COPIER My mistake the one copier is a Kyocera/Mita Ai 3010 it has about 220,000 copies, was changed ou (rebuilt about 100,000 copies) Also I live iin Tarpon Springs. Joe
  • jpd8 May 11, 2010
    What is the problem you are having?
  • 92 Answers
Whats the problem besides the make and model
Posted on Jun 28, 2009
I want to refill kyocera mita dcc 2725 with fs c5400 refill toner. will it work
NO do not mix different types to toner. Major mistake that will cause the developer to go bad and even can cause fuser problems. toners are not the same. The have different percentages of ingredients depending upon the melt point of the fuser and the image density of the device.
Printer Repair Service in Miami and Fort Lauderdale FL
Feb 02, 2016 | Kyocera Office Equipment & Supplies
Dirty and light copy of my Kyucera KM 1505 copier machine
Clean the optical parts (lens,mirrors),and the poligon motor mirrors.
Apr 08, 2013 | Kyocera Mita Office Equipment & Supplies
Kyocera mita 6030
The optimizing performace may be because of the temperature in the room.Clean out all filters in the machine.Do not reset the drum light unless you do change the drum as the copy quality may degrade.
Apr 21, 2010 | Kyocera Mita Office Equipment & Supplies
Kyocera mita maintenance light is on and lines
check the rectangular **** glas and table for any white out or particles... clean thoroughly... make copies... clean again... make copies... if same issue... then replace drum... but in most cases its the optics... which I advised you to clean thats causing the issue... if the issue occurs when you print an internal report then its definitely drum... if reports are clear... there is something on the glass... or on the part above it... even a little bit of black toner or ink or whiteout anywhere out there can cause a line
Oct 05, 2009 | Kyocera Mita KYOCERA/MITA AS-M4110 Copier
Degradation of copies produced by Mita ai3010 copier
Please put the copier machine in the horizontally,and check the developer level in the developer station.Check the magnetic roller.If the copy degrade in the normal size (paper is positionly normal) the problem is in the optics section.In this case remove the mirror obturation plates,alligniament,clean the expo lamp.If the copy is degrade in the RS tray you need the check the developer unit,change and alligniament the doctor blade value (0,35mm) and change the drum collars.
Aug 18, 2009 | Kyocera Mita Office Equipment & Supplies
Mita all copies have clean, thin, black streaks
Needs a clean around the fuser area. You may see a build up of toner near the rollers which is being drawn in. There's an outside chance that the lens needs cleaning also.
Jul 07, 2009 | Kyocera Mita Kyocera-Mita SCANNER RACK...
Kyocera Mita 1635 Copier Printing Very Light Copies
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
Apr 15, 2009 | Kyocera KM-1505 Copier
The screen says AP -what does that mean
AP means that the copier is going thru a major toner cycle.
Sometimes when you drag a lot of toner out for dark copies, the normal toner cycle is not enough.
The spring that takes the toner from the cartridge to the dev unit mat also be faulty or broken.
Sometimes the AP message will go away but make sure you have plenty of toner.
Feb 09, 2009 | Kyocera Mita Kyocera-Mita SCANNER RACK...
Kyocera mita copier (printhead repearing ((led))
change toner... if that doesn't fix it then change the drum...
Jul 24, 2008 | Gestetner A045 Wide Format Copier
64 people viewed this question
jasbo
jasbo
