Question about Neovo M 15 (Black, White) 15.1 in. Flat Panel LCD Monitor
Neovo power supply
I got a neovo m-15v screen with a dead power supply. First it made some ticking sound, like transistor was trying to switch. Measured the voltage form the net (230 volts ok) than after the diodebridge (aprox 300volts) And than there are 2 ?transistors? mounted to a pice of aluminum. Behind these the power seemed to switch on and off. After a while there blew a service mounted resitor at the back of the circuitboard. And i couldn't measure anymore. Now i'm looking for a scheme of the powersupply of this screen. Can u help me out? thanks in forward. Kind regards, Biggles
Disconnect the PSU and get an external 12v 2amp psu try that as Ive the same problem
Posted on May 21, 2007
My neovo 17 inch moniter not getting on
To help you troubleshoot the issue, please follow the instructions mentioned below,
-Make sure monitor power cords are correctly connected to the power switch and connectors.
-Check if monitor VGA cable is connected properly from the monitor to the computer connector.
-Make sure Power button is switched ON.
If issue persists, please try to replace the Power cord and VGA cable if feasible.
If issue persists, it is recommended to contact your monitor manufacturer for further assistance.
GuruAid.com
Apr 19, 2016 | Neovo Computers & Internet
Ag neovo
Change your power supply.
Oct 20, 2017 | AG Neovo L-W22 22 wide screen LED...
Driver for neovo F417 lcd screen windows 7
No drivers are necessary. If Monitor is seen as "Plug and Play monitor" is ok.
Mar 07, 2011 | Neovo F-417 17" LCD Monitor
Neovo F-417 monitor keeps switching off and takes several minutes to be able to switch it back on again
The power supply of your monitor have problem.Leak capacitor at ur power supply need for replacement
Oct 04, 2010 | Neovo F-417 17" LCD Monitor
I have a Neovo !( inch monitor used as a security
First place to look will be for bad caps in the power supply/inverter section, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 21, 2010 | Neovo E-19 (Black) 19 inch LCD Monitor
Neovo F-419 screen blanks and power light flashes green.
Try other monitor(which is working fine) to your pc,if it work...it means your monitor gone bad.
If it doesn't work.. try to connect your neovo f-419 to the other pc to check if it is working.....,if it does,your pc's videochip/videocard or badmotherboard may cause the problem
Sep 29, 2008 | Computers & Internet
Power problem?
Try ordering a new power adapter from Neovo. Call them up. It could't hurt. Apparently adapters are tricky items. I have no idea how much they cost, but if its reasonable it would be a fair tade for the nuisance you are dealing with now.
http://www.neovo-usa.com/
AG Neovo Technology Corporation
2362 Qume Drive, Suite A
San Jose, CA 95131 U.S.A.
Email: rma@neovo-usa.com
Tel: 408-321-8210
Fax: 408-321-8211
Nov 14, 2007 | Neovo E-19A 19" LCD Monitor
Screen goes black in half a second....
Call the service dept. in the above post. Tell them the model and serial number of your monitor and order a backlight inverter board(approx. $35 plus shipping). Open up the monitor and plug it in, should fix the problem. This problem could also be caused by one or more backlights(small flourescent tubes) being bad. I just fixed a Neovo F-417 display by replacing one of the backlight assemblys. I also just fixed a Neovo E-17DA monitor by replacing the inverter board.
Oct 30, 2006 | Neovo E-19A 19" LCD Monitor
Neovo M 15 (Black, White) 15.1 in. Flat Panel LCD Monitor Logo
204 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
