Question about GE JE1460 Microwave Oven
How to repair a broken Handle on my microwave oven
My handle broke off my microwave oven. It looks like the bootom screw broke off. I don't know how to take the handle off to fix it. Please help Thanks Bob
  • GE Master
  • 9,156 Answers
If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Those diagrams should help you see how it comes apart.
Posted on May 10, 2007
  • William Miller
    William Miller May 10, 2007
    FOLLOW-UP: Quite often you have to take the door apart.
    It's usually not necessary to take the door off and usually best not to take it off.
    The attached photo shows how door panels often need to be separated.
Our handle broke off the fridgedaire microwave. Can we get a replacement handle or do we need to get a new door or new oven?
Can you post a picture of the handle? I have found that some handles have broken at the mounting screw and that a second mounting point is next to the original point.
Oct 01, 2017 | Microwave Ovens
Door handle broke on my Maytag MMV4205AAQ microwave. It broke once before while under the first year warranty so I know that repair requires replacing the whole door.If I purchase the part (PS909599), how...
Hi ,
There is a inner door trim on the inside of the microwave door that can come off to expose the screws for the handle. This trim is held in place by clips built into the trim, ( some older models may also have screws - look for them and remove before going any further ) the tabs on this trim can break easily but with a putty knife and some patience, the trim can be removed to get at the handle screws. See picture help. This trim can be pushed so the clips will "pop" back into place after the handle repair.
Sep 30, 2008 | Microwave Ovens
MVP V door handle broken
Maytag mvp v microwave door handle parts Questions ...
www.fixya.com > Forum > Tags > mvp v microwave door handle parts
Maytag mvp v microwave door handle parts related problems. Ask your Maytag mvp v... The handle on my maytag microwave oven broke off ... door handle ...
Maytag Microwave Handle Parts from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Maytag-Microwave-Handle-Par...
Shop for your Maytag Microwave Handle from our huge inventory. Return any part for any ... Repair Help for Microwaves .... Microwave Oven Door Handle.
CMV1000ADW Maytag Microwave Parts and Repair Help
www.partselect.com/Models/CMV1000ADW/
Dec 22, 2015 | Microwave Ovens
How do I repair the broken handle on my Spacemaker microwave from GE?
you have to remove the trim inside the door. you have to carefully pry the inner trim and kind of twist it as you remove it so you don't break it.
if there is enough of the handle left where the screw goes in(I'm assuming that's where it broke) sometimes you can drill into it a little and put a longer screw on. otherwise you need to buy a new handle.
May 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The handle broke on my microwave. How do I remove
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Aug 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Door handle broken away from microwave unit.
The door handle can easily be replaced. This is a common problem with microwave oven doors. You would think the manufacturer's would make them a bit more durable.
This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions about this repair, please let me know. I hope this helps you.
Jul 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Broken handle
Mine did this too. I fixed it by pulling the center front piece of plastic off the handle to reveal the screws. Problem was I found thet the failure occured in the plastic mount for the screw. I gorilla glued back in place and it has been good for several years now. Saddly the magnetron just failed.
May 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Handle broke and can't screw in the bottom screw of the new handle
bottom plate of the handle has a keyhole shape in the door-face of it
to go over a mushroom headed screw already secured in the door
tap the old broken handle down the door and it will pop off the screwhead
then
set the new handle sideways on the door, top end out into empty space, and pull it into place on the screw head,
rotate the handle top over the door and screw it into place, dont flex the handle much to twist it in place, they are brittle, and break
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
GE JE1460 Microwave Oven Logo
313 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
