Question about Dryers
Dryer don't heat up
The dryer don't heat up. the heating coils look okey. it does everything but heat.
  • cstack410 Jan 02, 2009
    Same problem here ... everything works but I get no heat!
  • Anonymous Jan 02, 2009
    gas dryer will not fire up . I replaced both coils still no flame
  • 91 Answers
REPL/ THERMAL FUSE
Posted on Jan 03, 2009
Replaced all parts for dryer because of no heat dryer runs drum turns had breaker and wiring going into dryer everything ok still no heat could wires be backwards going to replacement parts?
Electric dryers have as many as three thermal fuses. See if you might have missed one. One next to coils, one next to drum and one near the lint trap at air outlet. All three have different trip settings.
Jan 04, 2016 | Dryers
How do I get to the heating thermostat
I think you can "pop" the top off using a screwdriver.....
It might be the heating coil. Look for breaks in the coil or can use a volt/ohm meter to check it...
Oct 28, 2014 | LG DLE2532W Electric Dryer
Dryer vent was partially obstructed. Cleared out vent, but now the dryer will not heat up on any heat selection. Dryer operates, but just not heating up at all. The appliance is about 3 years old. I...
You have either shorted the breaker or broken the coil. If you check the breaker first, save time. If that isn't it, and you need to replace the coil, be careful that you don't short the coil against the machine itself or you will end up in the same boat.
Good Luck
Joe
Aug 29, 2011 | Dryers
My kenmore elite electric dryer inconsistantly starts to heat and
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
KitchenAid Gas Dryer wont heat everything else
Does the dryer heat at all? turn you dryer on for about 1 minute then open the door, any heat? yes= check to be sure you venting is good and clear. if good then you have 2 common issues i would check first. the thermal fuse could be blown or the gas valve coils could be bad. give me you model number and i can give you more suggestions of what to check and how
Mar 22, 2010 | KitchenAid Dryers
No heat for the dryer, drum turns, breakers good
Check the thermal fuses / temp sensors mounted on the top exetrior of the heating chamber and also the heating element. Both accessible from the rear of the machine.
Nov 08, 2009 | Frigidaire GLER642A Electric Dryer
The dryer does not heat up, it starts and everything, but no heat
Sounds like your problem is with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with a continuity meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
Good Luck,
Hope this helps
Oct 07, 2009 | LG Dryers
Dryers Logo
77 people viewed this question
Top Dryers Experts
