Question about Microsoft Windows XP Home Edition
Printer spooler stopped
Tried starting the printer spooler from the services screen and came up with the following error :
Error 1075 "The dependency service does not exist or has been marked for deletion"
Help!!
  • 827 Answers
The spooler service is responsible for managing spooled print/fax jobs.
The spoolsv.exe file is located in the folder C:WindowsSystem32.In other cases, spoolsv.exe is a virus, spyware, trojan or worm! Virus with same name:
Backdoor.Ciadoor.B
VBS.Masscal.Worm (vbs)
Hacktool.Privshell
It might have attempted to 'replace' (not really, but sort of, in order to use it as a cover for DOS attacks) your original spoolsv.exe when your computer got infected.
The most likely explanation of your current problem is that Regcure had cleaned it up, or has marked it to be kept in it's vault.
Regcure actually did what it was supposed to so don't think there is a problem with that program, although I tend to use the registry cleaning option within nCleaner instead, as a lot of these 'Registry Optimizers' tend to do a 'Free Scan' then report 'False Flag errors' and try to charge people to fix them.
First thing to do is download Spybot, then, (in this order) install it, Check for Updates, download them, disconnect completely from the internet (completely, take out the ethernet cable, or turn of your wireless connection), Scan for Problems (takes 20-30 mins or so, let it finish and don't use your computer during this), Fix Selected Problems, press the Immunize tab, Press Immunize. Reboot.
Now you are free of Spyware. If you had a worm/trojan, you're antivirus software would have detected it. (I use Avast antivirus, it's free and does everything for you)
Now try to Start the Spooler Service in Service Manager again. If you still can't, then you need to replace spoolsv.exe, so your operating system knows what to do with the requests from the printer.
The only surefire way to do this is to try running scannow, to replace any missing system files, from yourWindows install disk. Put your install disk in the drive and hold the leftshift key until the drives lights stop blinking (will prevent the diskfrom auto loading), or let it load and then exit the install screen.Then click Start > Run > and type sfc /scannow (note there IS a spacebetween the sfc and the /)
This will start a scan of the system files and will replace any that it finds are missing.
Done!
Reinstall the printer and reboot if necessary.
Hope this helps!
Chris (ziraffa)
PS I don't know if it is possible to do this, but if you don't have a Windows install disk, then you might want to try copying the spoolsv.exe file from C://Windows/System32 in another computer that is running the same operating system and pasting it into the same folder on your computer. I've never tried this, but it is what I would try if I definitely could not load a Windows install disk in this situation. Definitely try and use a disk first though, if at all necessary.. :)
Posted on Jan 02, 2009
  • chris grams
    chris grams Jan 02, 2009
    Oh, and you won't need to disconnect from the internet every time you use Spybot, it's just in this case there is a (remote) possibility that the problem originated from a dodgy file involved in executing DOS attacks.
Hp c6180 all in one printer displays error 0x000000aa is there a fix for this
The names of places on your computer may vary depending upon your version of Windows but you essentially have to do the following...
-Go to "Devices and Printers" right click the printer and select "Use Printer Offline"
-Stop the Print Spooler Service. The rough path for this is as follows:
Start>Control Panel>Administrative Tools>Computer Management>Services and Applications/Services
-Now double-click Print Spooler and click Stop
-Now click Start
-Now right click your printer again and select "Use printer offline" again
The error should now be history.
Dec 01, 2012 | Office Equipment & Supplies
Printing sitting in queue wont print
The print spooler may not be working.
Start and stop the print spooler Windows XP
To start and stop the print spooler open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management. In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler. Do one of the following depending on the task you want to do:
Click Stop to stop the service.
Click Start to start the service. When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK
Aug 28, 2012 | Brother MFC-290C Printer
Print spooler subsystem stopped
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Office Equipment & Supplies
Hi i have aprob my computer say the printer spooler cannot running error 1068
Check for other Service Dependencies A 1068 is a service dependency error. Print Spooler can't start because it thinks a service it depends on is not running.
shortcut: start-run-"services.msc"
Go into services and check its dependencies, it should just be the RPC service, which you shouldn't be able to stop, check that RPC is running
Double click print spooler and click the dependencies tab. See if there are any other dependencies set besides rpc. If so you will want to find them in services and make sure they are set to automatic and are running (will probably need to start them).
Then try to start "Print Spooler" service, should work. May need to reinstall printer drivers then.
Apr 21, 2009 | Computers & Internet
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
Error 1068 on vista print spooler stopped
Please follow the below given steps to remove the dependencies.
1.Click start icon.
2.Click on All Programs.
3.Click on Accessories.
4.Click Run.
5.Type cmd and hit enter.
To remove this dependency all you have to do is open the command prompt and type in the following command:
Please type Sc*config*spooler*depend=*rpcss (put spaces where the (*)’s are.
When you hit enter you will get this message:
Sc config spooler depend= rpcss [SC] ChangeServiceConfig SUCCESS
Now please restart the computer and try to install the printer.
Aug 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP print spooler problem and error 1068. Want my printer back!!!
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at dabesderis06@gmail.com
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
ahah..first things first...what Windows Operating system do you have...??
Feb 10, 2008 | Lexmark X1270 All-In-One InkJet Printer
Microsoft Windows XP Home Edition Logo
163 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
