Question about Mico DVDR310 DVD Recorder
DVD Set up
I have s Mico R311i DVD Recorder and Sky Digibox. Could anyone tell me the correct way to set it up please. I do not have a manual. I have a problem with the DVD not recognising the TV channels
If it's the Espejo 311i model (mine was £30 from Morgan) I don't think you'll have any joy trying to select channels direct from the unit. Mine works fine with a Freeview box but channel selection is strictly on the latter, then the SCART goes into the recorder's No. 2 socket (No. 1 goes on to the TV). You can record whatever the box is receiving by selecting 'EXT2' as the source. Even if you never record analogue it's a good idea to plug an aerial feed into the Mico so it can set its clock. Note PDC doesn't work (for me anyway) when recording via the SCART. If someone has set it up strangely you can reset from scratch by unplugging, holding the front panel On switch in, then reconnecting to the mains while keeping the button pressed until the first setup screen appears on your TV. It will auto-tune to any analogue signals it finds on the aerial input. I could probably scan at least some of the manual if you are really stuck.
Posted on May 13, 2007
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
Unable to set TV channels on dvd recorder since connected to Sky box
Actually you don't have to get other devices, Just cables, take the sky box output and connect to AV input of DVR
Feb 18, 2008 | Televison & Video
Wil my tv work with out remote
There are quite a few ways to connect cable box, DVD, receiver and TV together. At a minimum---Connections between DVD and a/v receiver: For Audio, either digital coaxial, digital optical or simple RCA (CABLE ONE); If you did not use RCA you need to connect Video with either component or s-video (CABLE TWO). For connection between a/v receiver and TV: either component, s-video or RCA (CABLE THREE) You did not mention how your cable (or sattelite) box is connected. You could use same set-up as between DVD and a/v receiver for another one or two cables depending on set-up used.connecting the speaker wires of an RCA TV to an amplifier: The signal that is fed to the speakers is not designed to be fed to the line-level inputs of your amplifier. You'd need some kind of conversion and I can't tell you exactly what that would be.
Get some double-screened satellite cable and fit a female TV plug to it (or a male plug with an adapter). Connect it to RF Output 2 at the rear of your Digibox. Fit a TV plug to the other end and plug it into your TV.
Temporarily disconnect the aerial feed from the Digibox aerial socket. Switch the Digibox on to get a picture on your main TV. The Sky Digibox normally sends its signal out on UHF channel 68 so go to the second TV and tune it to 68 (or tune it till it finds the Sky picture).
Now plug the aerial cable back into the Digibox. If there is now interference on the Sky picture on the second TV (or on the terrestrial channels) your Sky signal on 68 is causing interference. Press [services] 401 [select]* and set the RF output to a different UHF channel number. You need to connect it via a Scart lead on your main TV in order to see the menu.
*In the new EPG (April 2009) it's [services] 001 [select]
Try each RF output channel number in turn (21 - 69) and retune the second TV until you get clean pictures on the terrestrial channels and the Sky channel. Also check the picture from the VCR (if connected).
This is just a brief overview. If you need a real in-depth explanation you should read the "Piping TV Around the House" Ebook by satcure.
Nov 22, 2011 | AOMNI Corporation Televison & Video
I have a Pioneer DVR5100H which was set up to record Analogue programs - can I change the set up to accept digital programs. I have tried auto setup but it doesn't pick up any programs?
You can't record digital programmes with this recorder unless it is connected to a digital tuner, e.g. a Freeview box or Sky digibox. This recorder has a built in analogue tuner which allows it to record analogue transmissions. Recorders which can record digital transmissions have a built-in digital tuner and usually have a DVB logo (actually looks more like DV3) on the front.
If you want to record digital programmes using this recorder, you need to connect it to a Freeview or Sky digibox, preferably with a scart cable. It is not sufficient to connect it to a TV with a digital tuner or built in Freeview as the player does NOT record directly from the TV, it must be connected directly to the transmission source. A basic stand-alone digital tuner (Freeview box) can be bought for as little as £10-15.
Regards,
BElectric
Nov 18, 2010 | Pioneer DVR-5100H DVD Recorder
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
How do I tune it into Sky channels (lost manual)
i have tried to tune in a sky digibox that have not used for a couple of years,i can only tune in the first 9 chanels for some reason.any clues what i am doing wrong
Apr 13, 2009 | Televison & Video
New sky digibox fitted. Cannot timer record satellite programmes
I encountered a similar problem when recording and I phoned Sky and they changed my settings to eliminate standby mode for me.
No problem any more.
Mar 21, 2009 | Panasonic Televison & Video
I have a sony rdr-hxd870 dvd and as much as I follow the set up diagram I cannot get any signal via my sky digibox. I can get a signal via the analogue set up. The tv and sky reception work ok, but I...
this is a guess. there is a firmware update for the sony. has your one got the update? see it here https://www.sony.co.uk/electronics/support/home-video-dvd-players-recorders/rdr-hxd870/downloads/Z0005568 *** please be aware that you need to be good with creating the cd for the upgrade and it could if done badly, render your device useless. so only do it if it needs it. ** I am not saying it will fix the issue but the reason for the update seems IMPORTANT! and sounds like a possible reason.
Nov 09, 2017 | Televison & Video
Manual of instructions
I also ned a manual for the R311.
Jun 08, 2008 | Mico DVDR311
Mico DVDR310 DVD Recorder Logo
348 people viewed this question
Top Mico Televison & Video Experts
Are you a Mico Televison and Video Expert? Answer questions, earn points and help others
