Question about Olympus Stylus / mju 1040 Digital Camera
The screen stays black
When i turn my olympus 1040 on the menu buttons light up however the screen stays black, it then makes two short noises, then once more and turns itself of.
please help x
  • Anonymous May 14, 2009
    Did u solve this problem? How?
It could mean your battery or memory card is not inserted properly.. Mine also does this when my battery is low.
Posted on Oct 25, 2009
Why does the screen stay black when camera is turned on?
Did you try to press the display button several times? Most of the time you can cycle through different views on the display, with different information during record mode. One is display off.
Jun 18, 2014 | Olympus FE-340 Digital Camera
My olympus fe was dropped when the lens was closed, and everytime i turn it on the lens gets stuck out and makes a vibrating noise, than stops. sometimes it'll show me my pictures that i have on the camera...
Since a replacement is available for £46 on Amazon, and the repair charge would probably be at least that if not more, i should just replace it. And this time, don't drop it.
Jun 10, 2017 | Olympus FE-220 Digital Camera
My olympus FE-280 will not turn on. I put in a fully charged battery and when I press the power button the light on the back blinks red and the lens opens and closes about four times before completely...
There are many sides to the fault but it seems that you have a serious one. The camera needs to be opend to confirm the fault and so it needs experienced hands. The possible fault could be failure of the electronics, maybe the shuter drive, the lens drive or maybe the flash section. Assuming that your battery is good the fault can be related to a shorting or power related malfunctioning. Disconnection of one of the sectionmay be needed to confirm but an access to the camera electronics is a very sensitive job . so take help and hope the fault is economical. Good day
Aug 10, 2010 | Olympus FE-280 Digital Camera
My FE-230 is only 2 years old and will not turn on/off properly
This sounds remarkedly like a camera that has been dropped. Even by someone else! The odd noise it the can[mera trying to set the lens up and failing. The black screen is because the lens has not travelled the distance etc. multiple problems !
it needs a complete overhaul and may well be cheaper to ditch it and get a new camera
Jul 30, 2009 | Olympus FE-230 Digital Camera
Acer One pc notebook black screen?!
That is a problem of BIOS. U need to reset your BIOS.
Acer Aspire One BIOS Recovery
The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
May 07, 2009 | Acer Aspire One PC Notebook
Error 1203
hi..
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Olympus FE-220 will not let me take pictures
I am having same problem. View is black/blank, digital shutter appears to work but not photo taken. Returning camera to dealer as this appears to be an Olympus manufacturer error.
Jun 13, 2008 | Olympus FE-220 Digital Camera
Cant take picture
The lens assembly and or microprocessor has failed.
Contact Olympus
Good luck, Paul
Jun 06, 2008 | Olympus FE-230 Digital Camera
Olympus Stylus / mju 1040 Digital Camera Logo
324 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
