Laptop doesn't work on battery after charging
Hello, this is a Packard-Bell igo 3453, a Nec Versa M300 clone. It runs well on AC power, it charges battery, and ''can'' run on battery, but :
- When running on battery, if CPU temperature reach 60°C the power LED shuts down, and few seconds later all the system shuts down.
- When running on AC with a charged battery inside, if I unplug the power jack, the power LED shuts down, and a few seconds later all the system shuts down. It's impossible to disconnect power while working.
- When powering up on battery, if the battery has been in charge before (even for one second), the power LED lights on for few seconds, then shuts down, and a few seconds later all the system shuts down.
- To run on battery after it has been charged (even one second), I need to remove and reinsert the battery, and it then run well until it reaches the fatal temperature.
This laptop had been dropped-down 5 years ago, it then had overheating problems and was sent to Packard-Bell for repair. Since this event (drop-down or repair, I don't know) it never worked on battery. I have two batteries and can say it's not relative to them. It's not OS relative as it happens also in BIOS setup.
I believe something is broken in power management hardware, but got no idea what it is. I recently repaired the loosy power jack, and feel like reopening it in few weeks. I would be glad to get help preparing this manipulation.
Thanks !
  • edada Jan 03, 2009
    Hello knotbeerdan, when monitoring cpu temperature while doing hard calculation, I notice the fan start running at 60°C (140°F), and then temperature don't climb over 67°C (153°F). When I stop calculations the temperature gets down really fast. So I believe heat transfer is good.
    There's no temperature settings in BIOS setup. Anyway 60°C seems way too low, the security shutdown temp should be around 100°C ? That's why I'm thinking of a hardware failure, maybe a security circuit that trigger for no good reason.
    The CPU is an Athlon XP 1500.
    On AC power it does not shut down when getting hot.
    Master:
  • 413 Answers
If you are planning to open the notebook make sure the cpu cooler is mounted flush and has the most possible amount of contact with the cpu for heat transfer. I don't know about yours but normally in bios you can set a fatal temperature shutdown. Try to look up what cpu you have (when you open the case) and see if maybe the temperature is set too low. Then you would be able to reset the temperature to something higher if possible and this would solve the overheating shutdown problem.
Posted on Jan 02, 2009
Flashing blue land orange light
One possibility is that the replacement battery, the replacement AC adapter, or both are defective.
Dec 03, 2013 | Packard Bell Computers & Internet
I need a new battery for my igo 3000 series laptop
hello !
for battery you have to contact bell packard center to buy a new battery with warranty
peace
May 17, 2011 | Packard Bell Computers & Internet
Packard bell-VERSA E400 iGO 4000 Series. I am searching battery for above laptop.
Try this link: http://www.batteries-trade.co.uk/index.php/cPath/6_170?gclid=CK7bg87t0aICFUcA4wodvxD6yQ
Jul 03, 2010 | NEC Versa SX Notebook
Hello, i have a Packard bell igo , that when i try to boot 3 lights on the bottom of the screen and the cd keeps trying to run and also the screen is flicking , what should be the problem ?
Packard bell igo, is a notebook..what model is it. if the screen starts flickering on the go, then you could be having a flex problem or motherboard problem. but if it loads and later flickers, then you should check the installation. please explain a little bit more if this doesn't help.
Regards
Mar 04, 2010 | Computers & Internet
My laptop nec versa stopped to work suddenly. I
A questions are to be asked here. Does the laptop work when connected to AC power supply? If yes does the battery charge when connected to AC? If yes does this turning off happen when running on battery too? Please answer these questions so that I can help you with the diagnosis.
Regards,
Sai.
Nov 21, 2009 | NEC Versa VX Notebook
Packard bell versa e400 power only comes on when connected by the mains adapter. it has a battery in it but will not power up from it.please help
Hi there.
Basically the batteries dead and needs to be replaced!!
This is a common problem right across the board with all laptops, in some cases its the powerboard on the motherboard itself which won't charge any battery new or old.
To troubleshoot it you will need another battery to test with it.
Good luck
Jun 12, 2009 | NEC Versa SX Notebook
Hi, I have the NEC Versa M300 laptop. Today I tried to run it from the battery and it is dead. I have attached the mains and it works fine. The amber battery charge light came on for about 1 min then went...
This problem has been solved. After testing the output voltage on the main board and then the battery, it seems that the battery just gave up. It went from giving at least a 2hour life, to zero overnight without any other indiction of a problem.
Nov 16, 2008 | NEC Computers & Internet
POWER SUPPLY
bad abttery buy new one 1st even tho says charge dont have eneghf power in it to suport it all ok buy new try that 1st
Jan 28, 2008 | Packard Bell Easy One Silver 2101 Notebook
Power source
Most laptop batteries die - that is, fail to hold a charge, after a few years use, and have to be replaced. That is the probably the reason for your problem.
Packard Bell IGo 4000 series Versa E400
If you cannot see the speaker icon in the taskbar, click on Start > Control Panel > Sounds and Audio Devices and tick place icon in the taskbar. That's if a driver has been installed for your sound device which is a creative sounblaster I think.
Jan 08, 2008 | NEC Versa SX Notebook
Computers & Internet Logo
377 people viewed this question
David Payne
David Payne
