Question about Whirlpool RBS275PD Electric Single Oven
F03 on display panel of whirlpool single oven
Have no instruction manual
  • roger333 Mar 01, 2009
    i have F03 on the display panel
Whirlpool oven fault f03
Hi
Code F03 usually means that the oven temperature sensor is 'open circuit', that is not working at all.
The remedy is to have it replaced.
Dec 19, 2010 | Whirlpool AKZ159IX Oven
How do you remove the control panel from the RBD305PDS14 double oven?
Here is the service manual for this unit. The instructions for removing the control panel start on 4-2.
Service Manual
May 21, 2010 | Whirlpool RBS245PDS Electric Single Oven
Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
My whirlpool generation 2000+ oven it says f03 what does this mean
This means you have a bad temperature sensor.
This is a very simple part to replace so you will save a ton of money by replacing this part on your own.
Oct 18, 2009 | Whirlpool RBS275PD Electric Single Oven
F03 Displays
I bought a new oven found this one way to complex anyway. Afterall i just want to cook in it.
Regards
Ken Mc
Sep 14, 2009 | Whirlpool RBS305PDS Electric Single Oven
I bought a Whirlpool double oven AKZ161 and error code F03 appear
On this model, F03 indicates a faulty power control board (also known as the "Capricorn" board by Whirlpool technicians). A new oven with no guarantee? There is usually a reason something has no guarantee, in your case, a faulty control board. It is a relatively expensive part unfortunately.
You can try disconnecting from power, removing top panel from oven. The large square electronic board you see on the top of oven is the power control board. Check all plug connections are OK, especially the large thin multi plug that goes to the display board- I have had a poor connection at this plug causes F03 faults. If still no go, power control board will need replacing
Aug 17, 2009 | Ovens
Whirlpool range gas model GS445LEMS
i have the same problem oven comes on but goes back off. help
Jun 26, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool oven fault f03 shown
f03 error is a sensor error.you could have taken an ohm reading on the thermistor to see if it was bad.if you replaces the t-mistor then the only other component responsible is the board.make sure all the connections on the board are clean and tight before you replace it.
Sep 28, 2007 | Ovens
Whirlpool RBS275PD Electric Single Oven Logo
769 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
