Question about Linksys Wireless-G Broadband Router
I can't connect to the router from my laptop
When i tried to connect to the router to configer it from my laptop it was faild , but i can connect router from my PC ,, and i can connect to the internet from the laptop ((wireless & wired )) ,, so the problem is : i can't connect router from my laptop to configer it , although i can connect to internet from the laptop !!
help me please .
  • s.engineer Jan 02, 2009
    all of this settings are true ..
    and still the same problem !
    anyway thank you so much :)
  • 36 Answers
Maybe is a browser problem. Try another.
Posted on Jan 03, 2009
  • 611 Answers
Find the wather firewall is enable or what is enable then disable it and other this is wireless zero configuration option is start or what is start then re-start it
Posted on Jan 02, 2009
Can't connect work laptop to router (wireless or
Your work laptop probably has proxy settings in the browser. If yes, please remove it adn try. That should help .
Thanks
Ranjit
Jan 05, 2010 | Actiontec Electronics (GT724WGR) Retail...
I brought a Laptop (acer) I need to connect to my network but I can't remember my password. How can it get into the router to see what it is. I've called Linksys but they want to charge me 29.99
there a reset button on the back to reset config. so you must have all the router config backup on paper.
to reset router:
1st the router manual, needed for config.
2nd backup router config.(on paper)
3rd press the reset button more than 5 sec. until all lights were off (except on)
4rd reed manual the steps for 1st time config.
then config router again, and test internet connectivity and wireless security level (WPA2), change all router passw every 30days or less.
Dec 26, 2009 | Linksys Wireless-N WRT150N Router
Dhcp setup on a Cisco 2851 router
Let's look at how to configure basic DHCP on an IOS-based router. For this example, we'll start off with the default configuration on a Cisco 2611 router running IOS 12.2. (The configuration should be the same—or very similar—on all IOS-based routers).
To begin, connect the router's Ethernet port to a switch, and connect the switch to a laptop, which will serve as the DHCP client.
To configure Cisco IOS DHCP, follow these steps, which include sample commands:
1.Configure an IP address on the router's Ethernet port, and bring up the interface. (On an existing router, you would have already done this.)
Router(config)# interface ethernet0/0
Router(config-if)#ip address 1.1.1.1 255.0.0.0
Router(config-if)# no shutdown2.Create a DHCP IP address pool for the IP addresses you want to use.
Router(config)# ip dhcp pool mypool3.Specify the network and subnet for the addresses you want to use from the pool.
Router(dhcp-config)# network 1.1.1.0 /8 4.Specify the DNS domain name for the clients.
Router(dhcp-config)#domain-name mydomain.com5.Specify the primary and secondary DNS servers.
Router(dhcp-config)#dns-server 1.1.1.10 1.1.1.116.Specify the default router (i.e., default gateway).
Router(dhcp-config)#default-router 1.1.1.17.Specify the lease duration for the addresses you're using from the pool.
Router(dhcp-config)#lease 78.Exit Pool Configuration Mode.
Router(dhcp-config)#exit
I hope this is helpfull for you.
Thanks
Vikrant
Oct 26, 2009 | Computers & Internet
I had a earlier problem with my wireless network adapter in my laptop not fully installing. I bought a driver program and now I should have the most updated driver and the driver is working. my continuing...
To configure the wireless router and the laptop's wireless card, follow these steps : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 17, 2009 | Linksys WRT160N Wireless Router
Cannot connect via wireless network, router not being detected by laptop or ps3. I can connect to internet on desktop via modem through router. When trying to detect wireless network via laptop and ps3...
stupid question : is Wifi turned on ?
Go to your administration environment of your router ( typically : http://192.168.1.1 ) and check the config of the wireless settings
Aug 14, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
I just purchased a Dell Latitude 6500 laptop and I can't connect to my home network. I am using an Intellinet router.
hi! there is no problem with your internet connection with your router but the problem is your dell lattitude wont connect to the wireless network, please try to disable your dell software for connecting to wireless network and just use the windows wireless zero config, check the on the taskbar on the lower right of the monitor, there is an icon for the wireless connection for dell, right click it and select disable, sometime there is an option that windows will ask if you want to turn on the wireless zero config..if it didnt ask, click onn start, run and type in service.msc then it will show the services go to the buttom portion and enable the wireless zero config..
Aug 08, 2009 | Computers & Internet
Link Sys wireless G router, connects with laptop, not desktop
first unhook router and hook up pc directly yo modem and type in 191.168.1.254 and goto config tab and see is modem is ppoe or bridge to ethernet needs to be ppoe second go back into setup on router and do a manually config and tell you have a dynamic dns and finish setup process i had the same problem with att internet and att had me setting it up wrong
THESE ARE DSL INSTRUCTIONS
Feb 16, 2009 | Linksys Wireless-G WRT54GS Router...
DWA 552 and 2WIRE HP1000
you dont have router protected (is not yours anymore).to gain control again, you can rest config. but you need your router manual nerby, to help you config. a previous internet provider config. and so on. to reset router config, you press a reset button on the back, until the lights is off/red. then config the router on the router website( writen on botton with default user and passw.(user: admin passw: admin or password) the wan config, Wlan,...
(Use a wpa2/wep encrption level on Wlan config.)
Note: change all router passw every 30 days, or less if necessary.
Jul 24, 2008 | 2wire HomePortal 100W (1000-400026-000)...
Getting setup
Unless you get into the configuration of the router, you don't have to worry about 'messing' anything up... you just need to know the SSID (the name of the wifi connection they configured) and the password, if it is protected with WEP or WAP... just install the card into the laptop with the proper drivers, and use either the utility that came with the laptop (turn off the Windows Wireless Config in your services.msc) or use Windows Wireless Config Utility to access (find) the SSID of her router..
Let us know if you need further info...
Nov 20, 2007 | NetGear (IM-WG511T) Wireless Adapter
Linksys Wireless-G Broadband Router Logo
55 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
