Question about Belkin N Wireless Modem-Router F5D8633au4A
MY ROUTER KEEPS LOSING CONNECTION
WHEN TRYING TO USE WIRELESS ROUTER THE CONNECTION KEEPS GETTING LOST THEN RECONNECTING. EVERY THIRTY SECONDS OR SO.
  • 1 more comment
  • darkrift Jan 17, 2009
    this happened to me every since i updated to "Firmware Version 3.01.17 (Nov 29 2007 17:48:13)" i used a stop watch and i get disconnected every 45 seconds just long enough for everything to loose connection.
  • easy2kgrind Jan 28, 2009
    same problem after i updated the firmware
  • piratemech Feb 17, 2009
    My console computer does not recognize the internet through the router, but I can use it with my laptop.
    When I plug in the cable modem directly into the computer, the internet is fine.
    I have the same problem, any answers there?
  • 728 Answers
Hello fieldon68, & to all the rest with the same problem.
There are many things that could be wrong, but intermittant discounnects sounds very much like a interverance from another wireless device. (ie phone, cell, etc)
To try to address this issue, follow the steps below:
Note : The steps below are applicable only for Belkin routers.
  1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
  2. You will get a login page. Leave the password blank. Click Submit ( unless you created a password, then enter that).
  3. On the left side of the page, click Channel and SSID below Wireless .
  4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
  5. Click Logout in the top right hand corner.
Note: The wireless card in the computer will automatically detect the change in channel number on the router and will update the channel on the card.
CauseYou get disconnected wirelessly mainly due to an environmental interference. When the wireless channel is set to auto, the router will cycle to though channels when it detects significant interference. When the router changes channel the wireless connection will reset itself and disconnect all wireless clients connected to the router. Wireless signals are prone to interference from cordless phones and electrical appliances (e.g., vacuum cleaners, microwave ovens). This is one of the more popular reasons Belkin wireless connections can drop. Good Luck Mark P.S. Please leave a rating.
Posted on Feb 17, 2009
  • Mark Taylor
    Mark Taylor Feb 23, 2009
    They have a new firmware to help resolve the connection problem with the prior firmware. Try and download it HERE.
    Good Luck
    Mark
Mine has the same issue, I would really like to know how to solve this!
I have a Desktop computer connected by cable internet, with the router hooked up for my laptop. The laptop has internet and is fine but the desktop keeps disconnecting and running slow. It's very fraustrating.
Posted on Jan 03, 2009
Internet connection lost every 30 minutes
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
May 22, 2012 | D-Link Xtreme N DIR-655 Wireless Router
My laptop keeps losing signal, keeps disconecting. plus when pc was hard wired it too lost connection
have you tried downloading the latest firmware?
you can do so by going to
http://www.dlink.com/products/?pid=DIR-615&tab=3
click on support resources.
select your router model and download the latest firmware.
May 25, 2011 | D-Link DIR-615 Wireless Router
I keep losing my internet connection when I use the wireless router. When I disconnect the wireless router, internet works great but when I reconnect it it keeps cutting out. I unplug it for ten seconds...
Try changing the channel to 11. Cordless landline phones often interfere with the default router channel. It can even be your neighbors phone that is conflicting.
Feb 06, 2011 | D-Link DIR-615 Wireless Router
My computers keep losing connection and reconnecting.
Try changing the FREQUENCY of the router, you probably have interference coming from an other source (baby monitor, wireless phone, RF transmitter, etc...)
Cheers!
Jan 15, 2011 | Linksys WRT160N Wireless Router
Lost my wireless connection on linksys wireless g wrt54g v.4 router help.... called linksys wants to charge 39.99 for a quick fix plz help
My friend,
Please reset the router by pressing the reset button for at least thirty seconds.
Open the setup page of the router with 192.168.1.1 from Internet Explorer.
Username=leave this blank.
Password=admin
Router setup page will be displayed then.
Click on the basic wireless settings .
Give the network name(your choice) and channel =6.
Under wireless security settings .
Click on the security mode should be WPA.
Put a security key.
Save settings.
It will start working wireless .
Saved your 39.99 $
Regards:-
Amit Awasthi
Dec 12, 2010 | Linksys Wireless-G WRT54G Router
Telus router SE567 connection problem
Change the Wireless channel on the router to 9 for best wireless connection and also check if the firmware on your Router is the Latest or not, if not then update it as soon as possible.
Mar 22, 2010 | Computers & Internet
I lost my passphrase of my dlink router
There should be a reset button located on the back on the router. Hold on that button for about thirty seconds or so and resetup the router with the password.
Nov 14, 2009 | D-Link DIR-615 Wireless Router
My belking keeps losing connection during games?
If your wireless you probably need to change broadcast channels on the router ( to the last channel) if its hard wired, you probably need to port forward the ip address for the Xbox
Oct 05, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Hi, Expert: I am using NETOPIA 33347 wireless Router for home networking. I can not reset the router for my wireless laptop computer. Wireless light is not turned on and can not access to router from my...
Greetings my name is Mark and I will be glad to assist you. First unplug the router power and let it stand for thirty seconds. Second locate a small hole in the rear of the router it will not be marked. Third insert a small paperclip in the hole, you will feel a click when you do this, hold the clip in place for thirty seconds, at the same time you are holding the clip in place re-connect the power to the router and count to thirty seconds. Remove the clip and allow the router to re-boot for two minutes. It will reset to factory default and you will be able to access the router through a hardwired computer connection. Open your internet explorer and in the address bar type "192.168.1.100" your user name is andmi and your password is admin this should default your router and you can make the necessary security changes. Take care,
Be mucho blessed,
Mark
Aug 10, 2008 | Computers & Internet
Lost wireless connection WRT54G
I have had similar problems with my home wireless connections for years, across several different brands of routers. By far the quickest solution that I've found is to simply reboot the router; either using the command interface from a computer connected via ethernet; or by unplugging it, waiting 30 seconds, and reconnecting the power.
Sep 30, 2007 | Belkin (F5D9230-4) Wireless Router...
Belkin N Wireless Modem-Router F5D8633au4A Logo
727 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
