Question about Refrigerators
REFRIGERATOR WARM ABOVE 60 FREEZER 0
WIFE CLEANED INSIDE OF REFRIGERATOR AND FREEZER YESTERDAY AND DID NOT TURN OFF LEAVING DOORS OPENED FOR 30 MINUTES OR SO. SINCE THEN FREEZER COOLS FINE BUT NO COOLING TAKING PLACE IN REFRIGERATOR COMPARTMENT. THIS UNIT IS A KITCHENAIDE WITH FREEZER BELOW REFRIGERATOR
    Problem Solver:
  • 9 Answers
Try moving the air flow setting in the refrigerator up higher. I know my beer wasn't that cold before and moved the setting from 2 -6 and that made all the difference
Posted on Jan 02, 2009
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/STAT@coldest temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Jan 03, 2016 | Refrigerators
Fridge freezing up
Set your Ref/Freezer per the following:
Refrigerators:
36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
You have to wait about 4 hours for everything to stabilize. If you are still having ice forming inside the freeezer then the rubber seal around the door is probably the problem. If they have a split, tear or crack, etc. it will let warm moist house air into the freezer and turn to ice as it cools. If this happens in the refrigerator it'll turn to water and collect in the bottom of the frig. New seals can cost around $60 per door.
If you pack too much food in the unit it may also cause freezing because the air needs to move around in there and food shouldn't block the vents in the back walls of the unit.
Hopefully this helps..
Nov 23, 2012 | Spartan Showcase Self Service Cigarette...
Gbs20hbsww bottom freezer the freezer gos below 0 but the upper refrigerator stays at 60 I replaced the evaporator fan motor but it will only make 1/4" turns the damper door makes a clicking...
check the damper control on the freezer the refrigerator section gets it's cold air from the freezer sometimes the air damper needs adjusting or replaced
Nov 17, 2010 | GE GBS20HBSWW 30" 19.5 Cu. Ft....
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator temperature ins 50 and the freezer is 15. Is this the appropriate temperature? The butter is soft at this temperature
the fridge should not be above 40 degrees and the freezer not above 30. check back wall of freezer for frost. if so, coils are iced up and need to be defrosted. either take off back wall of freezer and melt ice with warm water or hair dryer, or unplug unit and let it set with doors open for a day. then clean up the water.
Jul 20, 2009 | Jenn-Air JCB2280HES Side by Side...
True 2 door reach in freezer
If its getting warmer or more humid where you are this is probably a sign of needing to clean your outer coils. Remove the panel covering the compressor and check the condition of the coils. Clean with a nylon brush or wire brush. Or blow out with compressed air.
If the outer coils look ok see if they feel warm up and down the sides. If they dont you may have a defrost problem. If they are warm recheck them in 30 minutes if still warm or warmer and no one has opened the door check the lite inside, and the fan inside (it will only run with door closed). Hit the switch and see if lite goes out and make sure the switch is being activated whith the door closed.
It could be low on refrigerant or an inefficent compressor but not laikey as much as these other items are.
The last thing is the thermometer could be reading wrong or out of calibration. Is it Electronic? Yes - Then its most likely one of the other problem before. If its mechanical (bi-metal) get another thermometer you trust or a new one and check it before you trust it. 2 of them telling you its 5'f then Id believe it other wise one or both of them are wrong.
Mar 12, 2009 | True T-49 Side by Side Refrigerator...
Freezer works refrigerator doesn't
Try finding the defrost timer and slowly click by click turn it just until the compressor stops. let it finish the defrost cycle. Let it run for about 3 hours then do it again. Sometimes if the frost builds up too much the defrost system can't handle it. If you can't find the timer, take out the food, unplug it and leave the doors open for at least 24 hours. Then plug it back in. It can take up to 10 hours to cool down completely. Use a thermometer. you should be around 38 degrees in the fridge and between 0 and 10 degrees in the freezer.
Jul 04, 2008 | GE GBS22HCR Bottom Freezer Refrigerator
Freezer still works refrigerator not getting cold
These are notorious for having the evaporator fan motor go bad. See www.AnyoneCanFixIt.com for the way to repair it with detailed step by step pictues...easy fix. Takes about 30 minutes or less.
May 21, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
159 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
