Question about Sony VAIO PCG-K35 Notebook
HOW CAN I TURN ON THE WIRELESS SYSTEM? - Sony VAIO PCG-K35 Notebook
  • 611 Answers
In the your laptop the buttonis here for wireless press the button then wireless is on and in the taskbar you get the icon double glik on it then you ge tthe wireless connection connect it enjoy it
Posted on Jan 02, 2009
Activate bluetooth
hey steven,
The wireless card on this system was an optional purchase at point of sale. If your system came with the card then follow the the troubleshooting steps below.
  • Check the BIOS to ensure the wireless card is detected. Also verify the Wireless setting is turned on and not set to Always Off.
  • If the Bluetooth device is installed, also verify the radio LED is enabled. You can turn the wireless and Bluetooth cards on or off with the wireless switch.
  • If the card does not show up in the BIOS or Device Manager, try reseating the card.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 18, 2013 | Dell Latitude D530 Notebook
Turn wireless switch fn
Hello Raymond,
If your system does not have a wireless button on the right side of the laptop that turns the wireless on and off then you would turn it on by the key stroke below.
You can press the Fn + F2 key to turn wireless On or Off. Use Windows Mobility Center in the con.trol panel to check the status of the wireless connection.
Thank You,
Dell-Jesse L
Jun 25, 2013 | Dell Inspiron 15 Laptop
Just got aspire 3000 .How do I turn on the wireless capeability
The wireless feature (Wireless LAN) on an Acer notebook allows you to connect to available networks. This convenience allows you to use the Internet with network cables, modems or network installation. Acer laptops come with a wireless switch to turn the wireless feature on or off. Once you enable the wireless feature, your Acer notebook can connect to wireless networks within range.
Follow these Instructions
Locate the Wireless LAN switch located on the front of your Acer Notebook. Move the switch to the right to turn on Wireless connections.
Right-click the network icon located on the system tray next to the clock. You should see a list of available wireless networks.
Select the network you want to connect to and click "Connect."
Feb 12, 2011 | Acer Aspire 3000 Notebook
How do I switch on the wireless internet
Depending on the Operating System, you need to turn on the wireless option.
Windows - Look for the wireless signal bar, probably located in the bottom right. When you turn this on, it should search for the wireless signal and find the SSID (broadcasted network name) for your network. Click on yours and it will ask you for your passcode. You should have the passcode from when you set up your wireless router.
Once your system is setup, you may have to restart you browser.
I hope that helps
Nov 27, 2010 | Advent 4211c Notebook
Using the soundlink wireless music system. was working fine. suddenly, both aux light and wireless light are on. not getting sound output from PC. how do I turn 'aux' off? pressing the 'sux' button...
Simply plug the small USB key into your computer, turn on the SoundLink system and select your music--iTunes, Pandora®, whatever you like. That's it. No networks to configure, no cables to run. And you can control your music using the handy remote.
Remove the battery in the machine and put back. Also, remove the battery in the remote and insert a good battery.
To turn off youe aux simply press the aux botton on your phone i am sure it will work.
Thanks for contacting Fixya
Jul 04, 2010 | Bose SoundLink Wireless Music System...
How to turn on wireless on Lenovo T61 laptop?
I checked the manufacturer's web-site:
http://www-307.ibm.com/pc/support/site.wss/product.do?brandind=10&familyind=374625&machineind=0&operatingsystemind=49979&template=%2Fproductselection%2Flandingpages%2FdownloadsDriversLandingPage.vm&validate=true
but did not find any device-driver for the wireless-adapter for your Operating System.
This might imply that the wireless-adapter is fully supported by the Operating System, i.e., no additional device-driver is needed.
Open the "Network Connections" window, and display all the currently-defined network-adapters -- the wireless adapter should be present. Select it, and right-mouse click on its icon, and choose "enable".
Apr 29, 2010 | Lenovo (40Y7026) Wireless Adapter
Have wireless internet but no connection to laptop. where's the switch on the laptop to turn it back on?
Hi !
Most of the laptop wireless switch is on the side of the laptop. If there is no physical switch, press the Fn+F2(wireless symbol) to enable the laptop. Double check the wireless LAN if enabled in the system setup. To access system setup, press F2 while the system is booting-up.
Hope this helps !
Thanks.
Jan 23, 2010 | Dell Inspiron 1526 Laptop
Wireless switch on the front of the lap top wont turn the wireles on. can i turn the wireless on without using this switch? laptop is VGN-FW21Z
Depending on the version of your operating system, you can right click on the icon in the bottom right that represents your wireless connection. Then select "enable". This should turn your wireless on. If this doesn't work, you can do the same thing through the control panel if you click on network places and go to the wireless section.
Oct 30, 2009 | Computers & Internet
Wireless Connection won't turn on
Try running system restore to factory default there must have been a missing driver during some un-needed updates.
Restart system holding down the f11 key till you hear a beep. Dont forget to backup your documents.
May 20, 2009 | HP Pavilion dv2000t Notebook
Wireless network card driver missing. I re-installed it and restarted the notebook a few times but still no change.
first unplug your system unit and remove the wireless card to system unit and then turn it on and install the driver and if finished turn off your computer put back the wireless network card and turn it on.
Nov 25, 2008 | Computers & Internet
Sony VAIO PCG-K35 Notebook Logo
110 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
