Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
Vhf MTS 2000
When i power up the radio it starts with the start up tone but then continues that tone which is like a two tone one a bit quieter than the other.It does not display any error codes.I have had this problem once before but cannot remember the procedure to fix.It was third button down pressed several times over from my memory!!!
Any ideas would be greatly appreciated.
Cheers
  • 4 Answers
Check the boards at http://www.batlabs.com ....
Wolfy
Posted on Feb 07, 2009
My baofeng radio will transmit but will not reseive
Check your settings for the RX frequency. Then check to see if the RX Tone is turn on and is set to the correct frequency. Just turning the rx tone off should allow you to hear any station coming in.
Aug 06, 2014 | Dual Uv-5r Baofeng Band Uhf/vhf Radio Usb...
Chanel lock
The Kenwood TK-3312e is a EU version of that handheld If you truly have that model# 3312e and not a TK-2312e.
Then you don't have VHF here the specs for the posted model# you gave.
Frequency Range: 400-470 MHz 5 Watt RF Output 128 Channels/128 Zones Built-In Voice Scrambler QT, DQT, DTMF and 5-Tone Signalling FleetSync Digital Signalling, PTT ID and SelCall MDC-1200 Signalling PC Programming
Jul 01, 2014 | Kenwood Tk-2312e / Tk-3312e vhf / Uhf...
Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Feb 01, 2010 | Motorola GP300 Compatible 2 Way Radio...
Motorola MTS 2000
Motorola may be able to tell you if you call them, but they may refuse.
If your radio has a front display, you can put it into test mode to see what firmware it has. If it is 5.44 or higher, then it is FlashPort.
You access the service menu by pushing the button with two dots (on the side above the PTT) 5 times quickly after the power-up beep. If you have no front display this is useless.
Jan 01, 2010 | Radio Communications
Mts 2000 vhf constant tone
The scan is on and you do not have a scan list programed.
This is the most common problem connected to your post. Hope that helps, Bill.
Jan 02, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
How to prograqm a motorola mts 2000 flashport?
1. Program the ABC switch as zone select.
2. Program each 'personality' into the proper zone (eg A1, A2..., B1, B2..., C1, C2..., etc)
3. Load the codeplug into the radio.
May 27, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
INEED HELP
A Motorola MTS2000 is a government issue 2-way radio, hence user manuals are restricted. You can try ordering them with Motorola (800‑422‑4210). I was made to understand that manual part number starts with “68” and ends with a “-O”. Version would depend whether you have the I, II, II versions in either VHF, UHF, 800 or 900 MHz.
Since this is your 2nd posting of this model and based on your profile however, I would assume that your requirement is technical in nature (field programming, repair, maintenance, etc), perhaps a Service Manual would fit you better.  It is available   here in pdf. A Spec Sheet is  here  likewise in pdf.
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
Oct 26, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
