Question about Electrical Supplies
Engin swing but do not start
Engin overheated, fuel at all 4 injectors, engin swing smoke but do not start. can the comp. be to low or maybe the rings colapssed. i am in the middel of africa and no comppression tester.
thank you
You could have a couple cylinders damaged or possibly a warped head lettind all the compression loose through the cooling system. Can you check the pressure on the cooling system with a radiator pressurizer while cranking the engine over? If it starts building pressure immediately, the compression is going into the cooling system. otherwise it is going into the crankcase and you will need to rebuild or replace the engine at that point.
Posted on Jan 08, 2009
Why is the engine emmitting black smoke when driving
black smoke is excessive fuel in the air fuel ratio
causes leaking gaskets under injectors, problem HO2S sensor , blocked air inlet /filter, excessive fuel pressure
possible cause --mechanic did not use new gaskets under injectors that were damaged form the overheating
Jul 29, 2016 | Cars & Trucks
Injector sprays too much fuel after starting. Engine floods out
Suspect (potentially) either a stuck injector, or a failed/failing fuel pressure regulator. One sign of a failed fuel pressure regulator can be gas in the oil. (I suffered that side effect, along with bogging, and black smoke rich running, worsening as warmed up, turned out to be fuel pressure regulator). If the injector is loose in the throttle body, or has bad o-rings, can also cause some wonky behavior. Good luck.
Mar 14, 2015 | 1992 Geo Tracker
Excessive white smoke from tail pipe
White smoke:
White smoke is caused by raw, un-burnt fuel passing into the exhaust stream. Common causes include:
·Incorrect fuel injection timing
·Defective fuel injectors
·Low cylinder compression
Low cylinder compression may be caused by leaking valves, sticking piston rings, ring wear, cylinder wear, or cylinder glaze. When white smoke occurs at cold start and then disappears as the engine warms up, the most common causes are fouling deposits around piston rings and/or cylinder glazing.
Continuous evidence of white smoke indicates a mechanical defect, or incorrect fuel timing.
Jan 25, 2015 | Chrysler PT Cruiser Cars & Trucks
Low power, blue smoke, engine cutting
blue smoke indicates oil is burning in the cylinders. This is either leaky valve seals, (little blue smoke when engine first starts, but stops smoking shortly after) or the worse problem, worn rings. What happens is when your rings are worn, they let oil get past the rings and into the combustion chamber, AND it also lets out your combustion pressure (your power source) into the crankcase, so you have considerable power loss. Only way to fix worn rings is to rebuild the engine, as just replacing the rings would require complete teardown of engine anyways, and who wants new rings in a worn out motor.
Dec 17, 2013 | 2006 Volkswagen Jetta
Black smoke
Is it a turbo engine. What size engine. How old is the car.
Dec 09, 2013 | Ford Ranger Cars & Trucks
Smoking on acceleration after overrun
Maybe a leak-down test on number 4 could find it. Cylinder wall wear, maybe?
At least you got a good head if you have to rebuild the engine, that is, if worse comes to worse.
Jul 11, 2013 | Cars & Trucks
1984 Honda GL 1200 Aspencade Gold Wing pumping white smoke out the exhaust
Hi, Paul your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is at the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on start-up is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on start-up may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on start-up is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1984 GL 1200 White smoke
overheating GL1200 Information Questions goldwingdocs com
Honda GL1200D Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda GL1200 1986 Owner Manual
Oct 05, 2011 | 1984 Honda GL 1200 Aspencade Gold Wing
My truck f 350 It's having trouble starting and wen It's starts blows a lot of black smoke It's giving me a diagnostic that says It's cylinder 4 injector circuit low
Most likely you have the #4 injector sticking open letting fuel drain into the cylinder when not running and causing a possible hydralock situation. An engine cannot compress fuel. If its not fixed soon you could end up having a bent rod. The #4 injector is the second one from the front on the drivers side.
Apr 26, 2011 | 2005 Ford F 350 Super Duty
Why engine exhausted blue,black and white smoke
ENGINE SMOKES BLUE THE ENGINE BURNING OIL DUE TO WORN PISTON RINGS , WORN VALVE GUIDES AND SEAL./ ENGINE SMOKE BLACK ENGINE GETTING RICH FUEL MIXTURE CAUSED BY DIRTY AIR FILTER, WEAK IGNITION SPARK, FAULTY FUEL PRESSURE REGULATOR OR LEAKING FUEL INJECTOR, EVAP CANISTER GAS SOAKED./ ENGINE SMOKING WHITE ENGINE BURNING ANTIFREEZE DUE LEAKING INTAKE GASKET OR BLOWN HEAD GASKET. IF ENGINE HAS A LIGHT WHITE BLUE SMOKE ENGINE BURNING TRANSMISSION FLUID DUE TO A RUPTURE VACUUM MODULATOR DIAPHRAM ON TRANSMISSION.
Nov 20, 2010 | 2003 Hyundai Accent
2004 yamaha ttr225 smoke's really bad out the exhaust and oil goes threw dont know where but come's out the exhaust,have changed the valve seals and all ring's and head gasket but still same problem,what...
Hi, Pauljackson your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
2004 Yamaha TTR 225 burning LOTS of oil
Yamaha TTR 225 Smokes BAD
http://tjsconcepts.com/ttr225/TTR225_Service_Manual.pdf
OEM parts for Yamaha
Yamaha TTR225S Owner Manual
Oct 23, 2010 | 2004 Yamaha TT-R 225
Electrical Supplies Logo
54 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
