Question about Bulova Chronograph Watch
Lost instructions for accurist chrono mans watch
This watch has 3 small dials and 3 windows inside main face with hands
    Problem Solver:
  • 9 Answers
It should have a CAL number engraved on the watch back and using this you can find instructions for download at www.accurist.co.uk under the after sales service area and downloads option.
Posted on Jun 18, 2009
Accutime watch in roman numerals, has 3 small circles on inside of the face of the watch . i don't kno what they are for or how to run them?
I'm not familiar with Accutime watches, but it may be that the 3 sub-dials are there just for decoration.
If they're not, then the upper and lower buttons on the right will control the hands on the sub-dials.
Check the following:-
Is there any movement in the buttons when you press them, or do they feel solid as if they are part of the casing?
Do the hands on the sub-dials look as though they are slightly raised or do they look as though they are glued on?
Does pressing either of the buttons cause any of the hands to move?
If pressing the buttons has no effect at all then you can be sure that the sub-dials are decorative only.
If the sub-dial hands do move when you try the above suggestions, then get back in touch for further instructions.
Oct 06, 2016 | The Watches
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
I have a sport watch fossil CH2470. the second hand is not moving, stuck on 12, but everything else works. how do i fix this?
Your watch is Chronograph watch and the big centre seconds hand is for chronograph function only - not day to day seconds counting. Check the small dials and you will see that the small seconds hand is already counting seconds- this small one is seconds counter. To engage chrono hand push the upper push button once. To stop it - push the same button again. to return to zero- push lower button. For users manual use this link: http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html Rate me, please.
Feb 28, 2011 | Fossil Watches
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
I have no instructions 4 my accurist chrono any help please
Most of my repair does'nt have a manual,all i do is to sure that all,the function button is working.then proceed to try all the function to work and observed what is the result.that watch three sitting of the crown by pulling,first pulled little then wind left and right and observed,second half pulled,then wind again third full pulled for hands function.Try this and you find the result. Hope it may help you; Regards VOTIT
Jan 02, 2009 | Watches
Festina 16177 / 8- Tour de France 2005 - second hand not moving
The large sweep hand is not the second hand,it is the 1,100th sec hand on chrono.The second hand during time mode is the small dial at the bottom which should be going round
Jul 22, 2008 | Festina 16177 3 Watch
Watch 3 dials inside face
so its a chrono watch i belive. well sometimes diffrent models require diffrent operations to set up the display.
Perhaps the manual can be found on the internet site of the watches brand.
Mar 17, 2008 | Watches
Its actually for a Cartier W10172T2 Circa 2006
I have the same problem and would be interested if you have received any answers to this problem?
Aug 22, 2007 | Cartier 21 Chronoscaph W10125U2 Wrist...
The watch stops instead of the chrono
On this type of watch the second should not be working unless you are in the chrono mode. The lower dial should be the only indication of the seconds when not in chrono mode. You probably need to have the chrono reset and shown how the functions work. Try a Fossil location they will be able to tell you how to work this watch. It does not sound like this is a major problem.
Dec 03, 2006 | Fossil FS3105 Wrist Watch
Bulova Chronograph Watch Logo
374 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
