Only drains wont do anything except drain
    Problem Solver:
How do u change transmission screen on 03 Honda Accord 3.0
transmission screen? do you mean trans filter? hondas have garbage auto trans and all u can do is drain n fill
most like ur trans is done and a fluid change wont do anything except cost ya money
but atleast it has vtec right?
Mar 16, 2014 | Cars & Trucks
Asko 10625 washing machine wont drain or open
Take the bottom panel off and there is a large drain under the drum. There will be a lot of water that comes out, so be prepared. When you take the drain off, there should be a debis trap in there. Clean this out look to make sure there are no socks or anything in there.
Nov 27, 2013 | Asko Washing Machines
Capri washer
Commonly the drain pump is run by a belt drive, which has possibly broken. You should be able to take the back panel off the washer by undoing several screws, and then look to see if anything is obviously broken.
Aug 24, 2013 | Washing Machines
Electrolux EWF1074 7kg washer stuck on drain cycle
The first thing I would check is the drain line, not for a blockage but to see if the drain line isn't pushed down in the drain so far that its below the level of the pump. If it is you'll have a siphon effect going and the machine will never advance past rinse
Apr 26, 2012 | Electrolux Washing Machines
First four lights on cycle indicator flash and machine beeps 10 times and then beeps every 30 seconds
I recomend checking drain hose for kinks or obstructions and checking drain pump. most dishwashers will drain first for about 25/30 seconds.Also check the drain hose into the main plumbing connection it maybe blocked.If it cant drain it wont do anything hope this helps.
Feb 17, 2012 | KitchenAid Dishwashers
Washing machine wont drain
Hello,Do you hear the pump running when it is supposed to? If no and the machine is still under warranty, take advantage. If you do hear the pump running, but nothing comes out--lower the drain hose down near the floor to see if it will gravity drain into a bucket or pan. If it drains, then the pump isn't moving anything even though it is turning--it must be replaced. If it doesn't drain freely, then something is blocking the drain--a pinched hose either to or from the pump, or maybe a stray sock blocking the outlet from the outer tub.
Thanks
May 19, 2010 | Tecnik TKL9260 Front Load Washer
Washer wont drain
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Jul 19, 2009 | Tecnik TKL9260 Front Load Washer
Overloaded it and now it wont do anything. Is there someway to drain it or reset it?
you may have broken the drive belt which is easily replaced. No need to buy a new dryer.
May 23, 2009 | Washing Machines
Washing machine won't drain
Sometimes machines wont drain if the filters haven't been emptied. I bought a machine which didn't drain properly and I checked the filter. It was chocker block full and the lint was clogging the drain. Once cleared, My almost new machine worked well. and I paid $300 for it
Nov 17, 2017 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
