Question about Apple MA128GA Remote Control
Apple Remote Control
I've just bought an Apple Remote and have replaced the battery but it is still not working. I'm trying to get it to work with an iPod Nano 3rd generation. The manuals at Apple have not helped can you?
    Problem Solver:
  • 7 Answers
To my knowledge the Apple Remote does not connect directly to any iPod (this might be different for the iPhone or iPod touch). You need to have the Apple Universal Dock to use the remote control.
Posted on Apr 26, 2009
Replacement remote control not working on TV
What is the brand name of remote control you bought?
Jan 21, 2013 | Televison & Video
Sony LC-C3234U Remote Problem
Check this after replacing the the batteries of the remote control with fresh ones. If the problem still persists, the remote control and the infrared sensor inside your TV [both] should be checked.
Dec 09, 2012 | Sharp Televison & Video
Just bought a Toshiba refurbished DVD/VCR player. The remote doesn't work at all. I've doublechecked the NEW batteries and tried a tip of pushing EVERY button with the batteries out. Any ideas
1) the batteries will be the same type and full charged
2) clean the contacts battery from dirty, dust, oxide or corrosion
3) retight the spring contacts battery with pliers for a GOOD contacts
4) open the remote.control and clean the keypads switch, from dirty, dust, oxide, Open contacts, or Bad contacts. they emite a good signal infrared from SYScon transmi vs Syscon receiver.
see the block diagram. If doesnot resolve the problem go to the repair shop TV for fix it.
God bless you
Jul 31, 2012 | Toshiba Televison & Video
My Sony RM V301 remote control code for my panasonic tv/vcr combo isn't working i've tried 018, 016, 017, 007, 049, 067 are there any others?
go www.fitness.manualsonline.com or www.remotecodelist.com
and follow the instruction manual procedure
1) tight the spring contacts with pliers
2) clean the batteries contacts
3) change new batteries
4) Resolder wires contact batteries and proof again. Otherwise you must go to repair shop
God bless you
May 10, 2012 | Sony (RM-V301) Remote Control
I've just bought a new remote control as the original isn't working. Is there a set up routine that one has to follow?
If you bought exactly the same remote, then it should work without doing anything (just make sure it has batteries) if you bought a Universal Remote, you should input the codes for Panasonic first.
Sep 24, 2011 | Panasonic DMR-E55 DVD Recorder
My Phillips HTS3400/37 Home Theater System came with a remote control, as usual, but it just has stoped working.. I've been trying to make it work by replacing the batteries and it still appears to be...
Try this first on the original remote. Insert the batteries backward and make sure that they make contact with the terminals in the remote control(stick a piece of metal in there to make sure all the posts make contact), then take them off and install them correctly and see if it works, it's a long shot but i've had some luck using this method. now, for the question regarding if the new remote will work, well, i couldn't find the correct code for your receiver using the RCA universal control. The receiver brand(Phillips) is not listed so it probably won't. Here's the RCA control's codes. Just copy and paste the link. http://www.remotecodelist.com/remotes/rca/rca_rcu404.html
Aug 23, 2011 | Televison & Video
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
Ipod will not charge
If the ipod is still working then the charger is the problem try getting a new one or if you are able to take it back for a new one try that
Oct 26, 2009 | Apple iPod nano
Apple MA128GA Remote Control Logo
559 people viewed this question
Top Apple Televison & Video Experts
Carlos L. Burgos
Carlos L. Burgos
Jim Goldsmith
Jim Goldsmith
Are you an Apple Televison and Video Expert? Answer questions, earn points and help others
