Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis Washer, model MDG6200AWW
My machine stops at the "rinse" cycle after it fills with water; motor hums and timer audibly clicks but does not advance. any ideas? Thanks. Phil
  • 1 more comment
  • pcglaw Jan 05, 2009
    I tried to make an appointment to have the washer serviced; the man from the repair company said "it sounds like you need a timer; are you sure you want someone to come?"... I took the hint and bought a timer at a local appliance parts store and put it in myself after the I found the Maytag Atlantis service manual on line. It works like new now and I saved myself about $120.00. Perhaps yours is the same problem. But if your washer is new it should be covered under the warranty.
  • Anonymous Mar 15, 2014
    It fills with water but afterwards it just hums
  • Anonymous Mar 18, 2014
    maytag washer fills with water then the timer keeps moving until the motor tries to come on, but it just hums then shuts off. it gives off a burnt smell.
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Posted on Jan 04, 2009
Washer stops before rinse cycle
Check the water level sensor.
Nov 25, 2013 | Maytag Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
It wont complete cycle and empty the water just hums for a while and then turns its self off
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Water not filling in tub washer spins,
It sounds as if the timer has failed internally. Spinning on each setting means the motor is not reversing and that reverse function is controlled by the timer itself. It would never fill if it is stuck in spin unless you select rinse and depending on cycle it can inject water in the spin during the final rinse. If your machine does this normally see if it injects water. If it does inject water at that point I am 95 % sure your timer is the problem.
Jan 11, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Machine stops at rinse cycle and hums
check the setting of the water temp for the rinse cycle. If one of your water supply valves is closed (HOT/COLD) the tub cannot fill with the proper water temp selected. The hum noise you are reporting is associated with the fill solenoid valve located in back of the machine.
Also, I have found the problem to be the screen located in the fill valve clogged with rust and water deposites. Disconnect both water lines and verify the water supply is not restricted.
Hope this helps..
If not, a more thural description of the problem may reveal more clues to assist in troubleshooting.
Thanks and good luck...
Apr 26, 2009 | General Electric Clothes Washer Timer -...
Maytag Atlantis MAV6000 Top Load Washer Logo
373 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
