Question about Cuisinart DCC-1200 Coffee Maker
DC-1200 Plugged in. The dgital clock did not come on.
Unable to use features (e.g. Program). The brew function works OK. Am I missing something in the User's Guide? Have had the coffeemaker only a few days; have not yet mailed the registration info.
Phil Hopkins
  • phopk46 Jan 04, 2009
    That seemed to do the trick.
    Sergeant:
    Novelist:
  • 326 Answers
Unplugging and plugging it in may reset the machine .also some other points that u must know about your coffe maker are mentioned below'
The coffee maker has a timer on it that allows you to set the time you want your coffee brewed during a full 24 hour period. There is also a programmable shut-off on the coffee maker so it doesn’t stay hot all day long.
There is a warming plate that is heat adjustable so you can decide the temperature that you want your coffee.
You might like your coffee really hot or you might like it warm. You can decide the temperature of your coffee.
After two hours the warming plate will automatically shut off and if you like to drink coffee for more than two hours you can turn it back on.
The filter included is a permanent filter that is not removable. This is a nice feature.
There is a pause and serve function that will allow you to get a fresh cup of coffee while a pot of coffee is brewing and the coffee will stop pouring out of the filter so you can pour a cup. When you replace the carafe the pot will begin brewing again.
for more help and details click the link below
http://www.coffee-maker-review.net/cuisinart-dcc-1200.html
Posted on Jan 03, 2009
    Genius:
  • 1,239 Answers
Hello
you need to check your flor meters. they could be scaled or dirty. you need to dismantle flowmeter that is on the side that is not working and clean it. make sure the water main is off and power is shut off. hope this helps.
  • ABHISHEK.C
    ABHISHEK.C Jan 03, 2009
    IF IT IS WATER STEAM ISSUE
    Fill the water tank with water, open the steam knob and when the water comes out, take off the water tank and let the machine go to it stop.
    Close the steam knob and put back the water tank.
    Open the steam knob again to get out the air in the system.
    Hope this will help you.
  • ABHISHEK.C
    • Unplug for 20 minutes or longer - this one has a longer than normal reset.
  • 916 Answers
After turning the control knob to "clock" hold in the hour button until the digital display starts flashing.
With the "program" function, turn it to "program" and the display will start flashing.
The "self cleaning" light is a little misleading, It doesn't actually clean itself. You need to do the usual water/vinegar cleaning as with any other coffee maker.
Flip on the toggle switch to "On" and also press the "1-4 cup" button. When used in this mode, the coffee maker must be set to "Auto On."
    Genius:
  • 1,913 Answers
Remove power cable from it.
then connect again.also reset to factory fefault
    Brigadier General:
  • 5,158 Answers
Perhaps it is locked up... unplug it for ten minutes and plug it back in.... i'll go look for the manual and read it over as well
  • Roberta Smith
    Roberta Smith Jan 03, 2009
    are you changing the function knob for each function you want to program ?
    found the manual online as well
  • Roberta Smith
    if changing the knob function does not accomplish what you are trying to do ... please restate the question and i'll look over the manual again and try to assist you.
The clock is saying 18:88 and won't brew coffee
Hmmm .... sounds as though it may have encountered a power
surge overnight. Might try the Microsoft universal corrective action:
1. Unplug the device from the wall socket
2. Leave it out for 1 minute.
3. Plug it back in.
4. Re-set the clock and other settings (autostart, e.g.)
If that doesn't work, then I'm sorry to say that it's toast :=(.
- Mike
Jun 08, 2015 | Cuisinart DCC-1200 Coffee Maker
Cuisinart dc 1200 coffee maker auto start mysteriously shuts off
Sounds like the switches got damp when you cleaned it. Let it dry out very thoroughly before you plug it back in. Then set the TIME OF DAY first, and be sure you pay attention to AM/PM if you are not in the 24-hour mode. Next, set the BREW TIME. Once again, heed the AM/PM or you will have nice hot coffee either 12 hours early, or 12 hours late! (I don't know which would be worse.)
Mar 18, 2012 | Cuisinart DCC-1200 Coffee Maker
How do I program my DeLonghi DCM 485?
Hi and welcome to FixYa, I am Kelly
First you must set the clock. Page 6 of this pdf manual:
http://www.smallappliance.com/images/SmallAppliance/English/products/standard/DCM485.pdf
Then prgram per instructions at the bottom of page 6 and the top of page 7 of the same manual. I note step 2 is missing from the manual.....
3. Press the CLOCK button until the desired brewing time is displayed
(See "How to Set the Clock" section of the manual).
4. Press the ON/OFF button to confirm the automatic time selected.
NOTE: The display panel and the on/off indicator light will flash.
5. Press the PROGRAM button to return to the current time of day (the
ON/OFF button will continue to flash.) The brewing cycle will begin
once the set time is reached and the ON/OFF button stops flashing.
6. If you want to check the automatic time selected, press the
PROGRAM button.
7. To override the automatic brew function, press the ON/OFF button
and the coffee maker will start immediately. Press the ON/OFF
button again to switch the coffee maker off.
Thanks for choosing FixYa,
Kelly
May 21, 2011 | DeLonghi DCM485 Coffee Maker
How do you set the clock and program to brew at a specific time?
To program the Auto On
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
Aug 16, 2010 | Cuisinart DCC-1200 Coffee Maker
Coffee too weak what are normal knob settings
Function Knob For setting time of day, and auto on and auto off times. a. Auto On The Auto On feature is used to program the start time of the brew cycle. The auto on time can be set for any time, day or night. The “PM” indicator is displayed on the LCD for nighttime program times. b. Auto Off The Auto Off feature is used to shut off the coffeemaker at a preset time, anywhere from 0 to 4 hours. c. Program Set The Program Set function is used to set the time for the Auto On function. d. Brew The brew function is used to start the brew cycle directly. e. Clock Set Used to program the time of day. f. Audible Tone (not shown) The Brew Central™ Coffeemaker is equipped with an audible tone which will sound 5 times when the coffee has completed brewing (coffee will continue to stream from the filter for a few seconds after tone).
If yours is a Vienna Digital Coffee Maker please click the link below. it is manual of Coffee Maker, it would be helpful to in the future.. http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
Jan 20, 2010 | Saeco Vienna Digital Coffee Maker,...
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
I have a cuisinart coffee maker. I can set the
Unplug the coffeemaker for 20 minutes or longer - not a second less - in order to fully reset it. Then, when you plug it back in, turn the function dial to Clock again. Press and hold the HR button for a few seconds, and then set the hours. It should work now unless it got zapped, as you said.
-Tha Mp3 Doctor
Mar 21, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart grind and brew beeps, but won't brew
we unplugged it for 10 minutes or so, plugged it in again, beeping stopped and it works again.
Nov 16, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Switch doesn't work - can't get it to brew anything
Try unpluging for a few minutes . If that doesnt work try moving to a diffrent outlet . If that still doesnt work . It is time to get a new coffee maker or to call them and get it replaced under warrenty .
This is a known problem with this brand , we have been through 5 of them for the same thing .
It could be caused from anything such as wear (depending on how often you brew) to a power surge that went through your line or even a failure ...
Sep 14, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee brews and then immediately shuts off Cuisinart DCC-1200
To program the Variable Auto Off: 1. Turn the FUNCTION KNOB to the ?Auto Off? position. Press and hold the ?Hour? button for 2 seconds. The clock display will start blinking. 2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the ?Hour? and ?Minute? push-buttons. (see ?To set the time?)
May 20, 2007 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
49 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
