Question about Roper RAS8445KQ Top Load Washer
The unit will wash, but will not spin in any cycle
The washer would not spin after wash. It also had a burn smell to it as if something was slipping.
  • Bill Balint May 14, 2007
    The problem was the coupling between the transmission and motor. Thanks !
  • Annette Paulson Nov 18, 2012
    I am having the same problem. Could this also happen if a belt needs to be replaced?
Faulty drain pump no drain no spin
Posted on May 13, 2007
Smells like burning electrical
Its sounds to me like maybe the belt is slipping that will smell like something burning.
Oct 07, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Frigidaire FEX831FS2 stack washer/dryer; it washes, but when it goes into spin cycle it does not spin and you can smell something "funny" burning up like a motor or something. This is what the...
well, The transmission hears turns 2 ways. One way to wash (which causing the agitator turn) and the other to spin. The motor also turns 2 way. If you say it washes fine and in spin cycle is where you get burning smell, maybe of many things: Bad transmission locking up motor causing the burning smell. Possible bad motor trying to start (bad start winding or capacitor). Maybe something simple as something getting stuck in between outer tub and inner basket. Something you can do to check the motor mechanically is disconnect the belt from the transmission pulley and put the time on spin cycle. If the motor shaft/pulley spins on start up then the next thing to look into is the transmission or something catching it from spinning. Check the inside of the washer, if the basket is the type with small holes, make sure there is nothing stuck in any of the whole. Iv seen small screws getting lodged in there and preventing the basket from spinning. You can start by doing simple checks like this to start narrowing down things. Open the front panel form the washer and see if you have access to the belt, if not then you have to tilt the unit to get under it. if you have money and dont want to bother dealing with the unit then replace it. But i like investigating things first. go with whirl pool if you replace it. let me know if what you find if you do make these checks.
Sep 10, 2011 | Washing Machines
Amana ALW880QAW doesn't spin and agitation is slow
winephan,
I could be the pump slowly ceazing causing the belt to slip which would give a burning smell.
Motors in those units, are well build...have a service guy in but DON"t say anything about the motor.. because they will say it because you mentioned it
I sounds like you pump
Jul 22, 2010 | Amana ALW880WH Top Load Washer
When washer is spinning it smells like something is burning
A burning smell means you have some slipping of the drive belt. I think your belt needs to be replaced. Another reason may be a binding in the tub. possibly a seized tub bearing. The only way to know is to take off the access cover at the back of the washer and visually inspect it first. you can spin the tub by hand from the back and this will give you an idea of what is binding.
May 26, 2010 | Kenmore 24032\24036 Top Load Washer
Washer spins but won't drain, electrical smell
HI, the smell is coming from the pump housing. the pump impeller may have slipped of the drive stud, in return, jamming itself in side the housing. this will cause the pump to burn out. Check the following before you replace the pump.
1. Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
Jul 09, 2009 | Kenmore 24032\24036 Top Load Washer
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
Roper RAS8445KQ0 spins but not fast enough
if it has no belt, seams like the clutch is slipping in the transmission, hence the burning smell
Jun 21, 2009 | Roper RAS8445KQ Top Load Washer
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Grinding noise,unit stopped, burning smell?
broken or slipping drive belt, motor to spin pulley defective drive clutch, spin brake fails to release to transmission is frozzen
Oct 07, 2008 | Admiral AW22 Top Load Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Roper RAS8445KQ Top Load Washer Logo
144 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Sal De
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
