Question about Nokia 6681 Cellular Phone
Battery low get a code which can give me atleats 50% of battery charged
Battery can low after attending 4 to 6 calls per day after full charging
Posted on Jan 07, 2009
  • gr8shrey Jan 07, 2009
    battery can low after attending 4 to 6 calls per day after full charging
    Master:
  • Nokia Master
  • 443 Answers
This app can help to charge the phone fast, hide images/videos, really great security app en Google Play Store LEO Privacy Applock Hide Safe Android Apps on Google Play
Posted on Jan 17, 2017
  • 495 Answers
Use this code, it might work..
* 4 7 2 0 #
Posted on Jan 02, 2009
Why wont my charging system on my Troy-bilt RZT 50 charge the battery?
How old is mower? Perhaps if it is still under warranty, I'd take it back to Lowe's or at least, give them a call and explain your situation. They're pretty good about helping out their customers.
Jun 05, 2014 | Cub Cadet Garden
Honda pilot engine light
Sounds like you took care of the problem. A low battery can fool the computer, give wrong readings.
Nov 28, 2013 | Cars & Trucks
Code 12 1995 dodge spirit 2.5 battery and PCM NOT disconnected. where does the pin 3 on PCM gets its battery suppy voltage from
Has the battery been disconnected or been low on charge in the last 50 ignition cycles?
Code 12 means that battery power has been disconnected within the last 50 ignition cycles. it does not mean there is no battery power to the computer
Pin 3 should be a red/white wire that is the constat power supply to the PCM. It is protected by a fusible link located neer the drivers side strut tower. If that link was bad the car would not start or run as it also supplieds power to the asd relay, fuel pump relay, and the ssd relay.
I would put money on the the problem being igntion (plugs wires cap rotor), compression (low cylinder compression usually cylinders 2 and 3), lack of fuel delivery (low fuel pressure, a weak or dirty injector), timin (timing belt jumped, worn distributor, look exciter ring), or possibly a plugged catalytic converter.
I would check compression first especially cylinders 2 and 3. It was pretty common for the head gasket to fail in between these two cylinders.
Feb 24, 2012 | 1995 Dodge Spirit
Purchased a digital camera and after about 30 pics the camera won't work. you charge battery and it will start up and then go blank, and you have to recharge battery which only takes about 50 seconds. and...
no battery charges in 50 seconds??? try charging it for longer... or if it really is a 50 second charge lithium-ion battery (which i reckon would explode and set a decent area of your carpet on fire) then replace it since it is not holding its charge...
Your charger could be giving out too little voltage...
I dont believe it charges in 50 seconds for 30 pictures. thats more output than input? is it flubber powered by any chance?
Jan 21, 2010 | General Electric E850 Digital Camera
Car will start if using a jumper cable.. but acts like theres no power to the bater when i shut it off and try to restart it... fault code flashed 12 and then 55 on the check engine light...the haynes...
Check and clean the battery connections and if the battery is dead, charge it and load test it. If the battery doesn't take a charge, one of the cells in it may be bad and it will have to be replaced. If it tests good put it back in the car and go from there. Good luck.
Nov 08, 2009 | 1995 Dodge Stratus
Battery problem: P3400i
Sounds like its probaly the battery, they dont last forever, try here for a replacement - HTC P3300 battery
Jun 06, 2009 | HTC P3300 Smartphone
Car isn't starting
I was have this problem. Battery is low. Charge battery or use cable to start. You can check the problem using Diagnostic Trouble Code. Cycle ignition key On - Off - On - Off - On within 5 sec. The odometer will show teh P-code for the DCT code number. Error code for low battery is P0562. Only "DONE" displayed on odometer inicates that no DTCs are present (no error) and the procedure is completed. PCM memory has been cleared within the last 50 ignition cycles. Hello from Croatia.
Apr 29, 2009 | 1999 Chrysler 300M
Battery Low with NiMH (won't turn on) OK with Alkaline
Not the camera obviously - works OK Replace the NiMah batteries- get several sets and keep one set in the bag charged with one set in the camera. You may be able to 'refresh' the original batteries by putting them into a small flashlight and running them until the bulb goes out. This discharges them completely- then recharge. It is said batteries have a 'memory' so that a battery that is down say 50% and recharged will only recharge that 50% and the other 50% is lost for use. So you have to flatten the batteries completely
May 29, 2007 | Samsung Digimax A7 Digital Camera
Nokia 6681 Cellular Phone Logo
104 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
