Question about RCA L1800BC 1.8 in. Handheld Television
A/V cable What type of cable do i need to use the A/V input or external ant? I want to hook up to a dlp overhead projector to use as a moniter.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
On most handheld TV units, the A/V input requires a 3.5mm stereo baby phone plug. While on most projectors, the Video out is a composite single RCA jack. What would be needed then is a 3.5 babyphone to RCA cable/adapter.
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Jan 02, 2009
SOURCE:
How connect to BenQ mp620p- xBox360 ? Thanks good luck
If you've got the version with a DVI input, use a HDMI to DVI cable. That'll take care of picture but not sound. You need to hook up an audio cable that finishes in a 3.5mm stereo jack if you want to use the Benq's speaker.
If you have the older version with just a VGA input then buy an Xbox 360 VGA cable. You'll also need an audio adapter; 2x phono/RCA sockets going to 3.5mm stereo jack.
Sep 09, 2014 | BenQ MP620p DLP Projector
My DLP projector SIM2 DOMINO D35 is turned on and works normally BUT picture is absent on all of inputs (projector shows NO SIGNAL, green indicators is ON). Sources of signal and cables are in order. What...
It is possible that the last time this was connected there must have been an higher input applied than is recommeded so that the input PRE_AMPS were loaded to fail.
You need to check with an signal trace on the input to find if an OP-AMP has failed or the LOGIC switching IC had failed.
Need to test using a signal tester and meter.
Jul 14, 2011 | SIM2 DOMINO D35 DLP Projector
Hello, if I want to hook up an external audio device such as a speaker to my Toshiba TDP-ET20 DLP Projector, how do I do that?
Hey,
You will need to buy a digital coax to an RCA or analog Headphone cable. You will plug the digital coax end of the plug into your "coax out" connection on the back of the project.
The other end will depend on your speakers. If your speakers take an RCA connection (white and yellow cables) then you will buy a Digital Coax to RCA cable. If they take a regular headphone jack then you will need a Digital Coax to 3.5mm headphone jack converter, and plug the headphone jack into your speakers.
Mar 01, 2011 | Toshiba TDP-ET20 DLP Projector
It says, that the ViewSonic PJD5122 SVGA DLP Projector has a built in 5 watt speaker. Does it? Because when i try to hook my xBox into it, there is no sound when the voume is all the way up. Also, when I...
You have a 3.5mm Audio Input jack for external audio in. ( Not Speakers) The Audio Output jack is for connecting that to a stereo system which is the best way to go. So, what you want to do is connect your xbox audio out which is probably a rca jack to the projector. I believe you will have to buy a y-adapter ( 3.5mm male > double rca fe-male) then use the standard rca audio cables. You don't plug speakers into that unit, I hope you haven't damaged the audio circuit. You might have a external audio switch within the menu of the projector to switch from internal to external audio source,,, look for that.
Dec 03, 2010 | ViewSonic Televison & Video
Projector does not work with computer
Hi Connecting a laptop computer to an overhead projector is a relatively simple process. That said, it can be a disaster to work hard on a presentation, be it for a school or workplace environment, only to show up and find yourself unprepared. Take the time now to learn about the different ways your laptopmag-glass_10x10.gif can connect to an overhead projector, and how to accomplish this easy task, and you can enter your presentation with poise and confidence.
Learn the different types of video outputs your laptop may or may not support. The three most common types of video outputs used with overhead projectors are Video Graphics Array (VGA), Separated Video (S-Video) and High Definition Multimedia Interface (HDMI). You need to make sure your laptop has the correct output corresponding to an input on the projector you will use.
Jul 31, 2010 | Eiki LC-XE10 Projector Multimedia...
How do you feed TV thru an Optoma DLP projector?
You need a tuner to tune in the tv channels. use a vcr that way you can change your channels
Jun 06, 2010 | Optoma EP739 Multimedia Projector
DLP Projector connection to Laptop
you need to go to te control pannel and go to display settings then manually select the external monitor then hit apply it will open on your projector
Nov 02, 2009 | Office Equipment & Supplies
Can i connect my xbox to X10 projector
yes it does... and there is available input for HDMI, S-VIDEO,M1-DA, & Composet video.
Oct 08, 2009 | InFocus X10 DLP Front Projector 1080p DLP...
CONNECT CABLE TO MY PROJECTOR
Depending on the specific model of your Mitsubishi DLP, you can have either S video, RCA, VGA or a few other choices of INput connection.
Depending on your cable provider and hookup, you can either have a plain cable with F connector or a cable box normally with RCA connectors and a remote control.
If you have a simple cable connection that attaches direct to a TV (no remote, no box), you would need a TV Tuner to be able to receive the different channels whose output would be a composite video signal into the yellow RCA jack. You would need an RCA to RCA cable to in turn connect it to your Yellow RCA Video INput of the projector. In the absence of a tuner, an old VCR with such a feature would also serve the purpose. In some instances either units may also have an S video connection.
If you have a cable box with with remote, then there is no need for a tuner or VCR since its output would already match the projector's input.
Either way you would need a separate audio amplifier/speaker  for the sound.
Hope this be of some help/idea. Pls post back how things turns up or should you need additional information.
Good luck and kind regards.
Oct 23, 2007 | Office Equipment & Supplies
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
RCA L1800BC 1.8 in. Handheld Television Logo
103 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
