SOURCE: i was driving and my cz500 clarion in dash threw
What was the code? was it something like mcu ulg? the same thing happened to my stereo. i have the same one. I called the people who installed it but they said they have no clue about what i am talking about.
SOURCE: mcu ulg error code for cz500 clarion radio. what
Hello there
The Clarions have an anti-theft feature that prevents the radio working if removed from the vehicle or if the 9000's battery is disconnected and then reconnected. This feature helps make the radio less desirable to thieves.
The Clarions have an anti-theft feature that prevents the radio working if removed from the vehicle or if the 9000's battery is disconnected and then reconnected. This feature helps make the radio less desirable to thieves.this code can be obtained online at the manufacturers website
Obtain the Clarion's 4 digit reset code that came with the player paperwork or from a dealership.
Put the car's ignition key in the ignition and turn to the "On" position to power the Clarion radio. Turn on the radio. The radio will beep and will not function.
Press and hold the "Band" button until four dashes are displayed on the Clarion display.
Enter the reset code by pressing the corresponding numbers on the radio's channel preset buttons. The code is six digits, using the numbers 1 through 6. These digits coincide with channel preset buttons 1 through 6. The radio will begin working properly once the code has been entered correctly.
NOTE;If you make an error while entering the reset code, finish entering digits to complete that attempt. The radio will beep and not reset. Press and hold the "Band" button until four dashes are displayed again and enter the correct reset code.
SOURCE: how can connect bluetooth in clarion cz500
Hold "D" button to enter the menu mode.
By using the previous/next button select BlueTooth menu by using the D button.
Use the volume to select auto connect.
I am also including the link to the manual just in case this doesn't work. Bluetooth menu will be on page 21.
http://www.clarion.com/us/en/MungoBlobs/370/422/CZ500_EN.pdf
SOURCE: I just installed a brand
The problem you are experiencing could result from a variety of issues. First ensure consistency on the wires which go to and from the unit to the power source to ensure that there are no breakages midway and the connection was properly done. Next ensure that the cable connections have been connected accordingly. Finally are you sure the unit itself is functional? if all connections are intact then try testing the unit to ensure it is operational as once the connections are right then the unit should work if it is operational.
Hope this solution has been helpful?
