Washing machine wont spin
Hi hope someone can help.my machine indesit omega 1200. wont spin it will wash and drain but just wont spin have u got any ideas? My machine stopped spinning or even turning the motor at all. There is no voltage on either of the two red wires coming to the motor but voltage on one of the black wires. I don't think this is how it should be but tracing the wiring in the harness is too difficult. Which controller terminals control the motor?
  • andyinhawick Jan 02, 2009
    Yes, the brushes seem worn.
    For future reference, where is the water level switch pressure chamber?
    Thanks
       Andy
  • Washing Mach... Master
  • 3,463 Answers
It is unlikely to be the motor faulty, if it will wash but not spin, check the pump filter first to be on the safe side, if that does not solve the prob, then remove motor and check carbon brushes in motor, as this can often be the cause of the prob.
Also check the water level switch pressure chamber for a possible partial blockage, as this can give the same sympyoms.
Plz rate my solution.
Thanks
Posted on Jan 02, 2009
  • Barry Coates
    Barry Coates Jan 02, 2009
    The water level switch chamber is the one with a long thin hose coming fromi t.It is about 3 to 4mm diameter.
Hi, I have and indesit wil1235 1200 and as you do the process to turn it on, the drum spins and then fills up with water but then just stops an every so often will make the draining sound without draining....
Check your drain line. It is more than likely pushed too far down into the drain line causing the machine to siphon water out as its going in.
Jun 02, 2012 | Washing Machines
My indesit front loading wg1432 model washing machine wont do final spin at the end of each programe, the rest of the programe is fine, just when it comes to final spin the dial stops at this point
hello it might not be draining enough water out it has to pump water out before it spins check the pump also the filter if it has 1 hope it helps
regards
shaun
Mar 14, 2011 | Indesit W 123 Front Load Washer
Indesit WDL 126 dryer - at end of cycle not draining or spining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 11, 2011 | Indesit WA 125 Front Load Washer
My washing machine wont drain, so the rinse and spin cycle cannot activate. Please help. Thanks
Hi.
Check drain hose at the back, then access drain pump filter and remove eventual blockage. If that does not fix the problem, a common fault is the pressure switck, try blowing in tube and removing soap.
Read general troubleshooting below:
My washing machine does not drain.
Jun 10, 2010 | Indesit W 123 Front Load Washer
WASHING MACHINE WONT DRAIN OR SPIN
did you get a solution as i now have this problem
Jun 08, 2010 | Washing Machines
Indesit WIDL126UK that never wants to stop!
did you ever get to the root of the problem >}?
mine is doing the same.
gsxr1000rider73@aol.com
Sep 25, 2009 | Washing Machines
Your machine may not be receiving adequate voltage to start. Make sure your machine is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your machine. Also, refrain from using an extension cord to plug your machine in.
Dec 03, 2008 | Indesit W 123 Front Load Washer
Indesit washer dryer 'omega 1200' WDG1295W won't drain!
Sounds like the pump is possibly faulty, or there is a blockage
There should be a removable plastic cover at the bottom front of the m/c, behind this you will see a round plastic cover.
This is the pump filter, unscreit and unblock it if it is full of ****!!!
Hopefully this should solve your problem.
Please leave feedback.
Dec 02, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
