Question about RCA F27615 27" TV
RCA 27 PIP remote
How do I use the remote for the RCA 27 inch TV. What settings are required to connect the laptop to the TV. I recently got a S-Video cord and connected to my laptop and the TV, still was not sucessful?
4 Suggested Answers
  • 56 Answers
SOURCE: PC to TV via S-Video
you can purchase an AV Scart Hub (a switching box/scart box),and connect all of your devices to your tv.
Posted on Apr 15, 2007
SOURCE: Instruction manual for RCA F27665
here is the link for the User Manual for the RCA F27655 Entertainment Series PIP
Posted on May 31, 2009
  • 6771 Answers
SOURCE: We have a 27 inch RCA TV Entertainment Plus PIP.
The tv has lasted ten years which is better than average, I find fixing anything after that time is not cost effective and the likely hood of additional breakdowns is extremely high, because you are dealing with parts that are ten years old. But to address your problem, when you first turn on the tv can you hear high voltage been generated, if yes! you have a video problem, If no! you have a high voltage issue that will involve the high voltage transformer and other parts tied into the horizontal output circuits. A tv technician is recommended to address the situation and I advise an estimate.
Posted on Jan 27, 2011
  • 431 Answers
SOURCE: no sound or video,only a crackling noise.rca 27
Problem in the high voltage circuit, check connections on flyback transformer and high voltage diodes on flyback to see if shorted,
Posted on Nov 12, 2011
0 characters
1 Points
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
Don't have original remote control. Somehow, a window for PIP opened, and I can't get it to turn off. Have a new sony remote RM-V310A, but the PIP button won't activate the remote. Any...
Many TV functions can be controlled from the on-screen menus using buttons on the TV itself. These include all kinds of settings however Sony did not include PIP in these menus. Therefore a valid remote is required to operate PIP. One thing you could try is removing the cable from the secondary input on the TV which provides the signal for the other picture. Without an input signal PIP may be disabled. Also, try buying a universal remote and setting the proper code for your TV. Original remote could be hard to find but may have one.
Aug 05, 2010 | Sony KV-27S45 27" TV
What channel does the TV need to be on to watch a
If your tv has input [rca connections] jacks, look at the original remote and use the input button.In some cases....pressing 00 on the remote will access an input. If you must a converter box...set your tv and the DVD player to channel 3.
Dec 25, 2009 | RCA F27442 27" TV
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have a sony trinitron XBR and the PIP won't turn off. Any help is greatly appreciated.
Please make sure that one input is connected to the UHF/VHF port of the TV and other is connected to composite or component ports. If you have connected likewise, please perform the steps below:
  1. Ensure the video source is turned on.
  2. Ensure the video source is connected to an available VIDEO input jack on the back of the television. IMPORTANT: The VIDEO 5 input cannot be used to view a program in the PIP window.
  3. On the television remote control, press the TV FUNCTION button.
  4. On the television remote control, in the PIP section, press the TV/VIDEO button to select the appropriate video input for the PIP window.
  5. If the issue is not resolved, connect the Audio/Video (A/V) cable from the video source to a different VIDEO input jack on the television.
  6. On the television remote control, in the PIP section, press the TV/VIDEO button to select the appropriate video input for the PIP window.
  7. If the issue is not resolved, replace the A/V cable.
Sep 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
No Original Remote , Which substitute
Required remote for your TV is available HERE.
Mar 06, 2009 | Zenith H27F36DT 27" TV
No connection DVD to G25189TK. No external channel set. (3 or 4)
to see the dvd video you should select the AVmode using your TVremote.if the wires are not properly connected you cant see the picture or video.try to connect the wires in the front panel or the back panel.try to connect the wires as per the notes given as audio input,video input etc.
Dec 06, 2008 | RCA G27647 27" TV
Harwa tv childlock code
For Harwa (also branded Logik) 54cm colour TV with remote RC-A07 showing blue screen with red lock in the corner, hold down "music" button on remote for 10 seconds to unlock.
Oct 24, 2008 | RCA TruFlat 27F520T 27" TV
Rca f27650 27"tv w/vport
The hdmi port is for high definition multimedia interface. You should be able to send standard video through the Vport to your set. (RCA phono jack and plug) Stargazer
Apr 21, 2007 | RCA F27650 27" TV
Apr 15, 2007 | RCA F27676BC TV
RCA F27615 27" TV Logo
23 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
