A thumping sound when driving between 30-40 mph. Feel a slight thump under drivers side floor. Also, only did this once, shimmy when doing a slow rightturn. Whats causing this?
SOURCE: 2006 toyota sienna thumping noise on drivers side
Has the upper strut bushing been replaced? Have you checked to see if the wheel is loose? To do so jack up the side you here the noise on and use a tire tool or piece of pipe and jack up the wheel when till it's off the ground about an inch enough to get you bar under the wheel. Next pull up on the wheel with the bar if you feel a clunk then get a second person to pull the lever up and down and see where the looseness is, if there is no looseness when prying up and down then you will have to wiggle the wheel from left to right to see if you can find the noise, a also you will have to pull on the drive axle to see if it's loose once you determine what is loose then you can tell me and I will tell you what has to be replaced.
SOURCE: thumping noise in front drivers side wheel and
Check your suspension bar and check your front strut assembly, jack up the side you here the noise on and pry against the tire to see if you have any movement between the strut housing and the frame, make sure the top strut nuts are tight, if they are next check tie rod ends to see if you have any play, next pull the wheel from the top and bottom to see if it's loose if it is watch while someone else wiggles the tire, you could have a tie rod loose or a king pin loose. Also it could be a wheel-bearing nut. Let me know what you find so I can tell you how to replace it.
SOURCE: 2002 Camry water on drivers side floor whenever it
There are three possibilities, the winshield seal is leaking, the door seal is defective or the door window seal is leaking, sometimes you can find out by having an assistant inside the car observe the areas mentioned while you spray the car with the pressure washer at the car wash.
SOURCE: 2002 toyota corolla - engine stutter?
its the drive belt tensioner dampner it goes bad and sounds like a bad engine vibration when accel and on cold start up
SOURCE: my toyota corolla nze 2002 has a rattling sound in the gear box
SInce any noise from within the engine/gear box cannot be taken lightly, it is important that you will need a good look from a service shop. If you have been carrying out the scheduled service in accordance with Toyota timings, there will not be an issue. You could check out if the noise is external,otherwise get you car to the authorised Toyota centre for an estimate. This will be better than trying out/ stipping and then waiting for spares. I hope my advise is helpful. good day
