to see if you have programs that you have installed on the machine that you do no use anymore and uninstall it.
  • If there are no files on the machine that need to be remove and you Hard Drive space it taken up by something then we can try and free space from you Hard Drive by doing a Disc Cleanup on your system.
  • To do a Disc Cleanup, click on Start then All Programs, click on Accessories, under Accessories click on System tools then click on Disc Cleanup.
  • A screen should pop up asking you to select a drive letter that you want Disc Cleanup to free space on select the drive letter where windows is installed normally that should be Local Disc C:
  • Once you've selected the drive to free up space on you will see a window Disc Cleanup for (C:) and in the list will be system services or files to delete that take up space on your Hard Drive on the right of each will be Increments of disc space being consumed by each put a check on them except for those that have 0 on it then click on next or OK then a box should pop up Disc Cleanup asking you if you are sure that you want to do Disc Cleanup just click on YES it will start doing Disc Cleanup on your system.
  • If this did not correct fix your concern then I assume the you possibly have Windows Vista on you system.
  • We can try decrease the space the Shadowstorage of VISTA system restore from your machine this is known to take up disc space on the Hard Drive.
  • To perform the said procedure above follow steps below .
  • Click on Start then All Programs, Accessories, right click on Command Prompt and select run as administrator.
  • The Command Prompt window will appear, a black screen with a blinking cursor.
  • Once in the Command Prompt type in vssadmin resize shadowstorage /on=c: /for=c: /maxsize 1gb then press enter once you should get confirmation that the Shadow storage has been resized.
After Resizing the Shadowstorage type exit then enter this will close the Command Prompt window.
Restart your Computer then check your Hard Disc space again to see if any of the disc space has been recovered or free'd on your Hard Drive.
Note: also check if there are backed up files that possible you may have created that you have not burned on a dvd yet, and uninstall unnecessary documents and files from the machine or back up any pictures and videos that you may have on the machine.
I hope that this will be of help regarding you concern, have a nice day.
mvincentc
Apr 13, 2011 | Dell Vostro 1720 (bqcwd1z) PC Notebook
I have a toshiba P205-S6267 laptop with windows vista it had a 120 Gigabyte drive out of the box I installed a 500GB hard drive wastold that this would make the motherboard crash or operating system...
The "worst" that could happen would be that the motherboard would either:
* not recognize/support the "large" disk-drive at all,
* would only be able to access "part" of the disk-space, e.g., the first 128GB or 256GB or 512GB of disk-space.
However, those possibilities only occurred with "older" motherboards.
Given the specifications for your computer: http://cdgenp01.csd.toshiba.com/content/product/pdf_files/detailed_specs/satellite_P205-S6267.pdf
and the fact that Microsoft Vista is pre-installed, you must have a "recent" motherboard, and it will support any serial-ATA disk-drive (500GB, 1TB, 2TB, ... ) that you can afford to purchase.
Nov 07, 2010 | Computers & Internet
Windows vista states insufficient space on Maxtor One Touch drive
You could check that the backup software settings are pointing to the correct drive. (I've made this mistake before).
Nov 03, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
Not recognised by computer
You gotta partition it first. http://windowshelp.microsoft.com/Windows/en-US/help/d9a4d35e-efdf-406c-a049-0860180129a71033.mspx
Except don't format the ones that already have a Letter (or u screwed urself there)
Sep 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Disc d is almost full. Processing is so slow. How do I free-up space on d?
Defrag, Dis Cleanup ,removing unwanted software,buy another har drive,partionise your hard drive.
Hope this helps if you need more please post.
Apr 17, 2009 | Microsoft Windows Vista Home Premium...
Low disc space
That means that your hard drive is full and it would be best if you transfer some or delete some files.
Mar 26, 2009 | Microsoft Windows Vista Home Basic for PC
Seagate 320GB will not accept a 5GB file despite ample space
First of all HI :)
I posted this on your other thead as well but for some reason it is not getting through. The main problem you have is that the file system of your hard drive is FAT32 not NTFS. You need to change it to NTFS in order to work. Here is how.
>> Copy all your data (the 50+GB you used) on to another hard drive
>> Now from My Computer
>> RIGHT CLICK
>> CHOOSE FORMAT
>> CHOOSE NTFS FILING SYSTEM
>> instead of FAT32 and
>> give your hard drive a nice full FORMAT
This will take a while and WARNING you will LOSE all your DATA so DOUBLE CHECK BEFORE YOU START THAT YOU COPIED EVERYTHING.
Hope that this Fixya Helps you :) With reference to the you do not have permission message it means that you are not logged in as administrator. Best solution is to clean it up on a computer on which you are the administrator to make full use of it.
Best Regards
(please take some time to rate solution thanks)
Jan 07, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
