Question about HP Photosmart C6180 All-In-One InkJet Printer
HP software that enables networking is not responding
  • 495 Answers
My guess would be to install the HP software once again just to check if software has got corrupted.
Posted on Jan 02, 2009
2 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: HP officejet 6500 E709n while being installed
Using the HP Network Diagnostic Utility in Windows - HP Customer Care (United States - English).
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 16, 2010
How to troubleshoot HP Printer not found during network driver setup issue in Windows Operating system?
Download the full feature software from the HP website or on the software disc and setup your printer for wired or wireless network connection.
There might be one of the following errors if the installer does not detect your printer after setting the connection type.
1.Printer not found
2.Devices not found
3.Unable to find the printer
During the Hp printer network setup, there may be some troubleshooting issues,
Step 1: Reset or restart your computer, HP Officejet printer and the router
1.Disconnect the power cord outlet from the router.
5465_install_1a-ur23imwvkexuk45mistkg3hp-5-0.gif 2.Close all the tabs running on your computer and shut down your computer.
3.Then turn off the HP Officejet 4650 printer.
4.After few minutes reconnect the power cord outlet to the printer and wait till the connected status light blinks to normal.
5.Then turn on the printer and computer.
6.Again install the HP driver and software.
Step 2: Check the status between the printer and the network connection.
Before the setup confirm that your printer is ready.
1.Wireless Network: On the printer, open the wireless network connection settings menu and check whether the wireless signal is turned on.
2.Wired Network: Check that cable is connected to the printer Ethernet port.
Note: The green light should be in steady status and the orange link should blink when the cable is connected and make sure that your HP printer is not connected to a guest or host network.
1.Set the band to 2.4GHz if it is dual band router else the printer cannot connect to the network.
2.Check the network name and status of the connection in the notification bar.
3.If it is a different network then reconnect your network to complete the setup.
4.Move the computer and HP Officejet 4650 printer closer to the router if the signal is weak.
5.Slide the Airplane mode to off if it is on.
6.And again try installing the software and driver.
Step 3: Run the HP Print and Scan Doctor:
1.HP provides a free tool called HP Print and Scan Doctor to resolve the scanning and printing issues.
2.Download the HP print and scan doctor software to resolve all the troubleshooting issues.
3.After the installation on the Welcome screen click start.
4.A new menu box appears on the screen with the printer list. If your printer is not listed then turn on the printer again and connect it.
hpscanprinter-ur23imwvkexuk45mistkg3hp-5-2.png 5.Click the option my product is not listed and then select retry.
6.After that, your printers display and select it.
Step 4: Temporarily disable firewall software.
If the firewall software is installed on the computer that will help you to block the threats that found on your computer.
Use the print and scan doctor to identify and temporarily disable firewall software on your computer.
1.Click network on the print and scan doctor window.
2.A drop down box appears in that select the option troubleshooting firewalls.
3.Click the firewall software to disable it.
4.And install the HP driver and software.
If the HP driver is successfully installed then consult the firewall software support to change the settings as security level, trusted zones. After changing the settings re-enable the firewall software.
If the HP driver is not installed then there is no issue in firewall software and re-enable it.
Step 5: Uninstall and reinstall the HP drivers and software.
1.Disconnect the cable if your HP Officejet 4650 printer is connected to the USB cable.
2.Click programs and features in the search windows.
3.A list of installed programs will be displayed click your printer name and uninstall it.
4.Then follow the on-screen instruction to complete the process and restart your computer and reinstall the software from the official site.
If you still have doubts regarding this setup you can call us @1-800-836-3987 or visit us 123 hp setup oj 4650
Jul 06, 2017 | HP Office Equipment & Supplies
Wireless button on computer not coming on with switch
If the switch is not responding you can try using the software side to turn it back on. As long as you are on windows you can go to the Control Panel, click on "Network and Internet", "Network and sharing center", Then find "Change adapter settings" along the left menu. You should see your wireless card listed, and disabled, to enable it right click and chose "enable"
Oct 10, 2012 | Gateway Core i5, 4GB RAM, 1TB HDD Mini...
I keep getting an error message indicating that my wireless device is disabled. It's a HP mini. for work serial CNF0260923. HP MIni 210 - 1076NR
If you get that message, believe it.
You will have to enable it either through the software switch or a little switch that some computer manufacturers place on the computer case.
The first thing you can do is open your network connections and see if you can see the wireless connections. If it says disabled, you might be able to right-click on it and enable it.
You can also look in the control panel to see if the HP wireless assistant can be accessed through there (or possibly through the programs list).
Mar 24, 2011 | HP Mini 1000 Netbook
My laptop can't get a wireless connection. Won't let me click on the HP wireless assistant. In the BIOS; should "network adapters" be enabled or disabled?
definitely enabled. also check your device manager if there is a bang ( yellow or red mark) at the side of the icon under network adapters. if so, download the latest network driver from HP website.
Mar 31, 2010 | HP Pavilion dv6000z Notebook
Vista laptop does not see HP cpu on the network. It does see all the other cpu's but not HP. All other's including the HP are XP based. All are on the same Workgroup. I can ping each other and it responds...
You may wish to consider running the set up a network wizard to ensure file sharing is enabled on the HP machine, making it discoverable to the vista laptop.
Sep 22, 2009 | HP Computers & Internet
My HP mini laptop will not connect to my wireless network.
check you wireless router settings if the wireless is enable on the router then , if this is done disable the firewall on your wireless laptop and if you cannot still connect to the wireless uninstalled and reinstalled your wireless driver software.
Adeyiga Shitu
Apr 17, 2009 | HP MINI 2133 NOTEBOOK PC - 1.6GHZ PC...
Network adapter
I need network adapter software for hp presario V6000
Dec 31, 2008 | HP A6795A#0D1 Network Adapter
Internet connection light
Help & Support has everything that's in the owner's Guide. Just ask it.
Top left button, above the keyboard, is Wireless On/Off.
If nothing happens, go to CONTROL PANEL / NETWORK CONNECTIONS. R-click on Wireless Network Connection. L-click DISABLE. Wait about 5 seconds, do it again and L-click ENABLE. That should reset the modem and get things going.
After you establish an internet connection, go to START / PROGRAMS / HP / HP (SOFTWARE) UPDATES and install the latest patches. They will include aa newer version of HP Wireless Assistant
Good luck.
Jul 11, 2008 | HP Compaq Presario V5000Z Notebook
HP Photosmart C6180 All-In-One InkJet Printer Logo
681 people viewed this question
Ben Johnson
