Question about Nokia 5300 Grey Cellular Phone
Loose slider on phone is there a way to tighten
  • 34 Answers
Clarke, I am sorry to say that there is no way to tighten it.
Posted on Jan 02, 2009
Phazer gt yamaha
Raise the REAR of the Sled and keep it off the Ground
*** DO NOT OVER TIGHTEN ***
On the Rear of the Sled on BOTH SIDES there are adjustment Screws. You must align the opening in the Track, loosen the Jam Nut, then turn CCW to loosen and CW to tighten.
Are your Sliders worn out? Great time to replace them
Jan 09, 2014 | Winter Sports
Tip
Samsung phones
Hello there Samsung slider phones LCD or screen problem. Always you have seen that samsung phone get problem like some phone doesnt have light in LCD and some times they does not turn on. Samsung slider phones like G 600 , U 600 . J 700, E250 ,D800 and D900.Slider phones always has Ribben ( slidr belt ). And this ribben always connect phone upper part ( screen ) to the mother board.when the ribben (slider belt) got damage then it gives you that problem.it happens when you use your phone roughly or when you dropped your phone on concrete or any different floor.Mostly Samsung phone model U600 , G600 AND J700 has this problem.whenever your phone gets this problem firstly check. And Do not try any flashing or any kind of software tools. it easy to change ribben (slider belt ). Just get ribben belt or some tiny screw driver and some slider opener. this tools are easy to get from any tools shop. then mostly phone has screw. firstly open the battery cover and take it out and see two hole under the battery and when you slide up your phone then you can see two screw just under your phone top keypad just hold the slider for while and open those screw and slide up then see two rubber things are both side on camera. Use any flicker type things and take out that rubber top then you can see two screw just under the screw open those screw then use the slider opener if the opener is tight if slider is loose the do not use opener just take it out so softly and remove the one side of the ribben which you can see connected of mother board just take out ribben and put new one ribben the put all things back as a normal then tight the screws and put battery then turn it on your phone will turn on.some phone like U600 ,j600,has touch panel. this type of model slider belt or ribben always comes with touch panel and its quite difficult and quite expensive to change.Samsung U600 has this problem mostly because they are very thin and then slider belt is as well thin and they get this problem so quickly.
thanks
on Jan 08, 2010 | Cell Phones
Tighten track
NEVER OVERTIGHTEN a track.
Raise the Rear of the Track off the ground
Align the openings of the Track to gain access to the Adjustment screws
Loosen the Jam Nuts
CW to Tighten (make sure you do it evenly on both sides)
Did I mention NEVER OVERTIGHTEN a Track
Inspect your Sliders, right now is a good time to change them out if they are worn and the reason for the track being loose.
Jan 04, 2014 | Yamaha 2005 RS Venture
My sony ericsson slider is stuck,and ony goes till number 4,5,6
hi there your problem is the ribbon cable i guess thats why your slider getting stuck, thats also why only 456 number shown when your press key pad, due to stuck ribbon cable (they call it flex) on the slider the flex connector have loose or have been cut the ribbon. you should bring it to a service center to change it. thanks
May 28, 2011 | Sony Ericsson T303 Mobile Phone (Shadow...
Fit an alternator belt on a 1996 golf 1.9 tdi
there are 2 bolts,front and rear of the alternator,underneath it and an adjusterbolt on a slider bar.loosen all three then refit belt,leaving the main bolts fairly loose,place a lever behind alternator and pull away from block,until belts longest lenth has about 1/2 inch of movement in/out.then tighten adjusting bolt up tight,check movement in belt again,if okay,tighten main holding bolts.check again if all fine.JOB DONE.
May 19, 2010 | 2001 Volkswagen Golf
LG 265 Script slider too loose, won't stay shut.
I have that same problem.. did something fly out one time? because that is what happened to me and im still trying to find out how or if I should fix it.
Apr 16, 2010 | LG RUMOR Cellular Phone
The screws on the slider of my Pantech Matrix have come unscrewed and the slider is just barely hanging on. How can I take the phone apart to tighten these screws? AT&T and the manufacturer were of co
When I have wanted to replace a cover on any mobile, I go online google search put in the model of the phone/fascias or covers, the companies that sell these, also sell the pack of screwdrivers you need to use for these tiny screws. Its a one time buy, I would get a cover for a phone then you get the tool free? £5 possible £6 or get a pouch for your mobile. Good luck you will get it sorted.
Apr 24, 2009 | Pantech Matrix Cell Phone
Loose slider
That would actuallly be a warranty fix, if you have waranty take it to the store to fix / replace - otherwise it's a tuff fix and i suggest to use a pro
Jan 25, 2008 | Sony Ericsson W850i Cellular Phone
Nokia 5300 Grey Cellular Phone Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
