Question about SanDisk Sansa e250 MP3 Player
One earphone works
Sandisk e260 - only the right earphone is working since yesterday, worked great for 6 months
  • johnnywal960 Dec 12, 2008
    b-man.... you are the man.... I tried the soldering fix and it worked... no more mono... sound is actually coming in clearer.... and here I thought I was going to fry the thing....
    - Cheers mate
I had the same exact problem with mine. Reading around it seems to be a common problem with the Sansa line. I opened mine up and found that one of the solder points that holds the ear phone jack to the main board had come loose. I soldered it back and it works like a charm. Pretty easy too. If you have a soldering iron, just open it up and resolder the solder point that has broken off. You can read instructions for disassembly here: http://www.anythingbutipod.com/archives/2006/11/sandisk-sansa-c200-disassembled.php When you have it apart, looking at it from the side, with the jack to the right, the broken point should be the rear (closest to the circuitry) point. You will see a very small, not sure what to call it, chip on the board you have to solder a connection to. here is a diagram: http://i42.photobucket.com/albums/e321/fuzzygoat/sansa-c200-disassembley-8.jpg Hope this helps.
Posted on Aug 23, 2007
If you don't know how to solder something you can always get these little things for really old radios (which only play in one ear) that make it play in both ears. Although it may be a little bit more bulky you can listen to your songs with both ears. Hope this helps.
Posted on Aug 29, 2007
It is possible that The earbuds are broken and should be replaced or it is possible that the headphone jack on your mp3 player is broken. I have the same player and this happened to me. I returned it for a replacement. Try bending the connecters inside the heaphone jack to achieve better contact with the headphone plug. Try another set of earbuds with your mp3 player.
Posted on May 10, 2007
  • derry lappin May 10, 2007
    sarahamlee that was not a solution
Sandisk Frozen Pale Blue Screen
Having received no response in over a month, I assume this is no longer a problem.<!-- from fixya rte -->
Jul 05, 2010 | SanDisk Sansa e260 MP3 Player
White screen on sansa e260
For the non-deletable files try: http://forums.sandisk.com/sansa/board/message?board.id=e200&message.id=26888&query.id=215455#M26888
http://forums.sandisk.com/sansa/board/message?board.id=e200&message.id=24445&query.id=215455#M24445
http://forums.sandisk.com/sansa/board/message?board.id=e200&message.id=2824&query.id=215455#M2824
For the Display: http://forums.sandisk.com/sansa/board/message?board.id=e200&message.id=25895&query.id=215591#M25895
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=16113&view=by_date_ascending&page=1
Hope this helps...
Feb 04, 2009 | SanDisk Sansa e260 MP3 Player
The Sansa doesn't work, you can hear any thing
call the company and tell them wat happen they should tell you to send it to them in order for them to fix it
Nov 11, 2008 | SanDisk Sansa e260 MP3 Player
Only one side of my earphones work. I have tried several other earphones and when plugged into my sansa mp3 player that one side still does not work?
Headphone jack repair
· http://www.pcpages.com/thebishop/nomadfix/
· http://www.instructables.com/id/Zen-Micro-Headphone-Jack-Fix/
· http://www.noboundrees.com/micro_fix/
Jan 14, 2008 | SanDisk Sansa e260 MP3 Player
Audio Problem
Mine does that too. I am not sure if it works with other things but I just bought new ones.
Jan 02, 2008 | SanDisk Sansa e260 MP3 Player
Only one audio output working - not stereo!
It is the actual headset jack on the device. It wears out from plugging and unplugging the headset.
If its less than 1 year, call SanDisk and they will replace it.
Otherwise, if you are inclined, you can replace the internal headset jack.
SanDisk Technical Support 1-866-726-3475
Best of Luck.
Nov 11, 2007 | SanDisk Sansa e260 MP3 Player
Earphone jack has a short.
take it apart resolder the connections. if the jack itself is bad see if you can find a new one. never worked on something that small myself, but should be fairly straighforward
Jun 03, 2007 | SanDisk Sansa e260 MP3 Player
Only one earphone (right) is working
The problem is in the ear-phones, not the player. Return the phones via warantee if available. You should be able to wiggle the cord at various places along the cord to find out where the short is. (One of my sansa's phones had a short close to the plug itself.) If you know how to perform basic wire splicing/sodering, and melt a piece of shrink tubing (from Radio Shack) over the splice, you can fix this yourself. The sansa phones I have are real good, and worth saving, however don't be afraid to buy some really good ear-phones (over $50) if you cant fix the cord.
May 10, 2007 | SanDisk Sansa e250 MP3 Player
Can't hear music from sansa
Hi. If you have to adjust your earphone (even if you used other earphones) just to get a normal stereo sound, then the problem is with the player's earphone jacks. If that's the case (and assuming the radio feature of the player also manifests the same problem), then you may need to call the tech support guys at SanDisk for advanced troubleshooting, or possibly replacing that player. I found their tech support contact number at their website upon consulting prior issues I had with my player. Here it is: 1-866-726-3475.
May 09, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
356 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
