Question about Hoover U5172900 Fold Away Widepath Bagless Upright Vacuum
Cant reset pin code on awa set top box model 262
I dont have menu access frrom remote ,only basic functions, need to know how to reset it sow i can use the menu etc
the manual has a note that 7710 is master code but dosent tell you how and when to enter it
  • 1 more comment
  • Anonymous Feb 09, 2009
    can only get channel seven and no other channels ,cant get the menu up on the screen to re scan channels and apart from channel up and down no other buttons on the remote work
  • Anonymous Mar 21, 2009
    can only get ch7 no other button responds
  • Anonymous May 02, 2009
    My remote buttons don't work can't access the menu can only change chanels on the set top box.
How do i get access to the motor on a hoover vhv781c tumble dryer as i need to replace the capacitor
Hoover vision hd tumble dryer VHC680F 16/10/2012 ...
? 0:19
https://www.youtube.com/watch?v=WCiQ9qc2TWk
Oct 16, 2012 - Uploaded by Ben Smith
Ben did you manage to change the capacitor? I got the same problem but I cant actually get close enough to the capacitor to replace it!.
Nov 26, 2015 | Hoover Vacuums
CATHEDRAL ELECTRONIC SAFE 25EA CANNOT OPEN IT WITH MY CODE NEED THE RESET CODE
You can't, as there is no reset code available once the door is locked. It would be absolutely useless anyway if all a thief had to do was to ask on a public website for a bypass code. The only alternative way into the safe is via the override key (an actual physical key which fits into an opening hidden behind a removable plastic panel on the safe door).
If you cannot find the emergency key then you have just one fix: you must open the safe destructively. Fortunately, your model is just a budget-priced electronic strong-box rather than a true safe, so the top or sides can be easily be cut open using a grinding disc or by just drilling a few holes and joining them up with a cold chisel.
Note that it's not worth calling out a locksmith, they'll only cut the box open and the charge will be many time more than the cost of a complete replacement strong-box (you can buy a similar complete replacement for under £40 including postage from this seller).
Sep 19, 2011 | Vacuums
Sewing basic stitch is good on right side of fabric but looks like a wavy line on reverse
Hi. Chances are your upper thread tension may need to be adjusted, increasing it by very small amounts at a time (say one tenth of one whole number), see if the stitching on the bottom improves. Another possibility is that the bottom fabric is moving around. Try pinning top and bottom together with straight pins set at a right angle to the stitch line. A third possibility could be lower thread tension set to tight. If the lower tension screw is all the way in, this is likely your problem.
Aug 19, 2011 | Vacuums
My machine is only two months old and the power is now not getting to it. I have checked fuse, and the plug. On calling the shop they suggested taking the top plate off and pressing a re-set button. ...
Look throughly and patiently it is there, often it is hide and the hint for finding it is a pin hole. Where you need a pin needle to reach the inside reset button. You need a flash light, slowly look for it.
Just follow what they say, take the top plate off and find the reset button, there in your unit it is expose not hide, just be patience and you will find it.
Good luck.
Jun 22, 2011 | Vacuums
I have just purchased a second hand AWA CRD176X CD Clock radio that did not come with a manual and I am having trouble setting the time, alarm time etc. Can you please help out at all. Thanks in...
Hi Chris, is this the one?
Like most of this type, it should have a button named TIME, and another one named ALARM.
Then there should be one button named HOUR, and another one named MINUTE.
With the radio turned off, press and hold the TIME button, then tap the HOUR button until you reach the current hour, AM or PM.
Release the TIME button.
Press and hold the TIME button again, and tap the MINUTE button until you see the correct minutes.
Now repeat the same operation with the ALARM button, to set the time the buzzer or music should come on.
If you have any further questions please email me.
Subject: AWA CRD176X CD Clock radio
faxmando@yahoo.com
I can't make out the names of the buttons or functions from my image, so if you need any extra information, please send me a clear image of the top and front of the radio.
Thanks!
Jerry
May 30, 2011 | Vacuums
Cant get my rca remote to work on ,my sharp tv i need the code for sharp tv the model onmy remote is rcr311w
Not really sure what to do here, whether or not its a universal remote you are referring to. The attached is a link for almost any users manual for anything electronic. Hope it will help you find the users manual with the correct code. http://www.retrevo.com/support/HP-m8150-Desktops-manual/id/3167ag902/t/2/
Mar 21, 2011 | Vacuums
I need to replace the remote control (UC7083T) of my Hampton Bay Sidewinder 54 Ceiling fan. Could you pls tell me where to buy one? Thanks
You can buy a fan remote at Home Depot, Lowe's,or Menard's basically any one of the big box stores. If they do not have the one used with your fan,you buy a universal remote. Follow the instructions in the box make sure you shut the power off as you may get shocked or burn up he control
Feb 01, 2011 | Vacuums
Cant open roller assembly roller not spinning i dont see anything in the way
Turn the power head over so the bottom is facing up. On the bottom towards the back there are two holes (one on each side) where you can get to the access screws. Remove the two screws (you'll need a phillips screwdriver). With the screws removed you can now remove the top cover from the base by pulling out on the two clips on each side of the power head. With the top cover removed you can get to the belt and roller brush. If you need a belt for this model you can get it here:
http://www.vacbelts.com/20-5218-belt.htm
Don't forget to rate the answer!
Jan 07, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
I have an ipod touch and i forgot my password and now i dont know how to unlock it :(
There are other, more technical, ways to do it, but if you don't know what you're doing you'll break your ipod so I'll stick to the safe and easy official method:-
Connect your ipod to your host pc and run the itunes software. Click on the "restore" button (in some versions of the software it's labelled "reset to factory settings"); this will reset your ipod to the way it was when you first got it out of the box. You'll then have to re-sync all of your music back onto the device and if you have a jailbroken model you'll have to reapply the jailbreak.
If you want to see the alternative methods, then just search "ipod touch password reset". Some of them claim to reset the password only without having to start all over again but some owners report that their machines simply don't work afterwards.
Hope this has helped you, please take a brief moment to rate my reply.
Sep 06, 2010 | Vacuums
Hoover U5172900 Fold Away Widepath Bagless Upright Vacuum Logo
284 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
