Racer AcerPower F5  PC Desktop Logo
Anonymous Posted on Jan 02, 2009
RAM Upgrade for AcerPower F5
I bought memory for a friend's desktop PC (an AcerPower F5). Every memory configurator I used pointed me towards DDR2 533 (PC2 4200) with a maximum of 2 GB (2 slots, 2X1GB) but I've bought two different sets of ram for it (first a PQI Turbo 2GB kit with a CL 3 then Kingston ValueRam with a CL 4) and the PC wouldn't boot or post with either (any) of the new sticks. Upon closer inspection, the motherboard does have DDR2 667 stamped on it in small white letters. Before buying a 3rd (and most assuredly final) set of ram, I wanted to see if anybody could shed some light on something I might be missing. Is the answer in front of my face -- 667 is the way to go and anything slower won't work?? ...or am I just generally jinxed and/or doomed? Please help!
  • Anonymous Jan 02, 2009
    To clarify, this is a memory upgrade necessitated by frequent "OUT OF MEMORY" errors.
    Also, you are correct: the PC came with 1GB ram. However, aiming to maximize compatibility and reduce the likelihood of other unforeseen problems, I made the decision to utilize a matching pair rather than simply purchasing an additional stick of ram to compliment the existing one.
    The existing stick is generic with no discernible markings.
jambon316
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Sep 02, 2010
jambon316
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
1099
Points
9
Ive had the same problem upgrading the ram on 2 acer pcs in work, we have 4 of them in total,2 took ddr2 667 mhz 1 gb crucial brand ed ram sticks, the other 2machines however wouldnt take the same chips and exhibit same symptoms as above even when original chips were put back, drives spin at 1st, fan blowss but no signal to monitor and no post codes. turning the pc on and off a couple of times get the machine booting but inevitebly the machine will freeze after sometime in windows. weird eh,
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jan 02, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
Helped
4442
Points
18
Just to make sure, you are UPgrading the RAM aren't you, it originally has 1GB in it, didn't it? Because i Hate people that change things when it is unnecessary.
But you are right it helps to look at the little label on the RAM you took out as to what kind to get, try to get the same speed will probably guarantee it will work.
AcerPower f5 4GB RAM only 3 available
in win 7 it won't shows all RAM, mostly virtual and paging file uses it,don't worry your ram is fine.when cpu require high RAM usage it uses it.
Hard drive beeps
was your vostro 230 third generation? meaning, did it use DDR2 memory before or always had DDR3? They are not compatible. 2nd generation computers cannot use third gen parts. cpu, ram, most none of that type stuff. the motherboards are different and cannot change. if it was ddr2 memory you have to use ddr2, not ddr3, hope that helps.
1helpful
Can I upgrade my 2.8 Ghz CPU with the 3 2 GHz dual core 775socket BX80571E5800 CPU into my N1996 acer 671t desktop motherboard, and can I upgrade my 553/ddr2 ram with a 2nd 2G ddr2 800/ RAM (max 4x 1 G...
as long as the socket is exactly the same as the processor you are trying to upgrade to you should be good. As far as memory goes you can use a faster ddr2 chip but you have to find out what the maximum capacity is on each slot. Most newer computers can support 1gb+ per slot. Always make sure you install ram in pairs and in the proper slots.
2answers
Can I upgrade my Ram on Gateway Desktop . I have 512mb, 2.0MHz. It's a good computer that I would upgrade for a project.
Hello
Number of Slots:4
Slot 1 Slot 2 Slot 3 Slot 4 Each memory slot can hold DDR2 PC2-5300, DDR2 PC2-6400 with a maximum of 1GB per slot.
Not to exceed manufacturer supported memory
Good Luck, and do rate the solution if got help
2helpful
2answers
Upgrade to 2g memory
If its a desktop it should be fine with two 1 gb sticks. Check to see how much ram is being shared for video. You can see that in the bios setting. Not sure how much can be shared but it may read differently depending how much system ram is being shared for onboard memory.
1helpful
2answers
DDR or DDR2
DDR 266 is DDR, not DDR 2 . The 266 is the frequency value in Mhz.
Try having the memory refunded or resell it on Ebay, so that you do not lose your money.
Here is supported memory, many older motherboards do not accept modules of over 512Mb each, ask to the seller:
PC2100 Memory DDR266 DDR-266 184-Pin Upgrade (266MHz) Memory Upgrades
1helpful
I want to upgrade my lenovo laptop ram memory from 1gb to 2gb by adding one more stick. i currently have ddr2 PC2-5300(333MHz) latency 5 5 5 15 2T RAM my friends advised me that BLUE SCREEN ERROR occurs...
The rule of thumb with RAM is to always buy matching pairs. So instead of buying one new stick of 1gb its a better idea to buy two of the same kind and replace the one that is currently in there.
Before you even think about doing this, head over to lenovo's website and make sure that the computer is compatible with 2gb(from the speed of the ram im assuming that it will, I don't know of many DDR2 computers that cant have 2gb.) you may also be able to get ram that is faster if it is compatible, The website will have all this info.
7helpful
3answers
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
1helpful
Dual Channel on an Emachines T5082
Look closely at the BOLD print
Memory Upgrade for eMachines eMachines T5082 Computer, the eMachines eMachines T5082 Computer takes the PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T5082 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for eMachines eMachines T5082 Computer.
1helpful
6answers
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Top Racer Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Racer Computer and Internet Expert? Answer questions, earn points and help others
