Question about Cobra 29 LTD CB Radio
CB Base Station picking up electrical interference
I have my CB all installed and ready to go as a base station here at my house. But all I get is electrical noise when powered on and I have to turn the squelch way up high just to get it to go away. I've done radio checks and I can't pick the radio up from my car. I even tried my handheld CB and sat right next to it and received a very weak signal. I have even moved the base station a few times to see if that would work. This is a brand new radio which replaced a broken one (actually broken for sometime) but I never had this issue in the past. Now I have it connected via DC-AC adapter, could this possibly be the cause?
  • Dutyacx May 11, 2010
    If you can't receive the signal from your car and it's very weak when you sit right beside it, I'm afraid you got a bad radio. Maybe DOA ?
    However, make 100% sure the antenna has a good connection with the radio and it's freely installed.
  • Kevin May 11, 2010
    Depending on the DC-AC adapter you are using, it could be the noise source.  Is it made for you radio, or are you using something that has the right output voltage for you radio? Can you run the radio off of a battery?  If you can, see if the noise is still there with the AC-DC adapter plugged in the wall, and with it not plugged in.  Did your handheld pick up any noise when you were next to the base radio?
  • 32 Answers
I dont know what AC DC adator your using. you should look into a 12V power supply. or plugging that into a RF canceling power strip, like a monster power strip. TV's that are on or other appliances may cause high noise levels on the CB, make sure your coax is good, your antennas good, and all jumpers are good. its hard to tell with out looking at it, but do a quick once over of the system.... you are using a base antenna right? if not you need to create radials for a mobile you plan on using for a base.
Make sure the connectors on the coax are all on right, this causes problems a lot of the time. sometimes even brand new coax have bad connectors installed.
Posted on Jan 11, 2009
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
I have a KX-TG6700 base station and 4 Handsets. When I have been calling on the handsets I have recently found that there is static on the line. Later I realized that there is problem with the DTMF being...
The KX-TG6700 manual at: http://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdfhttp://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdf
States:
For best performance
Base unit location/avoiding noise
The base unit and other compatible
Panasonic units use radio waves to
communicate with each other.
For maximum distance and noise-free
operation, we recommend the following:
LPlacing the product away from electrical
appliances.
LPlacing the base unit in a HIGH and
CENTRAL location with no obstructions
such as walls.
LRaising the antennas vertically.
LIf you use the handset near a microwave
oven which is being used, noise may be
heard. Move away from the microwave
oven and closer to the base unit.
LIf you use the handset near another
cordless phone’s base unit, noise may
be heard. Move away from the other
cordless phone’s base unit and closer to
your base unit.
Have you considered all these points?
Is there a way you can move the base station to another location in your house to see if the problem get better? I don't beleive your base station is faulty, I suspect interference from something.
I don't think the 2.4GHz set is causing any issues, but you never know, try unplugged it for a while to investigate.
If you do determine that the base station is faulty there probably isn't many options to get it repair other than sending it to Panasonic. May be cheaper to buy a new base station to go with your extra handsets.
Good Luck!
Mar 14, 2008 | Lands Phones
Replaced batteries, outsid temp. does not display
Jan 05, 2016 | Taylor Measuring Tools & Sensors
Panasonic KX-TCD25AX cordless phone. Why can't it find the base station?
several reasons
too far away from the base station
too much interference between the phone and the base station ( buildings, iron sheeting etc)
the phone is not programmed into the base station memory-- re do the system program where the base station recognizes each phone and sets it's number for identification
May 14, 2015 | Panasonic Lands Phones
Phones always searching for base.
Is the base station too close to another electrical appliance as it could interfere with the signals. Try moving the base station to another location to see if that solves your problem.
Aug 04, 2010 | AT&T 5.8GHz Cordless Phone System with...
I need a manual to base station CB Ranger rci-2990. Can you tell me where to download or purchase this manual. Thanks
http://www.rangerusa.com/websupport.html
http://www.worldwidedx.com/cb-band-cb-radios/18036-manual-rci-2990-a.html
you may find some help with these sites
Sep 24, 2009 | Radio Communications
My house phone keeps saying bs search and wont call out or recive calls
bs meaning of course - Base Station...
There is no link between your cordless set and the base station, hence the message.
I would do what SpencerR stated, try to re-establish the connection via the base station to accept the handsets again.
Have the cordless sets worked before?
It may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless sets, and take out the batteries in the cordless set. Wait for about 15 seconds for all the power to drain out of the sets, and re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link to the cordless sets.
Good luck
May 11, 2009 | Lands Phones
My neighbor's cb radio comes in on several frequencies.
All electronic devices are required to receive unwanted interference but not cause enterference them thats the best answer I can give you. Your neighbor might be operating with greater than 4 watts allowed by the FCC for citizen band transceivers.
Dec 27, 2008 | Uniden Radio Communications
Aerial replacement eu falcon
NOT AT ALL .....IF YOU ARE TALKING ABOUT A BASE STATION ANT.....FIRST GET A GOOD ANT ......GET THE MAST TO PUT IT ON ..1 OR 2 MAST.. YOU MAY WANT TO USE SOME GUIDE WIRES..IT'S A GOOD IDEA......MAKE SURE TO GROUND THE ANT..WITH A LIGHTING ROD THAT GOES INTO THE GROUND.....GET SOME BASE STATION COAX.........GET A SWR METER A CHEAP ONE FROM RADIO SHACK HOOK EVERY THING UP CHECK YOUR MATCH WITH THE METER AND YOUR GOOD TO GO........WHERE YOU PLACE THE ANT ON YOUR HOUSE WILL MAKE A
BIG
DIFFERENCE IN HOW THE ANT WILL PERFORM PICK UP A CB RADIO BOOK @THE LIBRARY OR LOOK INTO ONLINE
Apr 20, 2008 | Radio Communications
Cobra 29 LTD CB Radio Logo
511 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
