Question about iLO 3200 32 in. LCD Television
Connection to a computer
What dvi cable do I need to connect a pc to this tv?
    Problem Solver:
  • 15 Answers
This TV has an HDMI interface, not DVI. If your source is DVI, you can get an DVI to HDMI adapter. The HDMI carries both video and audio data, so you will need to connect your audio separately.
Posted on May 12, 2007
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
How to use rca entertainment series 32 inch as pc monitor
Assuming that your RCA 32 inch tv has an HDMI or VGA input, all you need is the proper cable to connect the two units. If your computer has a VGA out (blue female connector) and so does your TV, you would need a male to male VGA cable. If your computer has a DVI out (white connector), you would need to purchase a DVI to HDMI cable. The combinations can me played around with depending on what connectors are on the back of the TV and what you have as an output for your PC.
Feb 28, 2011 | Compaq Computers & Internet
Which accessories are a 'most have' for connecting my TV to a desktop pc?
You'll need:
•VGA cable
•S-Video Audio to 3 RCA Type Adapter Cable
•HDMI cable
•DVI cable
Check the connection options on your TV. If your TV has a VGA connection slot, plug the TV into the computer with a VGA cordlike a computer monitor. Connect one end of the VGA cable to the back of the computer and the other end to the TV. Switch between normal TV viewing to displaying your computer on your TV by selecting the proper mode from the remote control, some remotes will mark the proper mode as "VGA" while others will label it "Computer" or "PC."
Check the back of your computer to see if you have an S cable slot. Connect S cable portion of the S-Video Audio to 3 RCA Type Adapter Cable to the computer and plug in the green audio plug to the audio port of the PC. Plug the red white and yellow RCA cables into the matching colors of the RCA slots on the TV. With this method you will need to switch modes from TV to video.
Check the back of the computer and TV for either DVI or HDMI slots. The slots on your computer must match, you cannot connect a DVI to a HDMI. Plug one end of the corresponding cable into the the back of the TV and the other end into the computer. Choose the correct program mode, HDMI or DVI, from the remote to view the computer from the TV.
Aug 12, 2010 | Televison & Video
Where do I get a cable to connect my laptop pc to the DVI input jack on the Soyo 32" LCD TV?
You will need either a DVI-I to DVI-I cable or a DVI-I to HDMI cable. Your computer should have a DVI-I output or HDMI. You can not directly connect a VGA output to the TV. If needed, you can purchase a VGA to component (Y/Pb/Pr) converter.
Mar 15, 2010 | Soyo DYLT032C 32 in. LCD Television
I want to connect this pc to LCD TV want know where is the audio output of the computer
LCD TVs are the best at showing computer graphics, so many come with PC video connection ports by default. If it does have one of these ports, all you need to do is get a cable to connect to it. This is usually a male-male cable. Be warned, however - stores like Best Buy and the like tend to horribly overcharge for cables. Check prices online at places like www.newegg.com - I found some from $6-$10 with $5 shipping. They'll probably be $25 minimum in a store. Also, if it's a DVI connection, don't get a DVI-A cable - that's for analog connections. DVI-D is for digital connections (specifically for connecting to LCD screens) and DVI-I cables are for both, but be sure to get a DVI-D cable.
Check out this link and look at the picture of the DVI-D and DVI-A connectors:
http://www.pacificcable.com/DVI.htm#DVI_Hoods
My video card has a DVI-I output, but my monitor only has a DVI-D input, so I can't use a DVI-I cable on it (DVI-A and DVI-I both have 4 extra pins that DVI-D doesn't).
If it's got a VGA port then whoop-de-do. There's only one type of VGA cable anyway. ^_^ Source(s): http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Description=dvi+cable&x=0&y=0
http://www.thesmallest.com/lessonettes/dviandvga.html
Jan 16, 2010 | Televison & Video
How do i connect my compaq pc to tv
Without the model number comptuer, I cannot verify what outputs your comptuer has. Without this, I will provide the various ways a PC can be connected to a TV.
1. Use a VGA to DVI adapter (HD-15 pin to DVI). Use either a standard VGA montor extension cable (cheaper) or a DVI extension cable (more expensive) to make the connection
2. If you computer has a DVI output, use a DVI extension cable only
3. If your computer has HDMI output - use a HDMI to DVI adapter and either a HDMI or DVI extension cable.
In all 3 cases, you will probably need to go to the comptuer's Display Properties and adjust the screen size so it looks OK on your TV (go to the Control Panel - find Display) and adjust the screen resolution to match the format of your TV.
One note - when purchasing DVI cables, understand that there are 3 types - DVI-D (digital), DVI-A (analog) and DVI-I (digital and analog) and that the pin outs are different. Be sure to check your the owners manual of your TV to find which connection it needs.
Here is a good reference for DVI types
http://www.interfacebus.com/Design_Connector_Digital_Visual_Interface_DVI_Bus.html
Dec 02, 2009 | Compaq Computers & Internet
How do I connect my Sony viao to my philips LCD
If your PC has a DVI port( ihope u have one) purchase a DVI cable and connect it to your TVs DVI port
DVI port
dvi cable
If your tv has no DVI port and only VGA port buy a vga cable and dvi to vga converter and connect to pc and use it
vga cable
you can also get a svideo to avi converter cable and use it to connect to your tv
svideo converter
Nov 27, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
How do i connect advent pc to philips hdtv. do i need to change settings?
well not really, you need to buy the proper cable depending on the inputs of your tv, it may have the standar VGA connection as the standar pc monitor.
DVI to VGA cable
DVI to DVI
HDMI to DVI
HDMI to HDMI
after you have the proper cable just plug it, and turn it off, disconnect the standar computer minitor and turn it back on. the computer will set the input signal from the tv by itself.
thats for the video, for the audio you need a different cable
3.5 mm to RCA (white and red cable)
3.5 mm to 3.5mm headphonejack cable
but if you are using the HDMI to HDMI you don't need a sound cable.
Oct 07, 2009 | Computers & Internet
LG32LZ55 TV GOING INTO DPM MODE
Hi Ben,
Did you ever resolve? I have the same issue.
Jun 18, 2009 | LG Televison & Video
WANT TO HOOK MY COMPUTER TO MY TV? COMPUTER : T6534 EMACHINE TV SET : MAGNAVOX WHAT ITEMS DO I NEED?
You Need a VGA to DVI Connector and a dvi cable which connect at the back of the tv.
you need to connect the VGA Port(Blue Colour) with VGA to DVI connector and then Connect DVI cable and Connect your computer.
Jul 14, 2008 | Computers & Internet
iLO 3200 32 in. LCD Television Logo
140 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
