Question about Nintendo DS Lite Console
Broken NDSL My son broke his NDSL in half. The gold wire (flexinble conductor) on the left side is also broken. How do I fix this problem?
  • 3 Answers
I ate it.
Posted on Jan 03, 2009
Sony pcg 281l
It is probably a broken backlight. This should be able to be fixed. It may be aconnector came partially loose when it was dropped. This shoild also be fairly easily fixed. Hope this helps.
Jan 01, 2014 | Computers & Internet
My skull candy ink'd left bud broke apart,how to re-wire it.
The wires inside the cord have broken, Unfortunately there is really no easy way to fix it, they don't solder well and replacing the cord is the only option but this also may not be successful. Replacing the headphones is the only proper solution
Mar 01, 2012 | Skull Candy Audio Players & Recorders
Can i fix my lg290c slider phone, the tape thing inside broke?
Yes this is fixable, but in most cases not by the owner as it takes special tools to take the phone apart to replace the part. This is best left to a cell phone retailers service personnel, cost about $50.00 on average to repair the flex conductor ribbon..
Dec 08, 2011 | Cell Phones
No sound coming from left ear initially, now no sound at all.
Sorry, it's probably not fixable. The wires are either broken internally or have become detached from the solder fixings and the headphones are not designed to be repaired, nor are spare parts available.
The only exception is if the plug on the end is broken or has broken wires. Wiggle the wire at the plug end only whilst wearing the cans. If you get sound, then identify where the wire has broken and cut the plug off at that point. Strip the wires, correctly identify the left and right conductors and fit a replacement plug using soldered connections. Ensure that the screening sheath is correctly soldered to the casing (it's the earth connection for both conductors) and close the new plug casing.
In practice, it's fiddly, and only to be done if you're confident with a soldering iron. If not, just do as Philips intended and bin your old cans and buy new: it's not as if the SBCHP430/00 was an expensive model to start with.
Feb 16, 2011 | Philips SBCHP43000 Headphones
Hello I have a LG Microwave/grill/convention oven. I caught my bracelet on the bottom lug thing that is attached to the door and now the microwave runs all the time? Please help is this something i can...
Sounds like part of the peg broke off and is left inside the recepter slot area where the sensor switch is. If it is the lower door plastic hook thing (inside bottom) that broke off, it is possible to re-attatch it to the door if you save the broken piece. Drill a small hole the size of a small wire or nail you have lying around to make a splint - Cut the nail or wire to about 1/2" to use it as a hidden "bone" or skeletal support inside the broken plastic. Glue the nail half way into the broken plastic using modelers glue. Closely align the nail peg to where the plastic broke off and mark it for drilling. Drill carefully making sure you are centered so that your wire "bone" will allow proper alignment of your plastic. Insert the pinned piece into the newly drilled hole checking for alignment, if it looks close enough you can glue it in place and you should have a strong enough repair. Dangerous to use a wooden peg to fool the internal switch. As it will be running even when the door is open and you don't want to get zapped.
Nov 04, 2010 | Microwave Ovens
My windows on the driver side will not roll down. I have checked the fuses and all are fine. The driver and left passenger door window switches have stopped working. How do I fix this?
open the drivers door and pull back the boot that goes between door and body. all the wires run through it. you will find one or two wires in there that have broken in half. get a piece of wire the same gauge as the broken ones about 4 inches will do.put a crimp but connector on each end of the piece of wire then stripe and conect to each end of broken wire.loop the extra wire so it lays flat the loop keeps it from breaking again
Mar 23, 2010 | 1997 Jeep Grand Cherokee
Broken lock
Gaffer tape is the best bet
Certainly you wont get parts in my view.
Though it may be worth a question to Sony Support - some models might -
May 24, 2008 | Sony Cybershot DSC-T200 Digital Camera
DS broken in half
I recommend you to change the broken case, you can choose to change only the hinge and keep the good case parts or change the entire shell. By the way stores usually sell the entire shell so you can choose. As your screens are still working you are lucky because so often the brown flexible conductor to the top screen get broken so be careful.
You can also use a silicon or hard plastic case to put over your broken NDSL to keep it in place just as the fast non technical option.
Here are some links and you can find text and video guides googling around.
Shells in ebay
Other stores items
Good Luck...
Nov 09, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
