Question about Saeco Magic Comfort Plus Espresso Machine
Got an old saeco magic comfort 7/8 years old -
Just started reusing the machine and dont know how to decalcify the machine as cant find the manual!  Any help would be appreciated
  • 2,039 Answers
Bye a good coffee descaler not vinager follow instruction on it normally fill the water tank leave room for the descaler start the machine open side valve leave it running for 15 second turn it off let it site for 10 to 15 minute after open valve for 30 second let it site for 10 minute and open valve repeat untill empty tank after clean water tank very good that descaler is acid nasty stuff after fill the water tank full of water start machine open side valve empty water tank that its good luck pierre p.s it take a while do descale good but worth it
Posted on Jan 10, 2009
My nespresso Larissa only drips a small amount when I press the large cup button?
After starting the machine press all 4 lit buttons on the top of the machine simultaneously for a few seconds. That will reset the volumes to factory settings. Decalcify your machine according to the manual provided with the decalcifying kit and the special nozzle for the milk steamer.
If if that does not work fill the water tank and the (clean) milk frother container with the 50/50 decalcifying solution + water and install as usual for making cappuccino (without a coffee capsule). Turn on machine and when the buttons light up press the large cappuccino button. Instead of cappucino you will get hopefully any of the residue from the entire system flushed out. Repeat until you used up the decalcifying solution in both containers. Discard and rinse a couple of times with clear water in both containers. Good luck - worked for my machine.
Oct 11, 2014 | DeLonghi Coffee Makers & Espresso Machines
Gaggia syncrony digital DECALCIFY, I done the prosess but i have the worning about DECALCIFY
You must use the correct tablets for this, gaggia make special decalcifying tablets.
The machine must be cold when running the program.
It takes about an hour to run the solution through the machine.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Gaggia Syncrony Compact Digital Espresso...
Is there an easier was to decalcify the capresso 3000 than taking apart the whole machine. The directions say you have to remove the auto cappuccino assembly
Yes
You should run the decalcify program with the JURA decal tablets or DURGOL. Do not use other agents.
See page 25 of user manual.
Many thanks
Feb 14, 2011 | Jura Capresso C3000 Espresso & Coffee...
On the screen it is written decalcifying.How do I fix this?
This is a pretty sophisticated coffee maker.. the manual goes into great detail about set up for entering water hardness and descaling messages. There is a discussion about the decalcifying procedure, but none the mentions a decalcifying message.
You should re-read the manual and possibly re-enter the programming again. The manual is available for free, here. Pay particular attention to sections 15, 16a, 20c and 22. These sections are only a paragraph long, but will help explain the filters, decalcify procedure and decalcification tablets.
Please rate this reply - thanks!
Dec 03, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
You are correct to descale the machine. I am not sure how "decalcification" is different, but if the message is still coming up, you may need to have some repair work done. There are some sensors inside that can be cleaned manually if a descaling solution doesn't do the trick. You can do some work if you are mechanically inclined.
Jan 20, 2009 | Saeco Magic Comfort Plus Espresso Machine
Decalcify
im not a saeco folks but i buy those machine on ebay and repair them decalcify ready to used mean its ready for you to put descaling product in machine and you press on it will start the descaling sequence if you dont whant to descale i sujject you do it if not go in our menu and push botton untill you see descaling finish or done thanks pierre p.s taking about descaling my machine vienna told me this morning time to descale it comme about every 3 months let me now i know those machine good
Jan 10, 2009 | Saeco Incanto Classic Espresso Machine
Decalcify
when the machine gives the signal press the bottom right hand button for 5 seconds.
it will tell you to open the knob.
before you open the knob fill the water tank with the descaling solution
place a large water receptacle under the steam wand.
now turn your knob
the machine will start to descale this can take a while
when the descale cycle is finished close the knob.
rinse the water tank out with fresh water and fill it will clean drinking water.
Press the same button on the bottom right to confirm that yo are doing the rinse cycle.
open with knob and the machine will start the rinse cycle.
when the rinse cycle is complete close the knob and load the circuit.
when descaling is over fit a new cartridge filter in your water tank and off you go with your descaled cleaned coffee machine.
May 21, 2007 | Saeco Incanto Classic Espresso Machine
What does Decalcify mean?
You can download the manual for free. Search for the manual.
If you want to decalcify, then you need to get decalcifying solution. The button with two circles is the decalcify mode. Press that, and the unit will go through it's automatic decalcify. There is a specific procedure to best decalcify superautomatic machines. Please search for that.
After this is done, the decalcify message will not appear. It is on a preset schedule, not an actual measurement of how much scale is in the machine.
Although you don't have to decalcify, it is recommended, especially if you live in an area with hard water.
May 14, 2007 | Gaggia Titanium Espresso Machine
Saeco Magic Comfort Plus Espresso Machine Logo
201 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
