Question about Mitsubishi WS-48315 48" Rear Projection HDTV-Ready Television
Projection TV keeps shutting down
TV shuts down power after about 10-20 seconds. During this time the green projector flickers and is intense. After TV powers down I can turn it back on but it will shut down again after 10-20 seconds. I can do this repeatedly but it will never stay on.
  • 5 more comments
  • Anonymous Jan 05, 2008
    Our Panasonic projection TV will not stay on. When we get it to turn on it lasts for a few seconds and then shuts down.
  • wpollock592 Jan 23, 2009
    Just this morning I turned on my tv which is a WS-48315 and it keeps turning itself off after sometimes 10 seconds or longer or shorter. Anyone find any answers. Pictures seems to be fine the short time it is on
    Just this morning I had the same problem. Any answers?
  • Anonymous Mar 19, 2014
    TV shuts off at times and can not get it powered on unless it sits for about 15 to 20 minutes. There are times it runs without the incurring this problem
  • Anonymous Mar 22, 2014
    when it shut off I tried to turn back on it comes on for about 3 seconds then shuts off again
    tv shut off while i was watching it when i turn it back on it shuts right back off after about 3 seconds with no picture or sound
    My tv shuts down after a few seconds.
This turned out to be a normal function of the TV to shut down when one of the CRTs is failing (was green CRT) to protect the circuits. Even though TV was only 2 1/2 years old, Mitsubishi could not provide part. Bad Mitsubishi experience!
Posted on Jul 24, 2007
I just took my Mitsubishi WS-65315 65" in to be repaired for the same problem and was told that it needed a new main circuit board part number 930b899005 as was told they wanted to charge me $1100.00. So I told them not to do the repair and picked up my tv and found that same part at Sears parts for only $225.00. Some of these TV repair places are theifs.
2 Suggested Answers
  • 927 Answers
SOURCE: Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Posted on Sep 26, 2008
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
No Picture/No Sound
This is very possibly a power surge, can you tell me how many times the light blinks, you probably have a bad power board now if you had a power surge.
Aug 11, 2007 | RCA HD52W59 HDTV Projection Television
Unit will not stay on
Is the fan that cools the projection high intensity bulb running? This sounds like an overheating condition, there is a temp sensor that will shut the machine down if it senses the temp is to high and poses a fire hazard or further damage to the projector.
Jan 15, 2012 | Optoma HD80 Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
Tv shuts down after about 5 seconds
Sounds like the green CRT has a short.If you unplug the socket from the green CRT tube (the one in the middle) and power up the TV and it stays on then it will verify that you need a new green CRT.
Jan 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Good Day;
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Apr 27, 2008 | Sony KP-65WS500 65" Rear Projection...
Sony 2002, kpws500
Minium is the green picture tube need to be replaced, if you can take the front cover and access panel off there is a control with 3 focus and screen controls.
you can adjust the 3 screen controls to possibly get a little more time out of it before the crt's need to be replaced. careful if you turn them down too much there will be no picture, and if you turn them too high the tv will go bright and shut off
Apr 13, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony proj tv,sound,green pict few seconds then shuts down
could be three different things.
1. could be the crt itself as a tube with dfective phosphure wil do this
2. could be the vertical ic on the crt board
3. could be the focus pac.  located in front of tv with 6 adjustment knobs on it.
Oct 06, 2007 | Sony KP-41T65 41" Rear Projection...
Open Questions:
I own a Samsung LN40C630K1FXZA TV with no picture but has audio and backlights. I need help determining what boards to replace. I tried to watch some tutorials posted on YouTube and have the following information. The TV was starting to have an issue that while watching it the picture was seeming to get a little jerky like it wasn't refreshing fast enough. It wasn't always noticeable and I initially though it may have been a signal issue with our cable. Eventually we turned on the TV one morning, the picture came on and then disappeared after 2 or 3 seconds but we still had audio. I tried to pull up the menu screen and that was not visible. I performed the flashlight test and there are images visible with the light. I removed the back cover and took pictures of the attached boards and also saw that the backlights seemed to be working but did seem like they were not quite a constant consistantly light. They never completely extinguish but do seem to fluctuate in brightness slightly. I did not see any visible issues with any if the capacitors being swollen or blown and did not see any apparent burnt components or boards. Below are the readings I got from one board but I was not sure where to get the readings on the TCON board. Main PBA readings CN201 1. 18v. Actual 13.1v 2. Sw. Power Actual 13.1v 3. 18v. Actual 13.1v 4. 5v. Actual. Falling to -1.6mv 5. 5v actual. Falling to -1.7mv 6. 5v actual 5.15v 7. 5v. Actual 5.15v 8. ground actual 13.1v 9. Ground actual 13.1v Any help would be greatly appreciated so I can buy the right parts from you. Thanks, Chris
Jan 19, 2019 | Samsung Televison & Video
See all Mitsubishi WS-48315 48" Rear Projection HDTV-Ready Questions
Mitsubishi WS-48315 48" Rear Projection HDTV-Ready Television Logo
555 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
