Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water through dispenser not cold.
Water coming through water dispensing line is not cold. is this normal,if no what can be the problem?
  • kirbymerrell May 11, 2010
    it wont be ice cold. the coils of tubing in the fridge cool the water.
  • 54 Answers
The first half of a glass will not be cold. The cold water has to travel from a tank behind the veg drawer. But if this is a refrigerator with the freezer on the top then it won't have chilled water.
Posted on Jan 04, 2009
How big is the reservoir for the water dispenser? Also, what is the normal temperature of the water being dispensed?
??? You never gave make or model and your mouth is that accurate to tell a 17 degree difference in water temp?
Jul 02, 2015 | Refrigerators
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
The water dispenser wont dispense water. Line is open and on. I
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Dec 23, 2010 | Whirlpool ET1FTTXK Top Freezer...
WATER WILL NOT DISPENCE FROM WATER DISPENSER
Sep 27, 2010 | Amana ASD2324HES Stainless Steel Side by...
No water coming out of dispenser on outside of door
Jul 01, 2010 | Refrigerators
Low water pressure from water dispenser
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. There is a screen filter in the line where the water supply connects to the water inlet valve.
. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 14, 2009 | Kenmore Refrigerators
Water Dispenser not working
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water from the in the door water dispenser trickles out instead of flowing out
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. If it comes out good here Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
A strainer before the inlet valve can also get stopped up restricting flow.
Jul 01, 2009 | Refrigerators
Whirlpool side-by-side refrigerator - 2 problems
I would suggest that you get a certified person to come out and look at it you very well could have bent the doors in the move.
but... if you want to do it yourself.
click here for a walkthrough
for your drip:
Flush air from the water system the first time it is used and after replacing the filter. Air trapped in the water line or filter may slowly travel through the coiled water reservoir to the dispenser, pushing any water ahead of it. This can cause the dispenser to drip. Water needs to completely fill the lines for all air to be cleared.
  • Use a sturdy container to press and hold the water dispenser bar for 5 seconds, then release it for 5 seconds. Repeat until the water begins to flow. Once the water begins to flow, continue pressing and releasing the dispenser bar (5 seconds on, 5 seconds off) for an additional 2 minutes. Repeat if dripping starts again because air can re-enter from the water supply.
  • As air is cleared from the system, water may spurt from the water dispenser.
  • Make sure the refrigerator is connected to a cold water supply.
One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
Jan 26, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,765 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
