The setting of my waching michine
Mitsubishi washing machine
  • 15,935 Answers
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Posted on Sep 16, 2010
MY TOP LOADE WASHING MICHINE SHOWS CODE PR HOW CAN I SALVE THE PROBLEM PLZ SEND ME ANSWER
PR is normally the code for--- pause in the wash cycle-- press start again and it should continue washing from where it was paused
other than that call in a technician for a proper diagnosis and a quote
Jul 15, 2016 | Washing Machines
Why water is leaking from bottom of the washing machine
it easy .look in and wach the falling drops coming from the inlet water or from the drainage hose and pump.Whatever it is u can handle it.
Jun 24, 2015 | Candy Washing Machines
My washing drained pump burned out. So i replaced it cleande the drum and refitted it all. The problem i have now is my waching machine turnes on and the pump runs as soon as the waching machine is turned...
If you can actually hear the pump running (as in not just hose too low and water draining out), I'd say that the main PCB is shot.
It was probably shot before you replaced the pump (pump burned out from constant running).
These models don't have an overflow as far as I know, unless it is pressure switch based (a possible issue if you did something odd cleaning the drum) remove and reseat pressure switch hose just to be sure.
May 27, 2014 | Washing Machines
Indesit
brushes, 2 of, are located in the back of the motor , , u will have to turn your washing michine on it side to do it.
Apr 20, 2014 | Washing Machines
What do we do if we have connected our washing michine but there is no water coming through?
First, check the plumbing. Is the water turned on at the source?
Next, check the electric outlet. You need 120VAC. Make sure the breaker isn't tripped.
Try the fill in every cycle. Try it with every water temperature selection you have available on the machine.
Dec 23, 2010 | Washing Machines
WATER IN WONT DRAIN OUT
The water inlet Solenoid is open. Check the Solenoid. Give gentle tap it may re seat again. Finally replace if it is not settling!
Apr 05, 2010 | LG WM-1832C Front Load Washer
Hi i have hitachi SF-110CJ waching machine how can i cotrol the water temperature before starting the waching process
i have an error code f9 and washing machine stop spinning and dont turn , how can i fix it and where can I buy spar parts , i am from lebanon , west bekaa
Jan 19, 2010 | LWScientific LW Scientific Variable-Temp...
I WANT TO ASK ABOUT THE FUNCTIONS OF INDESIT WIXXL 146 WASHING MA
instruction book http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WIXXL146-GB-Hires.pdf
Jun 10, 2009 | Washing Machines
SAMSUNG waching machine doesn't want to drain and spin.
drain pump blocked. remove bottom bung filter where hose comes out. will be a hair pin, bread tag stuck in fan blades
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
