Question about Acer Aspire 4720 Notebook
Want to load Win XP on my Acer 4720z laptop - Acer Aspire 4720 Notebook
  • Claudiu May 11, 2010
    be more specific, please!
  • 4 Answers
Step 1 - Start your PC and place your Windows XP CD in your CD/DVD-ROM drive. Your PC should automatically detect the CD and you will get a message saying "Press any key to boot from CD". Soon as computer starts booting from the CD.
Step 2 - At this stage it will ask you to press F6 if you want to install a third party Raid or SCSI driver. If you are using a an IDE Hard Drive then you do not need to press F6. If you are using a SCSI or SATA Hard drive then you must press F6 otherwise Windows will not detect your Hard Drive during the installation. Please make sure you have the Raid drivers on a floppy disk. Normally the drivers are supplied on a CD which you can copy to a floppy disk ready to be installed. If you are not sure how to do this then please read your motherboard manuals for more information.
Step 3 - Press S to Specify that you want to install additional device.
Step 4 - You will be asked to insert the floppy disk with the Raid or SCSI drivers. Press enter after you have inserted the disk.
Step 5 - You will see a list of Raid drivers for your HDD. Select the correct driver for your device and press enter.
Step 6 - You will then get a Windows XP Professional Setup screen. You have the option to do a new Windows install, Repair previous install or quit. Since we are doing a new install we just press Enter to continue.
Step 7 - You will be presented with the End User Licensing Agreement. Press F8 to accept and continue
Step 8 - This step is very important. Here we will create the partition where Windows will be installed. If you have a brand new unformatted drive you will get a screen similar to below. In our case the drive size is 8190MB. We can choose to install Windows in this drive without creating a partition, hence use the entire size of the drive. If you wish to do this you can just press enter and Windows will automatically partition and format the drive as one large drive.
However for this demonstration I will create two partition. The first partition will be 6000MB (C: drive) and second partition would be 2180MB (E: drive). By creating two partition we can have one which stores Windows and Applications and the other which stores our data. So in the future if anything goes wrong with our Windows install such as virus or spyware we can re-install Windows on C: drive and our data on E: drive will not be touched. Please note you can choose whatever size partition your like. For example if you have 500GB hard drive you can have two partition of 250GB each.
Press C to create a partition
Step 8 - Windows will show the total size of the hard drive and ask you how much you want to allocate for the partition you are about to create. I will choose 6000MB. You will then get the screen below. Notice it shows C: Partition 1 followed by the size 6000 MB. This indicates the partition has been created. We still have an unpartitioned space of 2189MB. Next heighlight the unpartitioned space by pressing down the arrow key. Then press C to create another partition. You will see the total space available for the new partition. Just choose all the space left over, in our case 2180MB.
Step 9 - Now you will see both partition listed. Partition 1 (C: Drive) 6000MB and Partition 2 (E: Drive) 2180MB. You will also have 8MB of unpartitioned space. Don't worry about that. Just leave it how its is. Windows normally has some unpartitioned space. You might wonder what happened to D: drive. Windows has automatically allocated D: drive to CD/DVD-ROM.
Select Partition 1 (C: Drive) and press Enter.
Step 10 - Choose format the partition using NTFS file system.This is the recommended file system. If the hard drive has been formatted before then you can choose quick NTFS format. We chose NTFS because it offers many security features, supports larger drive size, and bigger size files.
Windows will now start formatting drive C: and start copying setup files
Step 11 - After the setup has completed copying the files the computer will restart. Leave the XP CD in the drive but this time DO NOT press any key when the message "Press any key to boot from CD" is displayed. In few seconds setup will continue. Windows XP Setup wizard will guide you through the setup process of gathering information about your computer
Step 12 - Choose your region and language.
Step 13 - Type in your name and organization.
Step 14. Enter your product key.
Step 15 - Name the computer, and enter an Administrator password. Don't forget to write down your Administrator password.
Step 16 - Enter the correct date, time and choose your time zone.
Step 17 - For the network setting choose typical and press next.
Step 18 - Choose workgroup or domain name. If you are not a member of a domain then leave the default settings and press next. Windows will restart again and adjust the display.
Step 19 - Finally Windows will start and present you with a Welcome screen. Click next to continue
Step 20 - Choose 'help protect my PC by turning on automatic updates now' and press next.
Step 21 - Will this computer connect to the internet directly, or through a network? If you are connected to a router or LAN then choose: 'Yes, this computer will connect through a local area network or home network'. If you have dial up modem choose: 'No, this computer will connect directly to the internet'. Then click Next.
Step 22 - Ready to activate Windows? Choose yes if you wish to active Windows over the internet now. Choose no if you want to activate Windows at a later stage.
Step 23 - Add users that will sign on to this computer and click next.
Step 24 - You will get a Thank you screen to confirm setup is complete. Click finish.
Step 25. Log in, to your PC for the first time.
Posted on Jan 02, 2009
Acer aspire 4720z
The best I can do for you:
Download Driver Acer Aspire 4720Z Windows vista 7 XP
PS this message to you was written on an Acer 4720z !
Nov 24, 2017 | Computers & Internet
Acer aspire 4720z audio driver for widows xp home edition sp2
welcome to fixya
the only thing i could tell you is to try to reupdate the divers through the device manger if this does not work then you might of blown the soundcard in the machine
hope this helps you out sorry not better news
have a goodday :)
Jul 26, 2008 | Computers & Internet
I download acer 4720z drivers
hi u can download all the Drivers for Acer 4720z series
Acer Aspire 4720
http://support.acer-euro.com/drivers/notebook/as_4720.html
i hope this helps u solving ur problem
Best of Luck
Jul 16, 2008 | Computers & Internet
Have you gone to the acer site? and second question I too have an acer and I got rid of Vista is this what you did or did the computer come installed with xp. If it did make sure you have the Microsoft hdd coded driver installed. It is available by googling "hdd audio driver" it will send you to microsoft to download. Also make sure you have completely deleted the previous software before loading the new one they will conflict and load on top of each other. Hope this helped..Take care.. Be mucho blessed..Mark
Jun 27, 2008 | Computers & Internet
i know some of that specific laptop and most as their brand. go to their website and try redownloading the audiodriver for that laptop. i have more information so please email me if you have any more questions, please email me at meanness628@aim.com
Jun 21, 2008 | Acer Aspire 5100 Notebook
Cannot install Windows XP Professional on Acer Aspire 4720Z Laptop
yu need to go to the the bios before you start the installation and change the Sata hard disk mode to IDE.then it will detect the hard disk.
May 05, 2008 | Acer Aspire 5610-4648 Notebook
Not connecting to Internet in Acer 4720z
cheak for firmware update on roughter software for vista ect ok thx nick
Feb 06, 2008 | Microsoft Windows Vista Ultimate Edition
Drivers for xp
i want all the drivers of acer aspire 4720 for winxp.
Dec 23, 2007 | Acer Aspire 4720 Notebook
is there any other way to solve the audio problem? after i install win xp sp3 in my acer aspire 5550,i get stuck in installing audio driver.i have download the driver from many website even in acer.com, but still cant solve it..please give me some idea..
Dec 02, 2007 | Acer Aspire 4720 Notebook
Acer Aspire 4720 Notebook Logo
177 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
