Question about LG (GCE8527BB) CD-RW Burner
CD Drive will not read disks
I recently bough an internal LG cd burner. I followed the instructions and installed in correctly (I think). Now when I turn on my computer it cannot read any CDs although the Device manager in Windows says that the device is working properly. Can someone help me?
  • Richard Sowler May 11, 2007
    Sorted it out by installing new firmware.
    President:
  • 2,961 Answers
If you only think youve installed correctly, double check the jumpers on back whether master or slave depending on which ide cable is used and whether there are two devices or one on the ide cable. was the cdrom recognised by windows when it was rebooted after install and automatically installed? check on the device manager on the ide/atapi controllers see if ultra dma is being used.
Posted on May 11, 2007
I'm trying to install a PC-DVD Game to my LG CD-ROM CRD-8521B, It plays CD's but wont play DVD's of any sort. Really need help...
The CD rom is limited to CD's. In order to read a DVD, you will need to install a DVD rom. My suggestion is to get an external DVD Burner - i just bought a Samsung slim external DVD burner that reads / writes CD's and DVD's.
You will have no luck ever reading a dvd in a cd rom.
May 19, 2010 | LG CRD 8521B Internal 52x CD-ROM Drive
How do I Install my LG GCC-4320B
ok take this step to connect the cd 0r dvd drive
To install an external DVD drive:
  1. When purchasing a new drive be sure to understand the many formats available: DVD, DVD+R, DVD-R, DVD+/-R, DVD+/-RW are a few for example. More recent technologies include DVD-DL, HD DVD and Blu-Ray Disc. A decent DVD drive should be able to read and write both "+" and "-" technologies and also support recordable (R) and re-writable (RW) technology. Essentially look for a DVD+/-RW drive if you plan on recording DVD's, or just a plain DVD drive for reading DVD's (movies, games, etc). There are a variety of speeds from 2x-16x for a wide spectrum of users and needs; higher speeds will record faster.
  2. If you have a USB connection on your computer you can use an external drive. The advantage to an exterior drive is that you can use it on other computers as well.
  3. To install an external DVD, just follow the instructions provided with the drive.
To install an internal DVD drive:
  1. Look for a DVD with the letters RW on the box. This is so you can read disks and record them as well. Make sure the speed rating is 16X and that the DVD is dual layer so that it takes care of the latest technology.
  2. Read the instructions that come with the DVD. It may require you to load the provided CD software before installing the DVD player. Leave the disk in your CD ROM player for the rest of the procedure.
  3. Disconnect the power cord from the back of the computer (goes to the wall socket of your house.)
  4. Open the case of the computer.
  5. Locate the hard disk or CD drive. Most have two connections and can only be snapped in place one way. One connection is for data and one for power.
  6. Check to see if your computer mounts the DVD/CD ROM drives from the inside or if they are pushed through the front panel (you may have to remove the plastic panel on some models.)
  7. Carefully remove the plastic “knock-off?? cover on the outside of your computer. Make sure you do this only when you are ready to install the DVD drive.
  8. Slide the DVD drive into an empty compartment or bay. If it’s an older computer you can secure it with screws that come with the DVD drive. Many newer computers have spring clips to secure the drive in place.
  9. Connect the DVD drive to the data cable. The data cable is wide like a ribbon and is also called a ribbon cable and has a red stripe on one side. There are two or three connectors on the data cable. One is connected to the circuit board, one is connected to your CD drive or hard disk and one in the middle (optional third connector) is usually not connected to anything. Use the middle connector for the DVD drive. If your data cable only has two connectors replace it with the one that is generally included with the new drive.
  10. Hook the DVD to the power connector. This is a normal round looking cable. There are usually several power connectors in the computer.
  11. If you don’t have an available power connector, then you can buy a “Y?? connector to hook up to the existing power cable. Unhook the power connector and hook it to one side of the “Y?? and hook the DVD to the other side of the “Y??.
  12. Re-assemble the cover and plug the computer back in.
  13. When you run Windows up it should look for the drivers for the new DVD player and automatically locate and load them from the CD ROM that you left in the CD player from the first step.
thanks
ok bye...........................
Nov 18, 2009 | LG GCC 4320B CD-RW/DVD-ROM Burner
Lg DVD writer can not read DVD but CD . what's the
Dear,
This is a usual issue. You have to replace it. May be issue on DVD encording circute.
Get it replaced....
Oct 17, 2009 | LG 20x8x20 GSA-H55L Super-Multi Disk...
It can't read or burn any data on any empty disks (CD-Rom/DVD)! but it can read any other written disks like: programs , Movies , audio disks , data disks just when I put a blank or Empty disk it seems...
Some CD burners are either "+" or "-" or both "+ -".
That said you will have to check what type of burner you have. Example, you cannot stick a "+" blank cd into a "-" burner, and visa versa.
However, if your cd burner can read and burn both types, you should be okay.
Sep 25, 2009 | LG SecurDisc 8x External Double-Layer DVD...
LG Combo drive HT-DT-ST RW/DVD GCC-4521B can read can't read DVD
hello i was reading the problem you posted and i am getting an instant idea the drive is on the fritz, but is it new and if not how old is it, also did it come factory or did you install it and also what type of pc is it. Robert Alan
Jun 01, 2009 | LG GCC4521B CD-RW/DVD-ROM (Combo) Burner
Disk drive does not recognize or read a disk
you could try removing the drivers from your device manager by going through contol panel or by right-clicking on My Computer and then on the hardware tab. you would find it under cd/dvd rom drives.Just right click and click on uninstall. Then if you dont have your driver disk you might be able to download it from softpedia.com. If you have installed drivers more than once you might be able to roll-back drivers but the best bet would be to just uninstall and re-install the drivers.
Hope this helps
Anarkist
May 04, 2009 | LG GSA-E40L Burner
Not reading any disc
loss of driver, just reinstall supplied driver, if using VISTA go to LG site and get current driver.
Jun 22, 2008 | LG GSA-4160BI (GSA4160BK) DVD±RW Dual...
Help
Since that CD drive is really old, i think that it cannot read the disk properly. I you need to get a newer CD reader/burner.
Jun 01, 2008 | NEC (CDR-502) Internal 6x CD-ROM Drive
DVD does not read Data
try to find the CD-installer it's free when you purchase a combo drive.
Just try to re-install it.
I think that is the only way to make it work correctly.
Apr 12, 2008 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Both drives not recognising disks
Have an LG Super Multi DVD Drive, Model:GSA-4120B.
Won't recognize any disk, CD or DVD and won't play any audio video
Device manager says, it's working properly
Dec 28, 2007 | LG (GDR8164B) Internal DVD Drive
LG (GCE8527BB) CD-RW Burner Logo
55 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
