Question about Xante Accel-a-Writer 4N Laser Printer
Will Accel-a-writer 4n work running Leopard 10.5.6?
I've got a new MacBook Pro running 10.5.6, and I'm not able to install the Xante printer using the original installation CD. Xante's website doesn't indicate support for Leopard, so I'm wondering if there are any third-party vendors that have the necessary software.
thanks,
Don Hammond
Just download the PPD Installer from here: AW4N_OSX then install the driver. Use System Preferences -> Print and Fax to create new Xante Printer using Default or Apple Talk section of Control Panel.
Posted on Jan 16, 2009
I installed this printer on my mac book pro with leopard. I believe I called the support and they walked me to the download on the website. I remember it was under legacy products. Sorry this may not be much help. But give them a call and they should walk you straight to it.
Posted on Jan 05, 2009
How do I replace a fuser for a Xante Accel-a-Writer 4G?
dear please find back cover and open it found big unit of printer called printer fuser assembly.removed it carefully you need one Philips screw driver,losses the two screw after that you removed screws slide it right side if you stand back of the printer,however after remove the fuser assembly you can installed it new in the Xante 4G printer when you install slide fuser to left side and alignment carefully,hope you understand.
thanks.
Jun 19, 2014 | Xante Accel-a-Writer 4G Laser Printer
We bought a new iMac, running MacOs 10.6. Where can I find a driver for Xante Accel-a-Writer 3N Laser Printer
Go to this link and under Drivers, English select MAC OS X and download the drivers: http://www.xante.com/support/aw3ndn/
Sadly, the application drivers for MAC OS 10.6 are mot supported for this printer.
Feb 10, 2011 | Xante Accel-a-Writer 3N Laser Printer
My Xante Accel-a-Writer is not communicating with my macmini. I understand that OSX 10.6 doesn't support appletalk, and have configured the xante as an LPD printer and entered its IP address. The mac...
First, I would recommend that you connect the Xante Accel-a-Writer to a Windows OS computer (xp/vista). Observe if it will function perfectly. This will determine whether you are doing something wrong or if the problem is from the Xante Accel-a-Writer or if they don't support each other.
You can test the Xante Accel-a-Writer on a friends windows OS computer if you don't have one.
Let me know the out come so that I can direct you further.
Good luck.
Oct 19, 2010 | Office Equipment & Supplies
Xante accel-a-writer 4g for mac OSX 10.6
I haven't checked in a while. Xante told me when I called them that they were not planning to make updates past the current version of the 4G OS X drivers, as the machine was no longer in production. They said the driver should perform adequately on current versions of OS X even though it was not initially designed for them (as they did not exist when the driver was created).
I found this to be untrue in my case. The drivers did not allow me to print consistently from 10.5.8 on an Intel Mac Pro.
My solution was to activate the print server on an Xserve running the Tiger server version of OS X, install the Xante driver there (since it was designed to run on that version of the OS), and now my newer macs can use the printer without issue.
Apr 20, 2010 | Xante Accel-a-Writer 4G Laser Printer
Xante Accel-a-writer 3N Printer Not responding
I just signed up today. Are you still having the responding
issue?
Dec 18, 2008 | Xante Accel-a-Writer 3N Laser Printer
Accel-a-writer 3g for leopard
Yes. If you need the driver here is the link. Just scroll down to operating system and choose Mac OS X. If this takes care of your problem please rate as fixed. Thanks.
http://www.xante.com/support/aw3g/
Apr 03, 2008 | Xante Accel-a-Writer Laser Printer
Slow Printing under Adobe CS3 in OS X 10.4 environment
I had the same issue with 3 users and was able to solve it with a really easy fix. Set the dock to hide itself. I know it sounds weird, but there's a new print progress bar added to the CS3 icons, and that seems to be where the problem is caused. I'm assuming you have an Intel Mac?
Check out the blog post here if you want more info
http://techierambles.blogspot.com/2008/10/illustrator-cs3-printing-issue-status.html
Mar 14, 2008 | Xante Accel-a-Writer 4N Laser Printer
Xante Accel-a-Writer 4N Laser Printer Logo
372 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
